Which engine oil for 24hp Kohler Pro? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 14 Old 06-24-2008, 12:38 PM Thread Starter
I am at the 8 hr oil change interval for my DGS 6500. I can't find my manual and the online manual site is down. I checked Kohler site but I can't find anything on the 24hpo version, just the 25hp which most of the DGS have. However, mine has the 48" deck and the 24hp version. I was just about to head over to Wally world to get some and can't find the info Thanks for any help you can offer.
Model NO. 917.288480
Brett K is offline
post #2 of 14 Old 06-24-2008, 01:07 PM
Proud Father of 2 Girls
Jr88Fan's Avatar
Images: 7
Re: Which engine oil for 24hp Kohler Pro?
Here you go.
http://www.kohlerengines.com/common/...9001_b_508.pdf
Time is Short - King
Jr88Fan is offline
post #3 of 14 Old 06-24-2008, 01:09 PM
Jr88Fan's Avatar
Images: 7
Here is the Service manual also:
http://www.kohlerengines.com/common/.../tp_2574_a.pdf
Jr88Fan is offline
post #4 of 14 Old 06-24-2008, 08:05 PM
Certified Technician
RED-85-Z51's Avatar
Images: 7
Rule of thumb for summer use.
Kohler Command = 10w30
All other engines = SAE30 High Detergent
Winter use- Follow manuals recs for your lowest/average temps.
1993 Wheel Horse 416-H
Onan P216G
1962 WH702
1997 K3500 Dually Sierra
1995 K3500 Silverado
TBI 454
1995 K2500 Silverado
6.5 Detroit Turbo Diesel
1994 GMC Sierra Z71
350 TBI
RED-85-Z51 is offline
post #5 of 14 Old 06-24-2008, 08:40 PM Thread Starter
Thanks for the help. Is the Kohler Pro just a rebadged Kohler Command?
Brett K is offline
post #6 of 14 Old 06-24-2008, 11:43 PM Thread Starter
OK, now I have two conflicting manuals. I was able to open the manual up on Sears website and it says SAE 30. The Kohler manual for the Courage Pro says 10W30. Is the Craftsman Kohler Pro the same as the Kohler Courage Pro? Argh! Not only that it took me two hours of going to different autoparts stores before I could find someone to cross reference the number off the original oil filter. All I could find was a crappy Fram to boot. I hope it is the right one as I am relying on an 18 year old behind the counter. It is a Fram PH7575.
At this point I am afraid to change the oil. I picked up some Castrol Synthetic Blend 10W30 as per the Kohler website assuming my engine is the same as the Kohler Courage Pro. I wish I could find my manual to be sure
Brett K is offline
post #7 of 14 Old 06-25-2008, 12:41 AM
RED-85-Z51's Avatar
Images: 7
Easy cross ref is for the Command engines...Napa part Number 1348, . It's a napa GOLD filter, which is made by WIX, and wix is known for top quality filters.
Now, Fram...I wouldnt put a fram near an engine after one failed on a friends car and blew his new motor up, and a year later one failed on my Vette and nearly ruined a perfectly good engine.
Is your fram filter a PH3614 by chance?
Onan P216G
1962 WH702
TBI 454
1994 GMC Sierra Z71
350 TBI
post #8 of 14 Old 06-25-2008, 12:49 AM
RED-85-Z51's Avatar
Images: 7
You can use a good quality 10w30 in a Courage, but it's crucial it be used in a Command.
Onan P216G
1962 WH702
TBI 454
1994 GMC Sierra Z71
350 TBI
post #9 of 14 Old 06-25-2008, 01:01 AM
CraftHorse's Avatar
Location: Scott Depot West Virginia, Ridgeland South Carolina
I am using NAPA GOLD filter...Dad used to own a NAPA, and NAPA Semi Synthetic 10w30. I have about 13 hours on this filter and oil, and it is still clean as can be.
2006 Craftsman DGS 6500
1988 WheelHorse 211-4 (Re Stored)
1970 WheelHorse Raider 12 (Project)
CraftHorse is offline
post #10 of 14 Old 06-25-2008, 01:02 AM
CraftHorse's Avatar
post #11 of 14 Old 06-25-2008, 01:05 AM
RED-85-Z51's Avatar
Images: 7
i dont beleive craftsman DG models have come with a Courage engine as of yet, as far as I know, they have used only the Command models.
A way to check is to look at the air filter...if it is between the 2 cylinders up top, under a pop off lid, and is about 1.5" thick and uses a wire snap to hold it on...it's a courage.
If it has a square filter cover either up top, or on the front of the motor, that is held on with a knob, or a clasp, and uses a round element...it's a command.
The courage:
The Command
Onan P216G
1962 WH702
TBI 454
1994 GMC Sierra Z71
350 TBI
post #12 of 14 Old 06-25-2008, 07:57 AM
Jr88Fan's Avatar
Images: 7
My Sears manual says SAE30 also. It's wrong. The Kohler needs 10w30 for regular temperatures.
Kohler also recommends that you use dino oil for the first 50 hours before switching to synthetics to allow proper seating of rings.
Jr88Fan is offline
post #13 of 14 Old 07-02-2008, 10:02 AM
Bill Kapaun was kind enough to post this in another thread:
Briggs/Kohler type" 3/4" X 16 threads 8-11 PSI Bypass Gasket 2.734"OD X2 .430"ID 0.226" thick
Wix Purolator Hastings Kohler B&S Baldwin MotorCraft AC Walmart JD
2.3" 57035 NA LF503 2805001 492932 B7165 NA NA? NA ?
2.7" 51056 L35310 LF302 1205001 492056 B1410 NA PF2210 NA AM125424
3.4" 51348 L10241 LF157 5205002 491056 BT223 FL793 PF53 ST3614 AM101207
4.8" 51516 L20195 LF134 NA NA B243 FL400A PFL400A ST3600 ?
I am going to use the larger 4.8" wix on mine
shootist is offline
post #14 of 14 Old 07-02-2008, 02:16 PM
Slightly Autistic
Bill Kapaun's Avatar
The DGS 6500 manuals I have show the Courage engine.
Either go to the Sears site and plug in you tractor number (91728zzzz) and look up the engine, or lift up the hood of your tractor and look.
Command CV-zzz
Courage SV-zzz
Sears? Is using the term "PRO" for both engines.
Bill Kapaun is online now
