My tractor won't start - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 318 Old 01-21-2008, 05:16 PM Thread Starter
me
queen of spades's Avatar
Images: 12
Ok I finished putting everything on the tractor this morning and here's what happens when I try to start it:
I removed the plug and it has a big yellow spark. There is lots of compression too, I put my finger over the spark plug hole and the air blew it right back off. There is fresh gas in the carburetor and I even tried starting fluid. I can't get it to even think about firing.
Both valves move up and down that I can see. I made sure to line up the camshaft gear with the mark on the crankshaft gear, per tecumseh manual. Beyond that I am lost.
Any suggestions?
queen of spades is offline
post #2 of 318 Old 01-21-2008, 06:47 PM
My kid @ W.H. gift shop:
Edward's Avatar
Images: 9
Re: My tractor won't start
See/smelling gas out the exahust or in the cylinder when you pulled the plug?
Edward is offline
post #3 of 318 Old 01-21-2008, 06:50 PM
1086's Avatar
Images: 11
If the timing is correct your finger will be blown off the plug hole at the same time you see spark. Well, at least within a mili-second or two.
1086 is offline
post #4 of 318 Old 01-21-2008, 06:53 PM
7000 posts and climbing!!
Dad0850's Avatar
Images: 7
Did you try dribbling a little gas into the cylinder and then trying to start it?
I've always been crazy, but it kept me from going insane.
Waylon Jennings
Dad0850 is offline
post #5 of 318 Old 01-21-2008, 07:41 PM
Just Evil
jed12674's Avatar
Just a thought and maybe I am not hearing it right but did you check the valve lash? It almost sounds like a valve is hanging slightly open. I know you said it has compression, but I would check the valve lash. Even a valve being slightly open all the time may still show compression. Also how about ignition timing, is that all set? Thats an old tecumseh right? does the ignition work off trigger pins on the flywheel? if so is the air gap correct?
Jarrod J.
jed12674 is offline
post #6 of 318 Old 01-21-2008, 07:47 PM
dyt4000's Avatar
Images: 12
Yellow spark sounds like a weak spark...to me.
2001 John Deere 425 w/3 point lift, rear 540 PTO and Heavy Hitch with trash can option
1957 IH Cub Lo-Boy
1967 Wheel Horse 857
Yanmar 2000 with FEL/Rotary Cutter
dyt4000 is offline
post #7 of 318 Old 01-21-2008, 07:56 PM
Ratchet Jaw old Member
drbailey's Avatar
I agree , sounded like it might be sucking air.
drbailey is offline
post #8 of 318 Old 01-21-2008, 08:04 PM
Small Fry's Avatar
I agree with that. and maybe the valves. But for kicks you could try this.
You have a kill wire on the front of the shroud that goes to the mag. A wire from the key switch also hooks to that screw, if thats on. unhook the wire that goes to the key switch but leave the mag wire. Sometime a bad key switch will ground out the mag giving you a weak spark. You can recheck the spark to see if it looks different or just try to start it, your key won't turn it off though, choke it to trun it off.
Small Fry is offline
post #9 of 318 Old 01-21-2008, 09:06 PM Thread Starter
me
Images: 12
What is valve lash? Tecumseh said to line up a little dot on the cam gear with a beveled edge on one of the crank gears. Was there something else I needed to do?
post #10 of 318 Old 01-21-2008, 09:29 PM
Small Fry's Avatar
lash is valve adjustment , is that in your book ?
post #11 of 318 Old 01-21-2008, 10:09 PM
Just Evil
jed12674's Avatar
it is the air gap that is suppose to be between the valve stems and the lifters.
There needs to be a little bit of a gap between them for when the engine heats up everything expands. With out this gap it will hold valves open and you would be without enough compression. It should be in your book, maybe in the maintenence section under valve adjustment.
Jarrod J.
jed12674 is offline
post #12 of 318 Old 01-21-2008, 10:26 PM
Small Fry's Avatar
This model does not have trigger pins. It does have ACR (automatic compression release) and if its working it does hold a valve open, so you will have the sucking sound threw the muffler. There is a pin on the cam that holds the valve up till it starts.
queen of spades
1. Did you ever mess with the valves and if so did you adjust them after ?
2. Your spark is yellow and should be more of a blue color. Still if its getting gas and you get it turning over fast enough it should pop. Never crank it for more then 30 sec's as it could burn out the SSI.
If it was mine I would jump it to get it really wheeling and make sure its getting gas. Also you could try a different plug, some plugs will spark but not good enough.
Did this run before the rebuild ? just to make sure what we have here.
post #13 of 318 Old 01-21-2008, 11:17 PM Thread Starter
me
Images: 12
SF:
1) A machine shop rebuilt the block for me, new piston, turned crank and replaced one of the valves and grinded the other. They are a high-volume shop and I've had work done there before (I trust them). After getting the engine back I did nothing except put the lifters, cam & crank and bolt it all together (after making sure to line up the marks mentioned ealier).
2) I installed a new plug before trying to start it.
It ran fine before the rebuild, except for a loud knocking noise (which the machine shop guys said was the lower rod bearing).
I won't have time to work on it again for a few days because of school & work. I have the battery on a charger now but will try jump starting next.
post #14 of 318 Old 01-21-2008, 11:26 PM
Just Evil
jed12674's Avatar
Did the machine shop have the cam shaft there when they replaced the one valve and reground the other? If not there is your problem, after grinding a valve or replacing one you need to check and reset the valve lash. The reground valve will sit lower in the seat making the stem sit closer( or tight to the lifter giving it no clearance. Also a new valve will more than likely have more material on the end of the stem causing the same thing. This will hold the valves open when they should be closed.
Jarrod J.
jed12674 is offline
post #15 of 318 Old 01-21-2008, 11:29 PM
Dad0850's Avatar
Images: 7
If the shop did not have the cam, lifters and valves in the block, they probably did not set the valve gap.
Waylon Jennings
Dad0850 is offline
