Off-season topic. - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 5 Old 04-11-2012, 03:41 PM Thread Starter
WMass712's Avatar
Off-season topic.
So, now that I'm well on the way to resurecting my Suburban 12 I have a question. Would a newer 2-stage sears snowthrower attachment mount onto it and be able to be powered via the mule drive on the front? The snowthrower ia model # 842 240729 serial # 457451. Suburban is model 917.99420. I know we're comin up on summer, but the way life is it'll be January and the middle of a blizzard before I know it and I'm tired of clearing a 1/4 mile driveway with a walk-behind.
WMass712 is offline
post #2 of 5 Old 04-11-2012, 03:44 PM
Slowly turning green...
lobsterbox's Avatar
Images: 3
Re: Off-season topic.
I'm going to go out on a limb and say likely not, because the newer sears snow blowers mount to the underside of the frame on the 80's Craftsman II GT's. I do know that Haban made an aftermarket snowblower that was compatible with the Sears Suburbans.
My Youtube Channel: lobsterbox20
2000 John Deere 425 w/ 54" Deck, 54" Blade, 50" Tiller, 47" & 46" Snowblowers, Cosy Cab ~400hrs
1992 John Deere 322 w/ 50" & 48" Deck, 46" Snowblower, 42" Tiller, ~1300hrs
1981 Case 646 Loader w/ 44" Deck, 42" Tiller, 3 Point Hitch
1978 Sears SS/19.9 Twin w/ 42" Deck ~350hrs (trailer queen).
1975 Roper RT/16 w/ Tote Box, Sickle Mower & 3PH.
lobsterbox is offline
post #3 of 5 Old 04-11-2012, 06:05 PM
Small Fry's Avatar
I had a newer Craftsman blower on a Suburban, I don't have the model number but it was gray and from the 80's. The blower had a long frame that went under the tractor and mounted to the deck hangers. The pulley was on that frame and was about were your mower pulley would be. I did run it off the mule drive just like a mowing deck.
I still have it in the barn but it's barried. The one I have lined right up, no mods were needed. I put a peice off round stock threw the rear deck hangers. The ears on the blower frame slipped on to that rod, then the frame mounted to the front deck hangers.
It was hard on the belt, but the blower pulleys were pitted from rust when I got it. Im not sure if it was the pitting or the angle of the belt. I gave up because 12 hp was not really enough power for the size of the blower.
Small Fry is offline
post #4 of 5 Old 04-11-2012, 06:30 PM Thread Starter
WMass712's Avatar
Good to know it CAN be done, the power was the next question, I believe this is a 40" or 42" blower which will eat alot of snow, however if I go in 1st gear Low it might just do it
WMass712 is offline
post #5 of 5 Old 04-11-2012, 08:08 PM
mcavvie's Avatar
I've been looking for a two stage blower to adapt also, the ones I looked at were the models that have an idler pulley on the frame, like the MTD models. A belt runs from the idler to the blower and one from it to the engine.
1985 Bolens 1900 Eliminator hydro with hi/lo diff. cab, Cat "0" 3 PT., 60" deck, 54" blade, 46" 2 stage blower, tiller
2003 John Deere 4110 HST/ FEL 4' box blade,4' ripper,5' bush hog, single furrow plow, front quick attach, with 54" blade and 46" blower(bolens)
2005 Bolens(MTD) 17.5 hp 42" deck
42" MTD 8 HP tow behind tiller
1977 Sears 16/6 twin
42" sickle mower
spring tooth harrow
Tote box
42" deck
Komatsu PC18MR-2 Mini
mcavvie is offline
