Craftsman/AYP to Husqvarna Crossover? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 13 Old 05-09-2008, 11:33 PM Thread Starter
Howdy all,
Newby here, been searching all around the internet, lurked here for a day or so, joined and finally feel the need to post. I posted in the Craftsman Forum since there seems to be more of them around and there where fewer threads in the Husqvarna forum. I recently acquired a 2005 Husqvarna GT 2254, found out through the information here that I have a not so good design on my 22hp Briggs air cleaner assembly, amongst a few other things. Thank you all for the wealth of info here!
Question: Is there a comparable[mechanically], or very similar model Sears or other AYP Garden Tractor to the Husqvarna GT2254? I'm assuming that these things are like cars, sheet metal different, the rest the same, except engine and trans upgrades?, i.e. frame is the same, deck is the same, only two or three trans/engine options. My best guess, going by the pictures and the specs. of the 2004 Craftsman brochure is that it is a GT5000. If it helps, I have the 22hp B&S with the ELS system, dual range six speed manual trans, and the 54" deck, 23"x10.5"x12" rear tires. Mostly looking for maintenance parts, and the ability to order from Sears for the odd broken pieces.The two semi-local Husqvarna dealers seem to want my money even more than I do, and I would like to slow that down. Husqvarna's site isn't very helpful either. My property is a little "bumpy" and I will be using ground engaging implements, disc harrow, box scraper for the driveway, etc. Thanks for any and all help, you all have a really nice site here!
Wayne
WASAJCO is offline
post #2 of 13 Old 05-10-2008, 08:19 AM
Anything With Wheels
Argee's Avatar
Re: Craftsman/AYP to Husqvarna Crossover?
Welcome to MTF WASAJCO...glad you found us.
You're correct....I believe they were modeled after the Craftsman GT's...I have a GT5000 with a 25HP Kohler so it wouldn't be much help. I'm sure we have someone here that has that same spec and could provide you with the serial # for ordering parts.
Someone did a post on a retrofit air cleaner after striking out with B&S for warranty.
Good luck on your quest!
Randy G
Argee is offline
post #3 of 13 Old 05-10-2008, 12:44 PM Thread Starter
Thanks Argee! I am going to check the air cleaner housing regularly, I have a few tricks up my sleeve as well, was self employed for the last few years and had fun fixing zero turns, as well as some walk behinds. Neat stuff. Hope I am able to help folks as well with anything I may have learned over the years. One thing that might help folks, the Toyota specification RTV/silicone sealer is FAR tougher and resilient than the typical RTV/silicon sealer. It's worth looking for the Toyota spec # on the tube. Hylomar, if you can find it is also premium stuff.
Wayne
WASAJCO is offline
post #4 of 13 Old 05-10-2008, 10:57 PM
GG_GT5000's Avatar
Images: 3
WASA,
dont know the exact model you have but do you have a owners manual? If not ... try this one... I hope this is the correct one for your particular tractor - http://weborder.husqvarna.com/order_...5_O0502017.pdf
After looking through some of the owners manuals, it is a dead ringer for a GT5000. In the back of the owners manual, there is a parts diagram and parts list.
Agree said:
here you go - Briggs & Stratton 26hp ELS air filter problem
this thread is where I went ahead and rebuild my engine (26HP ELS725)
My First Rebuild B&S ELS725 26HP V-Twin
If you have the flat panel filter with the clamp down lid, keep a very close eye on dirt ingestion issue. If you the same flat panel filter but with a 2 or 4 bolt hold down lid, it is an improvement but still need to keep an eye on dirt ingestion issue
GG_GT5000 is offline
post #5 of 13 Old 05-12-2008, 11:16 AM Thread Starter
I do have the manual, and after a little more searching looked through a pdf file that had sears, husky and poulan, only poulan had an identical tractor. I suppose I'll be fine with the info that I have, I just wanted to be able to cross reference for belts, especially the ground drive belt, as there's an e-bay seller that has lots of stuff with the AYP number and Husqvarna seems to like to be proprietary in their numbering system, i.e., no AYP crossover when going to the online sellers.
WASAJCO is offline
post #6 of 13 Old 05-12-2008, 11:28 AM
Argee's Avatar
What's the OEM# for the drive belt? I can't imagine there is to much difference between the pulley locations on a Briggs and Kohler.
Randy G
Argee is offline
post #7 of 13 Old 05-12-2008, 10:34 PM Thread Starter
532 13 71-53 for the ground drive belt, and of course no specs as to length, width, etc.
WASAJCO is offline
post #8 of 13 Old 05-12-2008, 11:45 PM
Argee's Avatar
I wonder if that dash 53 specifies the length???
I have an OEM# on my Craftsman of 140218. Do you have a way of cross referencing??
Randy G
Argee is offline
post #9 of 13 Old 05-13-2008, 12:49 AM Thread Starter
No, but I'm going to hopefully find other numbers on the belt so that I can do that. I hate proprietary part numbers.
WASAJCO is offline
post #10 of 13 Old 05-13-2008, 12:52 AM
Slightly Autistic
Bill Kapaun's Avatar
http://www.m-and-d.com/ST-265-073.html
Specs: Application: Drive, Length: 83 1/2" , Width: 1/2" , Type: Covered
Try Google using AYP + your Husky PN. That should bring up a Sears (AYP) # along with your Husky #
Bill Kapaun is offline
post #11 of 13 Old 05-13-2008, 01:20 AM Thread Starter
Very good! It crosses over to a deck belt and it is a ground drive belt as well. Very nice. Saves me a ton of money, the spare will only cost ten bucks plus shipping. Didn't find the sears number though?
WASAJCO is offline
post #12 of 13 Old 05-13-2008, 05:07 AM
Slightly Autistic
The AYP# IS the Sears#
Not sure where you got $10 though.
post #13 of 13 Old 05-13-2008, 03:34 PM Thread Starter
Sorry, not clear, from Sel-lo on E-Bay. really ridiculous prices for some stuff.
WASAJCO is offline
