Kohler vs Briggs & Stratton. - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 35 Old 07-18-2009, 10:52 AM Thread Starter
I'm buying a Craftsman today(good Sears sale going on). The final question is: Kohler or Briggs & Stratton engine? Is one better than the other?
FYI I'm looking at either the YT 3000, YT 400 or PYT 24hp/42".
Thanks in advance for advice, warnings, etc.
swami7774 is offline
post #2 of 35 Old 07-18-2009, 11:18 AM
Re: Kohler vs Briggs & Stratton.
kohler is by far the better and long lasting engine
Bob Liley is offline
post #3 of 35 Old 07-18-2009, 11:38 AM
Has anyone seen ChimChim?
Brett-JDX748's Avatar
Assuming both engines are cast iron liner, full pressure lubrication, I don't think it's easy to pick a winner.. I think between Kohler Courage and Briggs Vangaurd it's a toss up.
X748 Ultimate,
Diesel, 4x4, 62C MMM, SE Seat, Quick Hitch,
54" Plow, 26Gal Sprayer, Soft Cab, 10P Cart.
That knockin, ain't a loose rod, Son!
Photos
Former Fleet:
2009 Craftsman GTS5000 Excellerator - Sold
Photos
2006 John Deere 3320, FEL, Backhoe, 62 MMM - Sold
Photos
2005 Cub Cadet 6284D FEL, Backhoe , 70" rear finish mower - Bought back, LEMON
Photos
Brett-JDX748 is offline
post #4 of 35 Old 07-18-2009, 11:40 AM
Sailingamerican's Avatar
For years no one thoght B&S engines were very good. They are making some very good engines today. I have a few and the comercial ones seem to do very well. I have a small one on a lawn vac and it is junk. You can never get it started. My YT and my Troy Horse tillers both have the B&S engins and do just fine. I would still go with the Kohler. I still think they have an edge.
Sailingamerican is offline
post #5 of 35 Old 07-18-2009, 11:54 AM Thread Starter
They are both cast iron liner, yes.
post #6 of 35 Old 07-18-2009, 12:42 PM
Chris223's Avatar
Don't you mean Kohler Command? Courage engines are not even close to the quality of Vanguards, at least as far as I've read. Either way, you will not find a Vanguard or Command in a box store these days. They mostly run Courage and B&S Inteks.
Chris223 is offline
post #7 of 35 Old 07-18-2009, 12:47 PM
FrankMA's Avatar
Location: Merrimack Valley in Northeastern Massachusetts
I'd rather have a BS Intek over a Kohler Courage. The bad air cleaner problem the Intek's had has been fixed for quite a while. I believe this problem is what gave the Intek's a bad reputation. Never had a Courage but I've not heard too many good reports on them - for whatever that is worth.
2002 Toro Wheel Horse 522xi
Honda HS928TA Snowblower
Honda HS621AS Snowthrower
Honda HS520A Snowthrower
Honda HS624WA Snowblower (Sold 8/23/2010)
Honda EM6500SX Generator
Stihl BR550 Backpack Blower
McCulloch MS1635 Chainsaw
Weedeater SST25 Line Trimmer
"It is what it is!"
FrankMA is offline
post #8 of 35 Old 07-18-2009, 01:17 PM
standard issue neuralyzer
LLigetfa's Avatar
Assuming both engines are cast iron liner, full pressure lubrication...
Check the specs closely. The presence of an oil filter does not assure full pressure lubrication. Some engines with filter still rely on splash lubrication.
LLigetfa is offline
post #9 of 35 Old 07-18-2009, 02:07 PM
Vet-Wrencher
Big10's Avatar
The old briggs use to be built as heavy as the kohlers were BUT, being how briggs has cheapened there stuff (like everything else this day and age) casting there blocks in mexico and getting there parts from japan, i honestly couldnt recommend Briggs anymore. I would go kohler. Just stay away from the courage line so i hear. 50 to 60 years ago Briggs and kohler were building neck & neck and ALOT of people chose Briggs but today that story has changed quite a bit.
I can set a good example right now.
I've rebuilt a good few Briggs engines recently becouse the rings were shot and were talking engines that were barely 10 years old. I have YET to rebuild a kohler that is under 10 years of age, and you could probably give some years aswell.
Obstical's are those terrible things you see when you take you're eye's off you're goal-Henry Ford
Big10 is offline
post #10 of 35 Old 07-18-2009, 02:41 PM Thread Starter
I went with the Kohler(on the YT-3000). It came down to the 3000, 4000 or the PYT 24hp. The Cub Cadet that just died after 28 years had a Kohler Magnum, so hopefully the company still makes good engines.
Supposed to be delivered Monday. And yes, I'll post some pix.
post #11 of 35 Old 07-18-2009, 02:52 PM
Chris,
*shrugs* The Kohler V Twin in my 5000 is labeled as a Courage and is a cast iron lined, full pressure lube extreme service engine. So.... Not sure all Courage engines are the same level.
LLigetfa,
How is it possible to have a spin on automotive oil filter and "splash" lubrication? To build oil pressure you have to have a georotor pump, how is the oil going to move through an oiling system (and a filter) in a con-rod splash setup?
http://www.kohlerengines.com/onlinec...ourage%20SV735
Not sure what Sears specifies that differs the standard SV735 from the one used in the GT5000's (the labeling is a little different). But those are the specs.
X748 Ultimate,
Photos
Former Fleet:
Photos
Photos
Photos
post #12 of 35 Old 07-18-2009, 03:39 PM
LLigetfa's Avatar
LLigetfa,
It is possible to have both. The topic of splash lubed engines with spin-on filters has been discussed here several times.
Oil systems: splash vs. "others"
LLigetfa is offline
post #13 of 35 Old 07-18-2009, 03:52 PM
LLigetfa,
Like I said, it would be impossible to be splash lubricated with a spin on filter. Those are technically pressure lubed systems on the top end, the crankshaft and con-rod are "splash" lubed. OHC engines need to be pressure fed, the cams have to float in pressurized oil flow, a lot of times they don't even use a "bearing" the tolerances in the head are machined in and the cam floats in the oil and there is no typical babbet bearing to be found.
X748 Ultimate,
Photos
Former Fleet:
Photos
Photos
Photos
post #14 of 35 Old 07-18-2009, 06:22 PM
LLigetfa's Avatar
Ja, as I said, "It is possible to have both". In the second link I posted are the words "ALL are pressure lubed to the TOP side of the motor".
LLigetfa is offline
post #15 of 35 Old 07-18-2009, 06:34 PM
LLigetfa,
Just as a point of information, 4-cylinder Wisconsin engines were splash lubricated with a bypass filter system for years. All the oil pump did was lubricate the governor, spray oil at the rod journals, and the surplus went through the filter and back to the sump. As far as the Courage and Vanguard are concerned, they're not even in the same ballpark, much less in the same game.
rscurtis is offline
