flywheel magnet..can it go bad?..get too weak to make the spark?? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 5 Old 03-09-2011, 12:59 PM Thread Starter
I have a question for you guys....I have a tiller with no spark...(I talked about it in another post)...but I am curious...can the flywheel magnet go bad?...I realize it could crack ...or get physically damaged...but assuming its intact...can it over a period of years grow weak??...and no longer produce spark??...
ericwest is offline
post #2 of 5 Old 03-09-2011, 03:43 PM
Senior MTF Poster
Re: flywheel magnet..can it go bad?..get too weak to make the spark??
I have seen warnings from B&S to not hit the flywheel hard with a hammer or it might result in magnets losing their strength but I have never run across it actually happening.
You should be able to check the pull against a known good magnet. I didn't read your other post but are you sure the condenser & points are good? Condenser being the most likely culprit.
Walt Conner
Walt 2002 is offline
post #3 of 5 Old 03-09-2011, 03:48 PM
Slow Crawler's Avatar
I have never see one go bad. But I have seen the magnet fly off the fly wheel.
Floyd
66 Suburban 10
73 ST/10 For parts
73 ST/12 Frankinburban
77 Sears 16/6 twin
88 Craftsman III Sold
84,86 Murray 18/42 gt mowing tractors Sold the 86
85 Murray 18/42 The Slow Crawler
96 Craftsman 917.251560, 22.5 Hp 50" cut
03 Huskee, MTD 18.5/ 42
Slow Crawler is offline
post #4 of 5 Old 03-09-2011, 06:03 PM
Sears/Craftsman Owner
DIRT Dog's Avatar
Images: 20
The magnet is not a real permenant magnet.They will go bad if broken or chipped.If it holds a scredriver good then it's probably ok.Check the pick up gap and see if it's tolerances.Might be a bad pic up coil do you know if there is any resistance on the coil?
77 18/6 twin,electric 3 point hitch,disc harrow ,cultivator,10" mold board plow,draw bar,Sears box blade,& sickle bar (Haban).
97 Craftsman GT 50",Craftsman front scoop,48"dozer blade.
79 GT18(parts doner),42"deck,2 manual 3 point
hitches.
74 ST-16,42"deck
DIRT Dog is offline
post #5 of 5 Old 03-09-2011, 07:34 PM
Collector of many tractors
Kbeitz's Avatar
I got a kohler engine that wont spark...
If I put the coil in my coil tester it sparks but not in my engine.
Gotta be the magnet...
Kbeitz is offline
