L3010 Starter problem - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 5 Old 09-22-2010, 01:17 PM Thread Starter
Long story short, I can jump the starter and start the tractor. What I can't do is isolate where the fault is yet. Think I have a problem with the black wire with white stripe from the back of the ignition switch to the starter.
I can get continuity from the connector attached to the starter relay down to the starter. I can't get continuity from the connector behind the dash connected to the ignition switch to the the connector at the starter relay or the starter.
Questions:
Obviously, what lies between?
Anyone have a readable wiring diagram? Not the one from the parts manual. I have that, and its just not suitably detailed of the areas I'm concerned about.
How can I test the starter relay?
I'm electrically challenged, so be kind. Thanks,
J
200x Kubota L3010HST
fishpredator07 is offline
post #2 of 5 Old 09-22-2010, 01:34 PM
Machinery enthusiast
Volfandt's Avatar
Re: L3010 Starter problem
Welcome aboard fishpredator07, J.
I don't have a shcematic so all I can do is offer a few swags.
1) Sounds like a safety switch. I don't know if you tractor has one but most have a switch on the pto lever (will only start with the pto off) and anotehr switch on the range selector (must be in neutral).
Some even have them on the clutch pedal meaning you have to have the pedal depressed inorder to start.
The pto switch is usually the main culprit. If it has one, wiggle the pto lever while simultainiously trying to start.
Other than the safety switches you should be able to take 12v and apply it directly to teh start solenoids small terminal, which is how I figure your jumping it now but the small terminal is the pull down circuit and if it works as it appears, the problem lies in the wireing, safety switches and maybe even the key switch.
Good luck and if I happen across a schematic I"ll be sure to post it.
Dave
http://www.mytractorforum.com/showth...highlight=BX23,
1966 Wheel Horse 856, Gear.
1966 Wheel Horse 876, HST.
http://mytractorforum.com/showthread...hlight=856,876
Volfandt is offline
post #3 of 5 Old 09-22-2010, 04:46 PM Thread Starter
Dave - thanks for the suggestions!
Will try the wiggle the pto solution first. That would be quick to test. I tested the clutch switch, it was ok.
I found a doc explaining how to test relays that I'll also be trying out next opportunity.
I feel like I have a $5 problem that's taken me 50 hours to isolate. Maybe $50, those relays aren't cheap.
Thanks again,
Jim
post #4 of 5 Old 09-23-2010, 09:56 AM Thread Starter
Tried the wiggling the PTO while starting, no luck.
Still need to test the relay and do more continuity checking.
Hate to have to dismantle the wiring harnesses behind the dash, but may have to to understand where the black/white goes, and why.
post #5 of 5 Old 09-30-2010, 01:38 PM Thread Starter
Wiring fault in the harness behind the panel under the seat. Couldn't see it from under or behind the tractor. Once the panel was off, I could see the damage to the wire. Was no bargain getting the handle off the 3-point drop adjust to get the panel off. Thank goodness that's over.
