Homemade Suburban mid mount grader blade - Page 3 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #31 of 173 Old 05-01-2011, 11:02 PM Thread Starter
VWJake's Avatar
Re: Homemade Suburban mid mount grader blade
Expenses so far are only about $5 for blades/cut off wheels. As for time I'm at about 12hrs now. Not having plans to work from and using scrap steel on hand means I'm staring at things quite a bit with no work being done.
'74 Sears SS/16- Smokey (drowned in the flood of '93 in St.Louis and still running) w/ Sears F.E.L.
'73 Sears ST/12- Oliver the Original - The tractor that started it all (my dad's first sears)
'66 Sears Custom 6- Roberta
'55 International Harvester R-122 pickup- Trusty Rusty
'64 Porsche 356 C- Little Red
2 '69 BMW 2002s
VWJake is offline
post #32 of 173 Old 05-02-2011, 02:05 AM
GrandPa
K108Cub's Avatar
Images: 10
Looking good, Jake. I will keep this thread for future reference.
KennyP
Proud Member of the 800 Posts Club
U.S. Army, RVN, 1968-1969
5th Battalion, 16th Artillery, Battery C
1971 Cub Cadet 108
1977 Ford LGT 165
1981 Craftsman GTV/16
198? Craftsman II
K108Cub is offline
post #33 of 173 Old 05-02-2011, 03:00 AM
Member: Special K Club
stripmine's Avatar
Images: 5
Originally Posted by eveled View Post
On my mid mount blade I can push down with my feet on either side to take a bigger bite of the material. Ed
I use my buddy's Mid Mount grader to dress up the tire ruts in his gravel towing lot. with the weight of the trucks packing it down, the grader just bounces across the surface.
I just put the tractor in first high, then put my feet on the blade.. there have been a few times, when i was standing on the blade to break it up.
you have to be careful when the blade is angled, because the rear tires keep trying to grab your boot.
kids.. don't try this at home LOL
dave
stripmine is offline
post #34 of 173 Old 05-02-2011, 10:51 AM
Cranky Motorsports
GT_80's Avatar
Images: 32
Looking good! That design is almost the same as the factory one, except the factory one had something more like 3" diameter pipe, but a trailer jack should be strong enough to take some abuse
MTF Addict #35886
Hugh-SS/16 fan #0001
I love Onans, Tecumsehs, and diesels!
1967 Suburban 12 "The 679"-Yanmar L70 Diesel swap
1967 Suburban 10 - soon to be trike with tecumseh again
1967 Super 12 - nice original
1968 Super12 "Miss Emma Lee"
1968 Super 12 "C&B Special"
1970 Suburban 12
1971 SS14
1973 SS16/ 18/6 Diesel hybrid "D10S"
1974 SS16 - rescued
1976 SS18 "Trusty"
1978 GT18 with Hard cab
Attachments: lots
My YouTube
My Ebay
Sears Manuals
GT_80 is offline
post #35 of 173 Old 05-02-2011, 01:24 PM Thread Starter
VWJake's Avatar
Thanks folks. It's basically a copy of the original sears blade with modifications as needed based on materials on hand / perceived design improvements.
Here's what I accomplished today:
I cut the other rib and welded both to the blade frame.
I ground off the pivot frame on the jack and welded it to the "C" frame. I welded it in "quarters" on both sides to ensure the two pieces are as "stuck together" as I can make them.
The angled braces for the spine tube are cut and fitted. The angle is 1/8" so I think I'm going to weld a plate across them tying into the C frame as well. I don't want that thin agle to twist if the edge of the blade grabs something.
2 '69 BMW 2002s
VWJake is offline
post #36 of 173 Old 05-03-2011, 12:24 AM
Cranky Motorsports
GT_80's Avatar
Images: 32
Coming along fast! Can't wait to see it done!
