ss/15 transmission - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 34 Old 03-21-2011, 06:07 PM Thread Starter
That_Guy's Avatar
ss/15 transmission
Hi MTF users, this may just b a simple task but its my first time doing it so i feel i shold ask first. how would i drain the transmission fluid out of my 1971 ss/15? thank you in advance.
-That Guy
That_Guy is offline
post #2 of 34 Old 03-21-2011, 06:13 PM
Cranky Motorsports
GT_80's Avatar
Images: 32
Re: ss/15 transmission
there is a drain plug in the bottom of the trans- has a square head on it. Then re-install that once it's done draining, and take the left rear wheel off, there is an elbow under the fender, pull the plug out of that, and pour 5 qts of 30w non detergent in there. It will take a while
MTF Addict #35886
Hugh-SS/16 fan #0001
I love Onans, Tecumsehs, and diesels!
1967 Suburban 12 "The 679"-Yanmar L70 Diesel swap
1967 Suburban 10 - soon to be trike with tecumseh again
1967 Super 12 - nice original
1968 Super12 "Miss Emma Lee"
1968 Super 12 "C&B Special"
1970 Suburban 12
1971 SS14
1973 SS16/ 18/6 Diesel hybrid "D10S"
1974 SS16 - rescued
1976 SS18 "Trusty"
1978 GT18 with Hard cab
Attachments: lots
My YouTube
My Ebay
Sears Manuals
GT_80 is offline
post #3 of 34 Old 03-21-2011, 06:38 PM Thread Starter
That_Guy's Avatar
ok, thank you james, sounds fun, but now that u say what type of oil i need, i told the guy at napa i needed 20wt but he sold me some other type of transmission oil, i think i might need to return it....
That_Guy is offline
post #4 of 34 Old 03-21-2011, 06:41 PM
Slow Crawler's Avatar
30 non detergent motor oil
66 Suburban 10
73 ST/10 For parts
73 ST/12 Frankinburban
77 Sears 16/6 twin
88 Craftsman III Sold
84,86 Murray 18/42 gt mowing tractors Sold the 86
85 Murray 18/42 The Slow Crawler
96 Craftsman 917.251560, 22.5 Hp 50" cut
03 Huskee, MTD 18.5/ 42
Slow Crawler is offline
post #5 of 34 Old 03-21-2011, 06:52 PM Thread Starter
That_Guy's Avatar
so 30 non detergent motor oil for the motor or transaxle?
That_Guy is offline
post #6 of 34 Old 03-21-2011, 10:30 PM
crashman's Avatar
You need 30 wt for both, the engin takes 4- pint and the trans takes 5- qt.
crashman is offline
post #7 of 34 Old 03-22-2011, 12:07 PM
Jeff Kattera's Avatar
ive used lucas gear oil in all my rearends and nothings gone wrong? why the motor oil in the transaxle? and ive worked my transmissions at pulling events getting firewood plowing and nothings gone wrong. and the easiest way ive found is to take the whole elbow off and get the quarts with the "funnel type tip" and just queeze the bottle to force it in the rearend. i usually get done in like 5 mins. if you try the funnel way it will take hours and thats not fun. also lift up the left side so after the 5 quarts are in it wont drip or anything so theres no mess.
I love 80-90s GM Muscle Cars and 60-70s Sears Garden Tractors.
List of Toys
01 Mitsubishi Eclipse RS
83 Monte Carlo SS stock 305ho
07 Kawasaki Ninja 500R
Jeff Kattera is offline
post #8 of 34 Old 03-22-2011, 12:19 PM
I feel gears should get gear oil too,and my SS-12 already had gear oil in it from whoever else had it before me,so I just top it off with more when it needs any--it leaks a bit from the axles and gear oil oozes out a lot slower!..I see no reason to drain it and go back to oil,if any damage was to be had from using gear oil,its too late now!--and that tranny shifts better and ir quieter than my other 2 Suburbans,that have 30W motor oil in them..
Though motor oil is used even in some truck transfer cases,I doubt it protects as well as gear oil,with it having the "EP" (Extreme Pressure) charecteristics needed for spiral cut hypoid gears in car diffs..some say using thicker gear oil will cause excessive wear due to it failing to flow well enough and reach some bearings,or the drive chain in a transfer case,but you cant prove it by me--most of the trucks I had with a full time NP-203 case had gear oil put in by some cluelless "lube tech",but I never had any of them fail or show any other signs of distress from using it..
