snapper yt12d rear end fluid? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 2 Old 03-23-2009, 08:27 AM Thread Starter
ragman396's Avatar
On the left rear side cover I took off the rubber gromet and it looks like its full of bearing grease. Is this right? I cant seem to find what the fluid is to be.
Any help out there? Thanks in advanced for any help with this....
Steve
ragman396 is offline
post #2 of 2 Old 08-11-2009, 08:24 PM
Re: snapper yt12d rear end fluid?
According to the manual for transmission differential remove check plug on the inside of the unit to check level of oil. add snapper #0 grease as needed thru upper fill hole to bring level up to the lower of the check plug hole. reinstall plugs. (chain case) remove plug and check if dry, add 1 ounce of snapper 0 grease do not overfill. Total capacity must not exceed 2 ounces. These our direct quotes from a yt 12d series 4 tractor manual
mark2550 is offline