MTF Addict #35886
1970 Suburban 12
1971 SS14
1974 SS16 - rescued
1976 SS18 "Trusty"
Attachments: lots
My YouTube
My Ebay
Sears Manuals
GT_80 is offline
post #37 of 173 Old 05-03-2011, 12:46 AM
Small Fry's Avatar
Your going right along.
Small Fry is offline
post #38 of 173 Old 05-03-2011, 01:30 AM
GrandPa
K108Cub's Avatar
Images: 10
Thanks for posting pics as you go. Helps to understand what you have done.
KennyP
1971 Cub Cadet 108
1977 Ford LGT 165
198? Craftsman II
K108Cub is offline
post #39 of 173 Old 05-03-2011, 01:50 PM Thread Starter
VWJake's Avatar
My pleasure. I'm happy you guys are enjoying this. Rest assured I'll keep posting pics as I move on with this.
2 '69 BMW 2002s
VWJake is offline
post #40 of 173 Old 05-04-2011, 02:10 PM Thread Starter
VWJake's Avatar
Not much to report today.
I tacked the angle irons to the C-frame/spine tube.
I've got the blade pivots all worked out. The top plate is 1/4" material. I made it 20-1/2" wide to spread the load better across the blade. It'll get bolted to the blade with 7/16" hardware. The outer 2 holes are the original holes that the blade angle arc bar bolted to. I'll trim the excess from the trailing edge of the top plate tonight. The lower pivot is a chunk of 1/4" angle iron. I'll weld it to the ribs for added strength. I trimmed about 3/8" off of the pivot end of the tube so I could move the pivot point closer to the blade. I'll probably weld in a sleeve for that pivot to add strength.
I hope to have the brackets attached to the blade and blade skinned this weekend. Once that's done I'll start sorting out the blade angle system. It'll probably mimic the original. I am temped to use a turnbuckle though
2 '69 BMW 2002s
VWJake is offline
post #41 of 173 Old 05-04-2011, 05:26 PM
Cranky Motorsports
GT_80's Avatar
Images: 32
wow! I like it!!
Now I think you got me wanting to make one... It will be pretty simple, mount to the two front mower mounts, have a pivot on top of the blade, and a simple (hopefully) lift system utilizing the back mower deck mount. no end to end tilt though... I don't really think I would need it.
MTF Addict #35886
1970 Suburban 12
1971 SS14
1974 SS16 - rescued
1976 SS18 "Trusty"
Attachments: lots
My YouTube
My Ebay
Sears Manuals
GT_80 is offline
post #42 of 173 Old 05-04-2011, 05:37 PM
Slow Crawler's Avatar
Looking GOOD , I like it.
66 Suburban 10
73 ST/10 For parts
73 ST/12 Frankinburban
77 Sears 16/6 twin
88 Craftsman III Sold
84,86 Murray 18/42 gt mowing tractors Sold the 86
85 Murray 18/42 The Slow Crawler
96 Craftsman 917.251560, 22.5 Hp 50" cut
03 Huskee, MTD 18.5/ 42
Slow Crawler is offline
post #43 of 173 Old 05-04-2011, 08:27 PM
Small Fry's Avatar
Your having way to much fun for one guy. Looks good !
post #44 of 173 Old 05-04-2011, 09:37 PM
Man, that's a good design. I like that it's a pull design. Can't wait to see this thing done, but the progress pics are just as good too me. Looks like a lot of fun too.
74 Roper Hydro with Onan twin 24HP in the works
74 ST/16 Suburban
Front and rear blades, plow, harrow, front bucket
www.youtube.com/Fastdirt505
Fastdirt is offline
post #45 of 173 Old 05-04-2011, 09:40 PM
Cable70's Avatar
Great work Jake, Your hired!!!!!!!!
'68 Custom7(Was Gramp's Since New); '67 Suburban10; '72 SS15; '06 Snapper Hi-Vac RER; '07 Snapper Snowthower; '88 Snapper LT12; '96 Snapper Walk-behind
Cable70 is offline