I cant see how standard trannys and some transfer cases last ,only having ATF for the lube--seems way too thin and not "slippery" enough to me,to let one last,butsomehow they do....
I'm not recomending you disobey the manual's specs for using 30W motor oil in the tranny--but I think gear oil wont hurt one ,personally..might even prolong its life...wont hurt to add some Lucas to the motor oil--I've added some STP Gear Lube Treatment to one tractor I had and it made it shift easier and whine a lot less..
Tractor-Holic is offline
post #9 of 34 Old 03-22-2011, 12:47 PM
yeah i was going to say that but forgot when i first got my st/12 it whined some but now doesnt at all with the gear oil. and i would think the thicker would be better cause it would climb the gears a lot more and get more to where its needed instead of slipping off. they have a thing at advance autoparts "where I work" that one side is oil and one side is lucas gear oil and the lucas covers the gears in lube and the oil doesnt do it as well very cool representation of the two different lubes.
List of Toys
post #10 of 34 Old 03-22-2011, 12:54 PM
30 sae non detergent is what the service manual calls for. I do agree with Jeff, & tractor-Holic that you would think it would take gear oil. But the book says different.
Floyd
66 Suburban 10
73 ST/10 For parts
77 Sears 16/6 twin
post #11 of 34 Old 03-22-2011, 04:26 PM Thread Starter
That_Guy's Avatar
ok, well thank you all, some guy at school was telling me i could use gear oil to, but Hugh-ss/16 told me to use the 30 wt motor oil. i guess i'll use whichever i find first at the store or does anyone know which is better? it sounds liek they both do the same job but just that some people like one better than the other. thank you
-That Guy
That_Guy is offline
post #12 of 34 Old 03-22-2011, 10:06 PM
ss12's Avatar
this mod helps too, the fill extenstion on the left side of the hitch plate, especially if the axle seals leak. mine are all running 30wt
our house is protected by the good lord and a gun, you might meet em both if you come unwelcomed
ss12 is offline
post #13 of 34 Old 03-22-2011, 11:15 PM
7000 posts and climbing!
Plowthesidewalk's Avatar
From what I understand, you need to use SAE 30 in the engine and SAE 30 Non-Detergent in the transaxle. The non-detergent oil is typically used for wiping stuff down with oil, gears, and oil can type oiling. My manual for my ST16 says to use SAE 30 Non-Detergent MM or MS oil in the transaxle. Sears.com has a case of Master Mechanic brand for about $50 plus shipping.
Plowthesidewalk is offline
post #14 of 34 Old 03-23-2011, 12:28 PM
I can get 30W non-detergent for 1.99 a qt. at "Benny's" store nearby....it says on the can "NOT for use in any vehicle made after 1932"--its a straight mineral oil,probably fine for oiling hinges and maybe our Suburban trannys--but I feel gear oil protects a lot better..it certainly wont hurt to add a qt. of gear oil or a additive like Lucas or similar gear treatments to the 30W oil ,in any case..
I've seen those counter displays that show how two gears running in a pool of regular oil VS the ones with Lucas behave,it is evident the Lucas "climbs" up the gears when regular oil sits at the bottom mostly...BTW--Lucas used to be sold under the brand name "Hi-Tach" ,I remember seeing that plastic counter display being labeled as "Hi-Tach" oil additive...
Just about ANY oil is better than whats in most of our old tractors--every one I've bought and drained out had either hardly any oil IN them (like 1-2 qts instead of 5!)--and most had oil that looked like old mayonaise it was so full of condensation,and posessed very little "lubrication"...how the gears inside look I dont know,I'm afraid to look,I wouldn't doubt there is some rusty bearings and shafts in them all...surprises me how they held up for 40 years with only that swill in them for "lube"!...
post #15 of 34 Old 03-23-2011, 12:40 PM
I heard that, mine was milky as heck. I used Penzoil to put back in it.
Floyd
66 Suburban 10
73 ST/10 For parts
77 Sears 16/6 twin
