Craftsman LT4000 motor ? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 16 Old 06-22-2013, 05:19 AM Thread Starter
Vintage10's Avatar
The motor turns almost 1 revolution then stops, I can turn it by hand or the starter will turn it to 1 position then stops??? What might be the problem?
Is this Tractor worth spending time on?
Thanks in advance.
Vintage10 is offline
post #2 of 16 Old 06-22-2013, 07:35 AM
Ericjr16's Avatar
Re: Craftsman LT4000 motor ?
Well check from top to bottom on this! We just did this to a Kohler CV12.5. Checked flywheel magnets first, checked PTO area,then worked to taking head off. Mine had a screw in piston area blocking movement! Here is thread of it!
Found another for the herd!!!! :)
Challenge Met
John Deere 180 with two bin bagger
1997 John Deere 345
1971 Bolens 1256 snow caster
1996 Craftsman GT6000 snow blower
1980 Wheel Horse C-85
1967 Sears Suburban SS10
Many more!! changing by the day!!
John 3:16 Psalm 28:7
"Complain and remain, praise and be raised!
Ericjr16 is online now
post #3 of 16 Old 06-22-2013, 09:59 AM
Slightly Autistic
Bill Kapaun's Avatar
IF it's a Briggs OHV engine, adjust the valves using the proper procedure.
Without stating the Sears 917.xxxxxx number or Engine brand, one can only guess which engine you might have.
Illegally Blind
Bill Kapaun is online now
post #4 of 16 Old 06-25-2013, 06:10 AM Thread Starter
Vintage10's Avatar
Sorry about the numbers, The Tractor is a Craftsman II LT 4000 Motor; Briggs& Stratton Model # 422707, Type 1522 01, Code 93054858 Twin 18 HP.
I haven't dug too far into it yet due to available time and so far thanks for the feed back. I hope to start on it soon.
post #5 of 16 Old 06-25-2013, 08:09 AM
Slightly Autistic
That's NOT an OHV engine.
Have you gotten the battery charged & LOAD Tested?
Places like Auto Zone will load test a battery.
Illegally Blind
post #6 of 16 Old 06-25-2013, 12:14 PM
el_simonito's Avatar
I have a Vanguard (Made by B&S) that would rotate in a simular fashion. Found a screw behind the flywheel that destroyed the stator. Be careful when you try and try again to get an engine moving, and things don't change. More often than not, you'll end up making things worse!
See here:
B&S Vanguard for SS16
Life is one long journey, and I'm happy to be along for the ride!
There is a fine line between engineering and rednecking...one I've crossed many times!
SS14 with deck (Gretchen) 917.25610
SS/16 - currently awaiting parts from Canada(Mr. Chicken) 917.25950
Murray 15.5hp riding mower, my wifes machine!(Helga)
el_simonito is offline
post #7 of 16 Old 06-25-2013, 07:58 PM
Ericjr16's Avatar
Ouch el simon! Similar to what happened to the JD we just sold!
Challenge Met
1997 John Deere 345
post #8 of 16 Old 06-25-2013, 09:05 PM
It depends. A few minor things to look for
Thanks in advance.
It depends.
Have you taken out both spark plugs and then tried to whirl it over with the starter? (a badly flooded engine will spew out fuel, or water, or whatever out of the spark plug holes, if it was an hydraulic lock...this test can also catch a perfectly good engine on fire, if you don't ground out the high tension leads before whirling the engine over, so be very careful to do that, ground out the leads)
If you did remove both sparks, and the thing continues to lock, did you try manually turning the engine counter clockwise, to see if it will lock while turning in that direction? (turn it backwards at least 4 revolutions, do not force it manually or otherwise if you feel a heavy drag, as previously stated from other replies on this thread)
Look for starter pinion gear damage, and also inspect the flywheel ring gear for a problem.
Make sure the clutch belt for the driveline & mower deck are disengaged, and not the problem.
Check the engine oil, to see if there is any in it, and if so, is it overfull?
Does the oil from the dipstick smell/appear heavy laden with gasoline or water?
wwxx
wwxx is offline
post #9 of 16 Old 06-25-2013, 09:08 PM
Slightly Autistic
Is the engine physically "locking up", or will only turn one revolution and then repeat?
Illegally Blind
post #10 of 16 Old 07-02-2013, 06:52 AM Thread Starter
Vintage10's Avatar
Thanks WWXX, I'll try those tests and see what I come up with, and Bill thanks for the help so far. The engine will only seem to turn to 1 spot then stop... in either direction. I have to apologize for the slow responses, I'm not getting much time to work on this.
post #11 of 16 Old 07-02-2013, 01:37 PM
you need a good high cranking amps battery for that engine and make sure all cables and connections are good. A poor ground cable connection will cause that.
38racing is offline
post #12 of 16 Old 07-03-2013, 07:53 AM Thread Starter
Vintage10's Avatar
I got time to play with it this morning and the motor defiantly stops in 1 spot whether you turn it CW or CCW. I'll be waiting for the time to tear it down!!!
post #13 of 16 Old 07-05-2013, 12:08 PM Thread Starter
Vintage10's Avatar
Got it running... tore off heads and that freed everything up???? Runs like a champ!!! K now I have a problem getting the belt on. Lowes and Sears couldn't help me with the size cause I didn't have the 9177254860 #. But my local mower shop compared the old belt with a new and sold me a Stens 248-92", and for the life of me I can't get the deck back on??? It is about 1 inch from meeting the the raing bracket holes, if you know what I mean. I don't have a manual so not sure I'm installing deck right. The beld is strung like a guitar string with the lever disengaged and deck lowered and worse with it raised. Please help, I'll be searching for answers. Thanks
post #14 of 16 Old 07-05-2013, 02:54 PM Thread Starter
Vintage10's Avatar
Got it, everything works except1light and that will be fixed at thw swiching of a bulb.
THANKS for the help all, ill be back....soon
Sent from the MTF Free App
post #15 of 16 Old 07-05-2013, 07:37 PM
Ericjr16's Avatar
Glad you got it fixed!
Challenge Met
1997 John Deere 345
