craftsman won't crank - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 45 Old 10-14-2008, 05:44 PM Thread Starter
Last time I was here, you guys helped me fix my steering. Now I have another problem. My Craftsman will not crank. It is a 6 or 7 year old 18.5 hp craftsman. After I got done mowing the tractor would not start. It seemed like the battery was dead. It gave a slight noise like it wanted to crank. I replaced the battery with a good battery from my other tractor. Same thing happened. Then I out the battery that was from the Sears into the other tractor and it worked fine. Anyone have any ideas? Tractor was running perfect prior to this.
Greg
dgjks6 is offline
post #2 of 45 Old 10-14-2008, 06:07 PM
Slightly Autistic
Bill Kapaun's Avatar
Re: craftsman won't crank
And the Sears 917.xxxxxx number is?
Bill Kapaun is online now
post #3 of 45 Old 10-14-2008, 08:44 PM Thread Starter
sorry - forgot that part
917270821
dgjks6 is offline
post #4 of 45 Old 10-14-2008, 08:54 PM
Junk Collector
tractorkid94's Avatar
Sounds like a key switch or starter solenoid. With the new battery, is there a clicking sound?
tractorkid94 is offline
post #5 of 45 Old 10-14-2008, 10:58 PM Thread Starter
no repetetive clicking sound like a car makes, but a one time light "womp" - and that is it.
Is a solenoid hard to replace?
dgjks6 is offline
post #6 of 45 Old 10-15-2008, 03:06 AM
Slightly Autistic
If you don't have the owners manual, here it is-
http://www.managemyhome.com/mmh/lis_...M/98080210.pdf
Engine is an old Briggs opposed twin (42E707-2631-E1) so we shouldn;t have any valve adjustment issues.
First thing I'd do is remove the spark plugs, ground the plug wires and try to crank it. (You don't want spark if gas comes shooting out)
It sounds like the cylinders may be full of gas from a leaking carb, hydro locking it. IF so, repair carb and change oil
IF that's not it, clean ALL battery/starter solenoid/starter motor cables, including grounds. Make sure engine mounting bolts are snug too.
post #7 of 45 Old 10-15-2008, 02:56 PM
Dangeroustoys56's Avatar
Bill is correct on that- it should turn over w/o the plugs in.
Ive also had a starter gear break on me- it lodged between the starter/ring gear and motor causing it to lock up- check that as well.
-Collecting lawntractors is like eatin tater chips- cant have just one!
-If i listed all my tractors itd be two pages long....
Dangeroustoys56 is offline
post #8 of 45 Old 10-16-2008, 02:28 PM Thread Starter
ok, here is a dumb question. How do you ground the plug wires?
dgjks6 is offline
post #9 of 45 Old 10-16-2008, 03:22 PM
Slightly Autistic
I've made up a pair of wires with small alligator clips on the ends.
You could probably reinsert the spark plug into the boot and then try taping them to the block/head out of the way.
OR ground the ignition kill wire-
The main thing is, you don't want spark near the spark plug hole where gas MIGHT come shooting out.
In general, it's not good practice to force an ignition coil to jump an overly wide gap. IF it can't, the HT spark tries to go to the path of least resistance and that can sometimes cause coils to break down internally.
post #10 of 45 Old 10-17-2008, 04:56 PM Thread Starter
Thank you guys for all of your help. I do appreciate it.
OK - I took out the plugs, taped them to the block and still nothing. Only a small "womp". Went underneath and turned the drive gear pulley and the motor spins freely. What should I do next? Solenoid or starter?
dgjks6 is offline
post #11 of 45 Old 10-17-2008, 10:38 PM
Slightly Autistic
You can try jumping the 2 large studs on the solenoid to bypass it, but I have a hunch the starting motor is bad.
post #12 of 45 Old 10-18-2008, 09:32 AM Thread Starter
would you mind giving me a step by step on how to do that? Jumping the solenoid I mean.
Greg
dgjks6 is offline
post #13 of 45 Old 10-18-2008, 11:59 AM
Slightly Autistic
A jumper cable for jumping car batteries is probably easiest.
Some people will use an old pair of pliers or similar to bridge the two terminals.
Expect the pliers to possibly get hot and be decisive. You;ll get some arcing. The more timid, the more arcing you'll get.
post #14 of 45 Old 10-18-2008, 12:09 PM
Junk Collector
Nah, just use a screwdriver with an insulated handle (like plastic). My Craftsman has a similar problem (mine's wiring related though) an that's the way I start it.
post #15 of 45 Old 10-19-2008, 09:19 PM
MikesRJ's Avatar
Images: 10
That's like saying, "Of course I have the key Officer, it's this long thingy with the Clear, Red, and Blue striped handle!". ROTFLMAO
In GOD we trust!
Mike in S/E-PA
Ability is what you’re capable of doing; Motivation determines what you do; Attitude determines how well you do it; and the measure of who we are is what we do with what we have.
- '58 RJ-58, '61 701, '68 Commando 8, '71 800-Auto, '72 800-Auto, '73 10hp 8-Speed
- 3533-A Cab, 7-2211 Cart, ST-324 Snow Thrower, 7-2513 36" Sweeper, RMR-32 Deck, CBR-32 Blade, AC-6 Cultivator, LR-24 Roller, 77-10DC01 Cart
MikesRJ is offline
