Too deep of a LB cylinder scratch? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 32 Old 03-17-2017, 01:59 PM Thread Starter
RfWi's Avatar
I bought LB 8270 that runs and an R8237 that doesn't.$25 for the pair. Both F engine.8270 had min.compression(80) and some leaks,I bought seals and rings and misc.to rebuild 8270 motor,my first attempt at something like this.I was reading another thread here about a rebuild and it was mentioned if a scratch in cylinder wall catches a fingernail the cylinder is junk.Well,my cylinder seems to have one of those.Is it indeed junk???If so hopefully the R8237 cylinder,that has really low compression,is in better shape.
RfWi is offline
post #2 of 32 Old 03-17-2017, 05:03 PM Thread Starter
RfWi's Avatar
Re: Too deep of a LB cylinder scratch?
Pic of cylinder after honing.Does that make any difference as far as being usable or not??
RfWi is offline
post #3 of 32 Old 03-17-2017, 05:59 PM
I would just use it before saying its junk. I wouldn't imagine 1 scratch like that would make the cylinder "junk".
I have been thinking of ideas to save wore out Lawn Boy cylinders. I wonder if a machine shop like Millennium could put a sleeve in or if there are chrome rings that will work with the piston a nikisil plating would last pretty much forever.
1998 John Deere 345
1996 Honda Harmony HRM215
1983 Lawn Boy 6301
1987 Lawn Boy 7351
1991 Lawn Boy S21ZPR
1999 Lawn Boy 10525
javjacob is offline
post #4 of 32 Old 03-17-2017, 06:47 PM
Yard Nazi's Avatar
Talking Re: Too deep of a LB cylinder scratch?
I would say you have nothing to lose in giving it a try. Lawnboys are pretty forgiving. I have read many storys of mowers that were straight gassed and frozen up and were freed up, cylinder cleaned, and used. You may have a small amount of compression loss but think about the scratch size and how much compression would actually leak by compared to how much stays in at the compression stroke. Good luck and keep us posted. Bill
1968 Lawnboy Mower Model 3054******1973 Lawnboy Mower Model 8231******1975 Lawnboy Mower Model 5024
1975 Lawnboy Mower Model 5273******1976 Lawnboy Mower Model 5274******1976 Lawnboy Mower Model 8234EX
1977 Lawnboy Mower Model 5024******1980 Lawnboy Mower Model 7268******1982 Lawnboy Mower Model 5247
1982 Lawnboy Mower Model 5247******1972 Lawnboy Edger Model 1015******1972 Lawnboy Edger Model 1015
1987 Lawnboy Trimmer Model 1400CL
Where there's a will, there's Mr. Bill!
They don't call me MacGyver for nothing!
I have LBAD and DCAD!
Yard Nazi is offline
post #5 of 32 Old 03-17-2017, 07:10 PM
Lawnboy77's Avatar
Images: 15
Looks like pretty deep scoring, personally I wouldn't waste my time and money on it. I think there is a good chance the cylinder bore is way out of limits anyway after all the honing was done. There are plenty of good used F series engines/cylinders out there for a decent price, so really not much of a need to mess with that worn out cylinder. I know compression will probably be within range (on the lower side), but I'd be worried more about the piston slapping going on than the compression loss...yes, been down that road recently and it's not a good road.
Lawnboy77 is offline
post #6 of 32 Old 03-17-2017, 08:03 PM Thread Starter
RfWi's Avatar
Well,I'm going to tear down the R8237 motor tomorrow and see what that cylinder looks like.
RfWi is offline
post #7 of 32 Old 03-17-2017, 11:37 PM
The bad thing about buying another used cylinder assembly is you are still just taking a crap shoot. Its too bad nobody makes over size pistons for these motors, there is definitely a market for it.
1998 John Deere 345
1983 Lawn Boy 6301
1987 Lawn Boy 7351
1999 Lawn Boy 10525
javjacob is offline
post #8 of 32 Old 03-18-2017, 12:47 PM
Yard Nazi's Avatar
Lawnboy77 makes a great point regarding the specs on the cylinder. If you have the tools or know someone that does, be sure to measure the ID of the bore. That would at the very least give you an idea if the bore is within specs or not. I don't think I have ever seen a cylinder being sold on eBay where the seller has already measured the internal diameter of the bore and provided that information so as it was mentioned above it's a crap shoot. Good luck and let us know how you do. Bill
post #9 of 32 Old 03-18-2017, 04:31 PM Thread Starter
RfWi's Avatar
Well,I got the R8237 motor torn down.Lots of carbon but not totally blocked,rust inside,one ring stuck to piston,and looks like a bit of something stuck to cylinder wall.But I think this one is usable.
ID:	1925226   Click image for larger version
ID:	1925234   Click image for larger version
ID:	1925242   Click image for larger version
ID:	1925258   Click image for larger version
RfWi is offline
post #10 of 32 Old 03-20-2017, 11:23 AM
Lawnboy77's Avatar
Images: 15
yes that one looks to be quite a bit better than the first one you posted. I see a little aluminum transfer, but should be no big deal.
post #11 of 32 Old 03-20-2017, 07:14 PM Thread Starter
RfWi's Avatar
I got the motor back together using that cylinder,and the reeds.The crank from the 8270 was in better shape so I used that one.The 8270 has the hex governor,the R8237 the round gov., so I'll use that one.Kind of odd they have two different carbs since they are both 1980 per LawnBoy serial number search.They each had different shrouds,I think one was replaced at one time since it has a date stamp of Dec. 1981,this one has the extra vents on top.The R8237 deck has less wear on it and not cracked so hopefully in the next few days I'll get that motor mounted on it and see if I did any good with it! Then I can get to making it look better with a repaint.
RfWi is offline
post #12 of 32 Old 03-24-2017, 04:41 PM Thread Starter
RfWi's Avatar
Welp,got the motor put back together and mounted on the R8237.It took a bit of priming and messing with the mixture needle but I did get it running.woo hoo!! I don't think I should run it anymore until grass cutting time to break it in with a load on it...right?Now I want to give that deck and housing a going over.It's kind of rough.
ID:	1929777   Click image for larger version
RfWi is offline
post #13 of 32 Old 03-24-2017, 06:04 PM
unclelee's Avatar
Images: 5
Good work, nothing like hearing one come back to life.
1953 8FH11LB
1958 9200 Loafer
1960 ET-1 edger
1963 8221
1964 3052
1967 3002
1968 5236
1969 7259
1971 5020
8235AE
6255 commercial
8461 commercial x2
1982 5006
10323 Duraforce
10732 Lawngirl
10520 Gold Series
GOD GUTS GUNS & LAWNBOYS
unclelee is offline
post #14 of 32 Old 03-24-2017, 06:44 PM Thread Starter
RfWi's Avatar
Thanks,I was getting a bit bummed when it didn't fire up right away,but it sure was a nice sound when it got to running right!!
RfWi is offline
post #15 of 32 Old 03-25-2017, 10:28 AM
Lawnboy77's Avatar
Images: 15
Outstanding! It good hear all these classics being brought back to life.
