Lawn Boy Push mower Questions - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 9 Old 02-10-2013, 12:12 PM Thread Starter
matth8888's Avatar
Arrow Lawn Boy Push mower Questions
http://charlotte.craigslist.org/grd/3577705533.html
Is this worth it? what model is this? What do these sell for running?
Current Fleet
- Lawnboy 7351
- Lawnboy R7070
- Wheelhorse 312-8
- 1999ish Simplicity Broadmoor 16hp/38"
-1990 Bolens 1468
And many other mowers, blowers,trimmers ect. Too many to list.
Sold
- Snapper RER 6hp/ 25"
-Murray 11hp/36"
- 1998 Murray 18/42
- 1990 Lawn Boy GT18H
-2008 Simplicity Broadmoor 20hp/ 44"
matth8888 is offline
post #2 of 9 Old 02-10-2013, 12:54 PM
Yard Nazi's Avatar
Talking Re: Lawn Boy Push mower Questions
Hi! Not sure of the model without better pictures or more info but appears to have a bail so post 1983 year. Seems to be a push rather than self propelled as well but hard to tell. You could easily part this out and make back well more than the $25.00 investment but it would depend what you are interested in it for. If you are looking for a mower for yourself or one to flip then it would only be worth the money if the motor has good compression and is not seized. I paid $125.00 for a 1996 push Lawnboy, one owner and very clean, but had to put no money into it. On the other hand I have purchased two different mid 70's D series Lawnboys at estate and yard sales for $25.00 each. One did not start and the other did start but ran poorly. Didn't take much money to make either of them good running, usable mowers. Also make sure there is no damage to the deck such as missing pieces, cracks, etc. Surface rust is easily cleaned off the handles with as SOS pad or similar method if it is not too bad. Make sure wheels are not worn through or excessively loose. Also make sure bail cable is not frozen as well as the throttle cable. Again, pretty hard to go wrong for $25.00 but it depends what you expect to get for that. Hope this is helpful. Bill
1968 Lawnboy Mower Model 3054******1973 Lawnboy Mower Model 8231******1975 Lawnboy Mower Model 5024
1975 Lawnboy Mower Model 5273******1976 Lawnboy Mower Model 5274******1976 Lawnboy Mower Model 8234EX
1977 Lawnboy Mower Model 5024******1980 Lawnboy Mower Model 7268******1982 Lawnboy Mower Model 5247
1982 Lawnboy Mower Model 5247******1972 Lawnboy Edger Model 1015******1972 Lawnboy Edger Model 1015
1987 Lawnboy Trimmer Model 1400CL
Where there's a will, there's Mr. Bill!
They don't call me MacGyver for nothing!
I have LBAD and DCAD!
Yard Nazi is online now
post #3 of 9 Old 02-10-2013, 03:23 PM Thread Starter
matth8888's Avatar
Well,i got the mower for $20.
Model #... Can anyone tell me about this model? engie type?
The pull cord dosnt retract in all the way. can anyone help me on this?
And i dont think this is the airfilter cover....it looks like a mulch plate for a mtd.
IT does have good compression though.And yes i have the gastank,ect; i just took it off.
Anyone have a manual or parts schematic?
Current Fleet
- Lawnboy 7351
- Lawnboy R7070
- Wheelhorse 312-8
-1990 Bolens 1468
Sold
-Murray 11hp/36"
- 1998 Murray 18/42
post #4 of 9 Old 02-10-2013, 04:02 PM
Yard Nazi's Avatar
Hi! Your mower is a 7351, 1988 aluminum deck push mower with the reliable F engine. This model was made in 1986, 1987, and 1988. Here is a link to Lawnboy.com with some information about your mower. You can also download the Lawnboy service manual through this link. Typical cause for the rope not to retract would be a broken recoil spring although it could be something else. The service manual may be of some help in disassembly. That plate does look like a deflector for an MTD so search eBay for the correct air filter cover which should be part number 93-1231. Good luck in getting this running. Shouldn't be too hard to clean the carb, check exhaust ports for clogging, check for spark, etc. If you need any help we are here to answer any questions. Bill
https://support.lawnboy.com/portal/s...ificationsPage
post #5 of 9 Old 02-10-2013, 11:49 PM
Mowerholic
BDM53's Avatar
Nicely done, some of my best mowers started out as $10 or $20 find.
Branden
BDM53 is offline
post #6 of 9 Old 02-11-2013, 09:49 PM Thread Starter
matth8888's Avatar
ITS ALIVE!!!!
I cleaned the carb and she fired right up!Anything else i should do? Should i clean the muffler ports? Now I wish i could find more 2-stroke Lawn Boys. Down here in Charlotte,N.C I dont see many...
Current Fleet
- Lawnboy 7351
- Lawnboy R7070
- Wheelhorse 312-8
-1990 Bolens 1468
Sold
-Murray 11hp/36"
- 1998 Murray 18/42
post #7 of 9 Old 02-12-2013, 12:41 AM
Yard Nazi's Avatar
Hi! Great to hear you got it running with minimal effort. Since you don't know what has been done to the mower I would check the exhaust ports to be sure they are clear. Sharpen the blade and invest in a new air filter and plug and you should be good to go. At some point if you have access to a way to check RPM's you could see how it is running. Just be sure it's not running too fast. Better that it's a little slow than too fast. Bill
post #8 of 9 Old 02-16-2013, 03:06 PM
Wolfy's Avatar
Those f engines are great. It usually is just the carb
Lawnboys! Yeah I have some...
Dad's LB 10550, 10525, 10323, 7023
Wolfy is offline
post #9 of 9 Old 02-17-2013, 11:31 AM
Mowerholic
BDM53's Avatar
no doubt. Think of how many mowers have been posted here being saved with just a carb rebuild or replacement. Ashamed so many give up on a mower because of it.
Branden
BDM53 is offline
