Starter spins, not engaging flywheel - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 11 Old 07-04-2011, 02:58 AM Thread Starter
jimk403's Avatar
Images: 3
My neighbor has a GT5000 with a Briggs 24hp ELS, the year is unknown, but it is one with the flawed aircleaner design.
The starter spins but does not engage the flywheel. I told her I would look into it, but our schedules are so mixed up I can't really troubleshoot it, so here I am.
Is this starter rebuildable or does she need to buy the whole thing?
Just my opinion, yours will differ.
1999 Craftsman GT
Bolens HT-20
jimk403 is offline
post #2 of 11 Old 07-04-2011, 06:28 AM
BushBoneYard's Avatar
Images: 12
Re: Starter spins, not engaging flywheel
My guess would be the bendix gear is stripped. On my opposed twin it was about a 60 minute repair and cost about $5. I honestly don't know how similar or different the set up on her engine will be. More help will be along. This thread of mine may help though.....
Is this starter toast?........
BushBoneYard is offline
post #3 of 11 Old 07-04-2011, 06:29 AM
JeffinIA's Avatar
Sounds like it just needs a new gear and spring, Very fixable IMO
John Deere 445/60"mmm
John Deere 855 w/woods LS72 Loader,
and 72"mmm
Simplicity 4213
Simplicity 4211
1965 Farmall 706
1958 Farmall 560 gas
JeffinIA is offline
post #4 of 11 Old 07-04-2011, 06:51 AM
Ralphst16's Avatar
Your neighbor could try tapping the starter and see what happens if that hasn't already been attempted.
1973 Sears ST16 (48" mower deck, front plow, snowblower, litter whisk, broadcast spreader, manual 3 pt hitch, penn line dump trailer)
1964 Bolens Husky 900 (38" mower deck, front plow, home made dump trailer)
1969 International Scout 800a
Ralphst16 is offline
post #5 of 11 Old 07-04-2011, 06:58 AM
Loving Life :-)
marlboro180's Avatar
Yep, I'd check to see if the Bendix is stuck before presuming anything. Tapping on the starter gently while turning it over is a good idea^^^. Keep your eyes on moving parts though.
Case 222, 448 ,648 LBH ,, Craftsman 11-36, DLT 3000, Ransomes Motor 180 x 2 :-) Gilson RE-11, Plymouth Gilson something,?and some Hondas and other stuff- the e c l e c ti c gang LOL "Got Solar?"
Help save the DLandreth Seed Company
http://hereandnow.wbur.org/2012/05/0...d-horticulture
marlboro180 is offline
post #6 of 11 Old 07-04-2011, 07:43 AM
also check to see if they change the batt and put the terms on the wrong sides, that will make it spin backwards,, tom
declid is offline
post #7 of 11 Old 07-04-2011, 12:06 PM
The starter drive on my Yard-Man 's Kohler Magnum has been sticking since I got it way back in the 90's!...I have to spray it with Wd-40 or something similar to get the drive to engauge the flywheel often,I think the shaft rusts up that is slides on in a matter of days..so far I haven't had to replace it ...I used the "straw" on the spray can nozzle to lube it by squirting it at the starter drive thru the screen over the flywheel..if I dont spray it I can sit there trying to start it until the battery dies,without the starter gear ever touching the flywheel--one squirt and it'll kick right in!...
Tractor-Holic is offline
post #8 of 11 Old 07-04-2011, 12:19 PM
Leave the hammer in the tool box. Taping the side of the starter may result in the internal magnet breaking into smaller pieces which will jamb the starter which then will need disassembly.
If the starter gears won't engage the flywheel, does the starter's geared surface slide on the starter's shaft? Remove any old lubricant and residue, then re-lube it up, using just abit of lube. Slide the gear up and down by hand.
Mke sure the starter's mounting bolts are tight.
Have a real good charge in the battery.
Tighten the large 'hi-current' posts on the solenoid.
Clean and tighten the positive and the ground lead frame attachment points, as well as on the actual battery.
Starter gear replacement is simple, but time consuming. The pin at the top is a bear, and the springs fly most anyplace. All it takes is some patience.
engine2quarters is offline
post #9 of 11 Old 07-04-2011, 01:21 PM
Collector of many tractors
Kbeitz's Avatar
If the battery is low the starter cant get up to speed fast enought to kick out the gear...
Kbeitz is offline
post #10 of 11 Old 07-04-2011, 05:41 PM Thread Starter
jimk403's Avatar
Images: 3
Thanks, all. Now at least we have some ideas where to start.
1999 Craftsman GT
Bolens HT-20
jimk403 is offline
post #11 of 11 Old 07-05-2011, 12:44 PM
Kbeitz is right--when I jump my Yard-Man with a strong car battery it almost never refuses to engauge the flywheel,but try starting it with a weak battery and all it'll do is spin the starter ,but NOT the engine!...I replaced the starter solenoid last year and that helped a lot,it eliminated the "wont grab" problem until the battery started dying of old age!..
