Briggs Model 326437 Points plunger - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 15 Old 02-18-2012, 08:33 PM Thread Starter
GB in MN's Avatar
Images: 5
Hi All, I am working on the Briggs 16 hp cast iron single 326437 it was running fine was adjusting the carb when suddenly it started running intermittently like the ignition switch was being turned on / off checked the spark and it was cutting in and out removed the points cover and checked the points and found the they were barely opening tried to adjust them now have no spark and have very little plunger movement what could have happened?? Is it possible to remove the plunger without braking it and not having to open the engine?
GB in MN
72 Sears G16 Suburban "S3"
67 Sears Suburban 12 "S1"
48 Earthmaster Model C
60 Sears Suburban DB
66 Sears Suburban 10 "S2"
48 Ford 8N
58 Ford 641
63 Oliver 770
04 Sears GT5000
75 Sears ST 16 S4
75 Sears SB 18 S5
74 Sears SS16 S6
84 Power King 1618
76 Power king 1614
73 Power King 1614
1949 Economy Standard
1984 Simplicity 7790
GB in MN is online now
post #2 of 15 Old 02-18-2012, 09:18 PM
SEARS TRACTOR COLLECTAH
Brad-RT/13's Avatar
Images: 21
Re: Briggs Model 326437 Points plunger
According to my service manual. The engine has to be disassembled to remove the plunger. There is a tappet on the inside end on the plunger that rides on a lobe on the camshaft. Here is a pic I scanned out of my manual. If you need additional diagrams, let me know. I have two giant B&S service manuals. Hope this helped, - Brad
Name:	briggs diagram 3.jpg
1981 Sears FF/18
1979 Sears GT/19.9
1978 Sears GT/19.9
1978 Sears GT/18
1978 Sears GT/18H
1978 Sears GT/16
1977 Sears 18/6
1973 Sears SS/16
1973 Sears SS/16-FEL
1976 Roper 16T
1976 Sears ST/16
1966 Sears Suburban 12
1968 Sears Suburban 12
1969 Sears SS/12
1968 Sears Super 12
1971 Sears Super Hydro-Trac 14
1972 Sears LT/8E
1972 Sears SS/15 x2
1970 Sears Suburban 12
Brad-RT/13 is offline
post #3 of 15 Old 02-18-2012, 09:26 PM Thread Starter
GB in MN's Avatar
Images: 5
Hi 73Searstractor, I was afraid that was the case, any idea why it would stop working, it move in and out but only a very small amount. The engine was running very nice and just like that it stopped working.
GB in MN
48 Ford 8N
58 Ford 641
63 Oliver 770
04 Sears GT5000
75 Sears ST 16 S4
75 Sears SB 18 S5
74 Sears SS16 S6
84 Power King 1618
76 Power king 1614
73 Power King 1614
post #4 of 15 Old 02-18-2012, 09:30 PM
If this has a battery/coil ignition system (which I doubt), you will have to get the points operating correctly. If it has a Briggs magneto, have the flywheel repolarized and convert the engine to Magnetron ignition. No more points and end of your problems.
rscurtis is offline
post #5 of 15 Old 02-18-2012, 09:45 PM
Images: 3
Repolarize the flywheel??
duffer72 is offline
post #6 of 15 Old 02-18-2012, 09:51 PM
Brad-RT/13's Avatar
Images: 21
It is possible that the plunger broke off partially inside. I would try removing the plunger, There isn't much more harm that can be done if its broken inside.
Try pulling it out of the sleeve. If you don't want to tear into the motor, You can convert it to magnatron ignition. B&S made those 30ci and 32ci cast iron engines from 1957 to 1988 (Believe). So you can get an electronic coil. I like points better because when they're adjusted right they have a much stronger spark. How little does the plunger move? All the plunger needs to do is open the point contacts 10 thousandths of an inch. If the points are opening then you need to replace the points and condenser. Sometimes the point surface will burn out and the engine won't run. - Brad
1981 Sears FF/18
1979 Sears GT/19.9
1978 Sears GT/19.9
1978 Sears GT/18
1978 Sears GT/18H
1978 Sears GT/16
1977 Sears 18/6
1973 Sears SS/16
1976 Roper 16T
1976 Sears ST/16
1969 Sears SS/12
1968 Sears Super 12
1972 Sears LT/8E
1972 Sears SS/15 x2
post #7 of 15 Old 02-18-2012, 10:11 PM Thread Starter
GB in MN's Avatar
Images: 5
Hi guys, its a points engine I converted it to battery ignition as the magneto as intermittent, was running great. Per my parts manual this engine per type # and date # can not be converted to magnatron ignition, likewise I like points also believe it produces a better spark. Pulling the engine out of this tractor is a bear the engine oil pan is the front axle bolster and you have to half dissemble the tractor to remove the driveshaft.
Brad do you think if I pulled the plunger out that I could fabricate a longer replacement?
