Craftsman LT4000 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 16 Old 09-01-2012, 05:20 PM Thread Starter
Michigan Mower's Avatar
Help Craftsman LT4000
I just got this Craftsman LT4000. The 15.5 OHV Kohler currently doesn't run. The 42 inch deck is in great shape and is newer to the tractor. The previous owner told me the engine had a bad coil and wasn't getting spark. I haven't checked the spark yet because the battery was dead. The frame is also cracked by the front axle. I have a few questions. What year is it? Model number- 917.257660. Serial Number- 052594D. What is it worth running with the deck? Thanks! On to the pictures!
No Lincense plate? No problem, I have a fluorescent orange triangle!
Lambert 666
Michigan Mower is offline
post #2 of 16 Old 09-01-2012, 05:22 PM
Briggs powered Sears.
craftsmanmowerfreak's Avatar
Images: 6
Re: Craftsman LT4000
serial number 05/25/1994
my mowers
1961 701 with hy-2 hydrolics
1967 sears suburban 10
1969 workhorse 700 with a k181s
1970 lawn flite (mtd)
1971 ss14 early model in progress
1971 suburban 14
1972 ss15 (redone suburban 15) 78 cast iron 16hp
1978 39inch sears 3pt tiller 8hp briggs
craftsmanmowerfreak is offline
post #3 of 16 Old 09-01-2012, 05:25 PM Thread Starter
Thanks you! So that's you tell eh! Cool! Thanks again!
Lambert 666
post #4 of 16 Old 09-01-2012, 05:25 PM
Images: 6
also take the blower housing off and take the kill wire off the mag. to make sure thats it is the mag thats out and not a short in the harness
my mowers
1971 suburban 14
post #5 of 16 Old 09-01-2012, 05:31 PM Thread Starter
Ok! Thanks!
Lambert 666
post #6 of 16 Old 09-01-2012, 05:43 PM
Images: 6
what i do if its a short in the tractor thats grounding out the mag is i put a toggle switch on the dash and run new wire to the mag and then ground other sideof toggle switch to the frame. thats just what i do to be a quick fix
my mowers
1971 suburban 14
post #7 of 16 Old 09-01-2012, 09:11 PM Thread Starter
Lambert 666
post #8 of 16 Old 09-01-2012, 11:43 PM Thread Starter
Another one!
Lambert 666
post #9 of 16 Old 09-02-2012, 12:22 AM
Images: 6
nice lt1000
my mowers
1971 suburban 14
post #10 of 16 Old 09-02-2012, 12:57 AM Thread Starter
nice lt1000
It smokes a lot, I am guessing it needs new rings. lol
Lambert 666
post #11 of 16 Old 09-02-2012, 02:02 AM
Images: 6
is it a ohv? could have a blown head gasket. if it is i set the vavles to 5 thousandths on both intake and exhaust.
my mowers
1971 suburban 14
post #12 of 16 Old 09-03-2012, 06:54 PM Thread Starter
Yeah it's OHV. I set the valves to 5 today and it still smokes. Probably the head gasket. What kind of rear end are in the LT1000 Spicer? Or Peerless?
Lambert 666
post #13 of 16 Old 09-03-2012, 09:13 PM
Slightly Autistic
Bill Kapaun's Avatar
Why set them to the minimum on one valve and the maximum on the other, when you can set them both in the middle of their range with the SAME effort?
Do you only own a .005" feeler gauge?
Illegally Blind
Bill Kapaun is online now
post #14 of 16 Old 09-03-2012, 09:41 PM
greenbud21's Avatar
Im pretty sure it is peerless. They are a fun little tractor to mod cause parts are cheap and easy to find.
greenbud21 is offline
post #15 of 16 Old 09-03-2012, 10:08 PM Thread Starter
Thank you!
Lambert 666
