Ss12 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 6 Old 06-26-2009, 03:04 PM Thread Starter
turbojet's Avatar
Ss12
Newbie here,
I have a 67 SS12 with a HH120 Tecumseh and Walbro carb. The only way it runs good is about half choke, so I decided to check her out and it's a vacuum leak at the throttle shaft.
Any ideas on how to correct this? I was thinking about a bushing, but can't think of where I would find something that size. Also, any suggestions on locating a carb kit.
Thanks
turbojet is offline
post #2 of 6 Old 06-26-2009, 03:35 PM
MEMBER
TOMMY's Avatar
Re: Ss12
Welcome to MTF<any good machine shop should be able to machine out the carb and put in a new bushing to fit the shaft.I have one worn and I put some
heavy grease around the base of the shaft,its a tempory fix,but it gets the job done.
TOMMY
TOMMY is offline
post #3 of 6 Old 06-27-2009, 10:47 AM
Re: Ss12
I have bought small flanged brass or bronze bushings at Lowes,they had them in the drawers in the hardware section--they also sell some popular ball bearings numbers that fit wheels and decks in my local store too,and roller chain and master links.. They had bushings as small as 3/16" I.D.,I have used some that were 5/16" O.D. and 1/4" I.D. to re-bush a worn throttle shaft on a carb body once on an old Wisconsin I had that was real sloppy..sometimes you can find brass tubing that will work also,I have used copper tubing as well and peices cut off of brass plumbing fittings too..
I did one carb with J-B Weld,I just spread some in the hole in the carb body and let it dry,then used progressivly larger drill bits to "ream" it to the right size..it seemed to work well and held up to gasoline OK..
Tractor-Holic is offline
post #4 of 6 Old 06-27-2009, 12:16 PM
Re: Ss12
Are you absolutely sure you're on the right track? Just how loose is it? Are you SURE you don't have some dirt plugging up something else in the carb? I've seen some PRETTY darn loose throttle shafts, and about all they affect is VERY low speed idle, something that these girls don't do much of.
440roadrunner is offline
post #5 of 6 Old 06-27-2009, 12:26 PM
Re: Ss12
get a new carb! I just got a new carb about 2 weeks ago and i have a tecumseh hh140 the instructions said the carb was good for the hh120-160 models
-Tim
My tractor garage:
1951 ford 8n, 1952 ford 8n, 1973 ford 2000, 1968 IH cub low boy, 1968 sears ss12, 1977 sears 14/6, 51 wonder boy 450 riding mower
ooticamitica is offline
post #6 of 6 Old 06-28-2009, 05:15 AM
MEMBER
TOMMY's Avatar
Re: Ss12
Where did you buy the carb?I might have to order and get one.
Tommy
TOMMY is offline