Or you maybe right about them only needing to open a bit maybe I should try a new set of points and a condenser before being too rough on the plunger. I was also wondering if removing the front pulley and the bearing cover if you could get at the plunger?
GB in MN
48 Ford 8N
58 Ford 641
63 Oliver 770
04 Sears GT5000
75 Sears ST 16 S4
75 Sears SB 18 S5
74 Sears SS16 S6
84 Power King 1618
76 Power king 1614
73 Power King 1614
post #8 of 15 Old 02-18-2012, 10:23 PM
Brad-RT/13's Avatar
Images: 21
I would deffinately try the points first! I think a new set is only like $7. And yes, The crank case cover is under the flywheel and must be removed to pull the cam out and access the plunger. - Brad
1981 Sears FF/18
1979 Sears GT/19.9
1978 Sears GT/19.9
1978 Sears GT/18
1978 Sears GT/18H
1978 Sears GT/16
1977 Sears 18/6
1973 Sears SS/16
1976 Roper 16T
1976 Sears ST/16
1969 Sears SS/12
1968 Sears Super 12
1972 Sears LT/8E
1972 Sears SS/15 x2
post #9 of 15 Old 02-19-2012, 01:15 PM
Earlier engine can be converted to Magnetron, but the magnets on the flywheel have to be reversed. If it has the magneto under the blower housing, it can be converted. Last I knew, Briggs will do the repolarization for free if you send them the flywheel.
rscurtis is offline
post #10 of 15 Old 02-19-2012, 02:12 PM
Brad-RT/13's Avatar
Images: 21
I have converted many breaker point B&S engines to magnatron for guys. I have never needed to repolarize the flywheel. Which engines are you talking about?
1981 Sears FF/18
1979 Sears GT/19.9
1978 Sears GT/19.9
1978 Sears GT/18
1978 Sears GT/18H
1978 Sears GT/16
1977 Sears 18/6
1973 Sears SS/16
1976 Roper 16T
1976 Sears ST/16
1969 Sears SS/12
1968 Sears Super 12
1972 Sears LT/8E
1972 Sears SS/15 x2
post #11 of 15 Old 02-19-2012, 03:06 PM
The cast iron block engine's flywheels must be re-polarized to use the magnetron ignition , I put a magnetron on my ss15 for a while and never could get it to run correctly. I though it was the carb. When I went and restored it I put a new set of points and condenser in it and it runs great. I have put magnetrons on aluminum block engines with great results.
Tractors: GT-18 hydro, GT-19.9, SS16 with FEL, 3 SS-16's, SS-15, FF18/w 54in snow plow, 44in deck
Attachments: Generator, 8hp rotospader, sickle bar mower, 4 manual 3pt hitches, 1 electric 3pt, 2 46in snowplows, 2 46in snow blowers, 2 disks, 8in plow, 10in plow, 2 cultivators, 1 spike tooth harrow, 2 48in decks, 7 42in decks
SS_Skippy is offline
post #12 of 15 Old 02-19-2012, 03:15 PM
Collector of many tractors
Kbeitz's Avatar
I just drill them out and push in a new one...
Kbeitz is offline
post #13 of 15 Old 02-19-2012, 04:00 PM
Brad-RT/13's Avatar
Images: 21
Ah ok, I've never tried to convert a cast iron engine. There's really no point because the points are so easy to access. I have converted tons of aluminum engines as well with no problems. - Brad
1981 Sears FF/18
1979 Sears GT/19.9
1978 Sears GT/19.9
1978 Sears GT/18
1978 Sears GT/18H
1978 Sears GT/16
1977 Sears 18/6
1973 Sears SS/16
1976 Roper 16T
1976 Sears ST/16
1969 Sears SS/12
1968 Sears Super 12
1972 Sears LT/8E
1972 Sears SS/15 x2
post #14 of 15 Old 02-19-2012, 07:08 PM
You are correct, the points are easy to access. But once you switch to the Magnetron, you have a maintenance-free ignition system that is impervious to moisture.
rscurtis is offline
post #15 of 15 Old 02-20-2012, 02:04 PM Thread Starter
GB in MN's Avatar
Images: 5
Good Morning all, good news the Briggs is running again, I want to thank all you for the help and suggestions, turns out it was not the plunger or the points nor the condenser, not the spark plug wire but the darn coil I suspected it right away on Saturday and tried another coil with no results so I got off and all the other things. Anyway this morning after being well rested I checked things again and sure enough the coil was bad as was the 2nd one I had tried the 3 rd one was the charm had good spark and the engine started up and runs nice. Both bad coils are now in the trash can and its a matter of tiding things up. Thanks again guys.
GB in MN
48 Ford 8N
58 Ford 641
63 Oliver 770
04 Sears GT5000
75 Sears ST 16 S4
75 Sears SB 18 S5
74 Sears SS16 S6
84 Power King 1618
76 Power king 1614
73 Power King 1614
