Kohler Pro...Command or Courage - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 12 Old 04-29-2009, 08:44 AM Thread Starter
tpaul's Avatar
I just bought a 2005 DGT 6000 with a 27HP Kohler Pro engine. My question is, is this engine a command or a courage. I will now put the Scotts L2548 up for sale. I should get a decent price, it only has 133 hrs.
Massey Ferguson 2522 2010
Craftsman DGS6500 2008
Craftsman DYS4500 2008
Craftsman LTX1000 2002
Craftsman LT1000 1999
tpaul is offline
post #2 of 12 Old 04-29-2009, 09:00 AM
Certified Technician
RED-85-Z51's Avatar
Images: 7
Re: Kohler Pro...Command or Courage
Kohler makes a Command engine, and a Courage engine.
Then they make a mosre costly Command PRO and Courage PRO with special features like a hardened crank journal, larger air and oil filters, etc..
Then they make an engine for Craftsman, can be a command or courage, and is labeled as a "Kohler PRO".
If the air filter is up on top of the frotn of the engine, and is under a snap down plastic cover, it is a courage.
If the filter is on the front of the engine, and is round, it is the command engine.
These "Kohler PRO" engines are not Command PRO or Courage PRO engines, just marketing from sears.
1993 Wheel Horse 416-H
Onan P216G
1962 WH702
1997 K3500 Dually Sierra
1995 K3500 Silverado
TBI 454
1995 K2500 Silverado
6.5 Detroit Turbo Diesel
1994 GMC Sierra Z71
350 TBI
RED-85-Z51 is offline
post #3 of 12 Old 04-29-2009, 09:26 AM Thread Starter
tpaul's Avatar
Thanks Red...clear as mud ! LOL
tpaul is offline
post #4 of 12 Old 04-29-2009, 08:01 PM
searsman6000's Avatar
You could look your engine model number up on Kohlers web site to be sure. I looked at a Sears today and all of the riders I saw except one had the Courage engines. I put a Command in mine like the one it originally had - Project "Big Red".
The Commands are supposed to be a step up.
searsman6000 is offline
post #5 of 12 Old 04-29-2009, 11:26 PM
tpaul,
I have the same tractor. It says only PRO on the engine, but if you look on the left side of the engine, you can find the model number. Mine has a CV740 which is a Command Pro.
Runningbare
Runningbare is offline
post #6 of 12 Old 04-30-2009, 12:18 AM
I have a 2004 Sears DGT6000. Here is a pic of my breather cover. Actually it is off my old blown engine. It was a CV740-0024. My new engine is a CV740-0018 but it does not come with decals from Kohler factory so I swapped covers. I held camera wrong so had to flip pic so that is why date upside down.
post #7 of 12 Old 04-30-2009, 12:43 AM
RED-85-Z51's Avatar
Images: 7
That's the same decal that's on the GT5K Im looking at...except 25hp.
It's funny it says larger air, oil and fuel filters.
But the fuel filter that comes on these things is the craftsman special..nothing really superior capacitance wise.
The air filter out of a non-pro standard Command fits the housing, same size.
The Oil filter is about 1" taller, but then you can buy that same filter tight next to the standard filter at your local dealer.
Nothing they are advertising there is not something you can put on a "non-pro" Command...
Why they call it "PRO" is beyond me.
The oil filter still needs to be changed with the oil, and if you are plugging up an oil filter in 50 hours, you seriously have major problems.
The air filter seems identical, cant find a dimensional difference. A taller filter wouldnt fit under the cover and let the cover mount right. A larger diameter filter wouldnt fit.
Might be a hair thicker, but it till has to fit the sealing cap, and the lip in the filter back.
Fuel filter, Kohler may supply the engines with a larger filter, but it sure looks like the same fitler that comes on most other Kohler engines...There is a larger capacity filter avaialble, but again...if you are plugging it up so much you need a larger filter, you really need to clean your fuel tank bad.
Onan P216G
1962 WH702
TBI 454
1994 GMC Sierra Z71
350 TBI
post #8 of 12 Old 04-30-2009, 07:55 AM Thread Starter
tpaul's Avatar
Its a Command. I looked it up on the Kohler website. I read here somewhere that some kohler twins had head gasket problems. How can i find out if the tractor i bought has a problem engine? Its the same as Searsman6000.
Searsman6000, what happened that you had to get a new engine? How many hours was on the old engine? I'm concerned I bought a future problem.
tpaul is offline
post #9 of 12 Old 04-30-2009, 08:13 AM Thread Starter
tpaul's Avatar
WOW Searsman6000, i just saw your other post. You had Big Red down to the last nut and bolt. One thing i noticed about mine is that its very loud. The muffler is there but its loud and it seems the tin cover that directs the exhaust to the front is not on properly. Its leaking exhaust out the sides between the screws and sounds really weird. Kind of a tinny sound.
tpaul is offline
post #10 of 12 Old 04-30-2009, 08:02 PM
Bought it with blown engine. Looks like previous dipstick didn't know how to read the oil dipstick. The hour meter had 122 hours on it.
"BIG RED" 2004 Sears DGT6000 27 HP Kohler Command/54" Deck/Fender Lever Control Hydro-Gear 311-3500
"BIG RED" Rebuild Thread - http://www.mytractorforum.com/showthread.php?t=66771
post #11 of 12 Old 03-25-2011, 02:06 PM Thread Starter
tpaul's Avatar
2 year later update. One of the head gaskets blew last year. I changed both using the kits from Kohler. Now it runs like a top. I greased the deck mandrels a few times and they still take grease and none squeezes out?? I made a bracket for the back to mount a 2" ball to move my utility trailer. This tractor is my workhorse. I normally use the others to cut grass. At the end of last fall I purchased another craftsman tractor. Its has a kohler courage twin and a 54" deck with a foot pedal hydro trans. I use that to cut 1.5 acres in PA.
tpaul is offline
post #12 of 12 Old 03-25-2011, 09:46 PM
Tractor hoarder/collector
searstractorfan's Avatar
Images: 5
Tpaul, might be a burnt exhaust valve...ive seen it on 2 25hp horizntal commands, and a 20 horizontal....I deal with the horizontals since we(the family) uses them in tractor pulling....Also the 25 was supposedly plagued with head gasket problems do to the original head studs...Thats what the local mower shop told us...We ALWAYS use the regular bolts(that came from a high performance engine builder of commands) when replacing gaskets as they have more holding power....My uncle has a 25hp command that cranks 10,000rpms and has over 200lbs of compression and uses the STOCK command head bolts..but he dumped the stock gaskets for copper(they are like $42 I think from the aftermarket)
1967 Sears Suburban 10, 1967 Custom 7, 1969 8Xl, (3) 1973 ST/16, (2)1973 SS/16, 1973 ST/10, 1974 SS/16, 1974 ST/16, 1976 ST12, 1977 SS/18, 1977 10/6, 1977 12/6, 1977 14/6, 1978 GT19.9. 1973-75(unknown year) Roper RT16T, 1978 or 79 Roper 18T. Craftsman Mowers: 196? Craftsman 6hp mower, 2 196? craftsman mowers. Various 82 series pullers 1973 IH Cub Low Boy, Cub Cadet 782, IH Cub Cadet 582 Special, IH Cub Cadet 582. 1972 Economy Jim Dandy, 1972 Economy. And an unknown Panzer, theirs more im sure.
searstractorfan is offline
