1970 Sears Suburban ignition questions - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 14 Old 02-04-2011, 10:54 AM Thread Starter
TominCT's Avatar
Electrical noob questions:
My ignition has crapped out on both of my 1970 SS-12s. While I was at Lowes I came across a ignition set with key for $9 and bought it on a whim. As I know very little about the electrical's on the SS12 I have a few questions:
Can I use this ignition for the SS12. The original ignition I recall is a 4 prong and the one I bought is a 5 prong. Part number:OEM 725-0267A
If so, does anyone know what wire goes where?
If not any recommendations for which part# I will need to buy?
TIA
Regards,
Tom
1970 Sears Suburban SS12 (x3)
Disk Harrow
Rear Plow
Snow Plow
Mower Deck
Snow Blower
Cart
TominCT is offline
post #2 of 14 Old 02-04-2011, 11:09 AM
Small Fry's Avatar
Re: 1970 Sears Suburban ignition questions
This is the right replacement switch if you can find the one on the tractor now.
http://sears.pammar.net/switch.pdf
Small Fry is offline
post #3 of 14 Old 02-04-2011, 04:32 PM
Slightly Autistic
Bill Kapaun's Avatar
EVEN IF the switches have the same # of terminals, they can be wired VERY differently internally!
For example, if a switch was designed for an engine with coil/points type ignition, substituting a switch for a later engine is going to fry some wiring.
Illegally Blind
Bill Kapaun is online now
post #4 of 14 Old 02-04-2011, 05:12 PM Thread Starter
TominCT's Avatar
Thanks for the help guys. Small fry the diagram you mentioned is perfect. I did also find a possible replacement on Ebay:
31-2942 - Roper/Sears 365401R Ignition Switch
Replaces Roper/Sears 365401R. Also replaces switch 74R, 2210R, 5797H, 7486H, 9541H, 21037, 71577, 72841 and 511404.
Replaces OEM #: 365401R
Price $14.30
Is the 365401R ok to use instead of 365401?
TIA
Tom
Disk Harrow
Rear Plow
Snow Plow
Mower Deck
Snow Blower
Cart
TominCT is offline
post #5 of 14 Old 02-04-2011, 06:03 PM
Small Fry's Avatar
I know the switch I listed does not have the 2 big post. It gives you some connectors to make it work.
The one you found looks like it does have the 2 big post. Maybe that's what the R means ? I think your tractor take's a 7486H witch is on that list. Going by what they are saying it will work.
You do have a Starter/Gen on that right ? These switches are for the starter/gen tractors.
post #6 of 14 Old 02-04-2011, 07:10 PM Thread Starter
TominCT's Avatar
Thank you again SF as your input is always appreciated. Both tractors have the starter/gen. After 41 years with probably both tractors being constantly started and turning off the motor with the original ignition switches, I decided to go with new replacements. The diagram you posted is a huge asset too.
Kind Regards,
Tom
Disk Harrow
Rear Plow
Snow Plow
Mower Deck
Snow Blower
Cart
TominCT is offline
post #7 of 14 Old 02-14-2011, 05:24 PM Thread Starter
TominCT's Avatar
Hooked up the new ignition switch (31-2942 - Roper/Sears 365401R Ignition Switch) and she starts when I hold the key on start but the moment I let go of the key it shuts off immediately. What would cause this? I'm thinking maybe a bad ground but would like thoughts before digging deeper.
Regards,
Tom
Disk Harrow
Rear Plow
Snow Plow
Mower Deck
Snow Blower
Cart
TominCT is offline
post #8 of 14 Old 02-14-2011, 05:44 PM
Small Fry's Avatar
I would have to ask, Are you sure it's hooked up right ? Why did you replace the switch to begin with ? Does your new switch look like the old switch,with the 2 big post ?
post #9 of 14 Old 02-14-2011, 06:59 PM Thread Starter
TominCT's Avatar
Thanks SF for the quick response. I'll take a pic of the hookup with new ignition and post tomorrow. I think I did it correctly as I have 2 of the same tractors and used the other one as reference.
Regards,
Tom
Disk Harrow
Rear Plow
Snow Plow
Mower Deck
Snow Blower
Cart
TominCT is offline
post #10 of 14 Old 02-14-2011, 09:41 PM
Small Fry's Avatar
Sounds like either those switches won't work like the seller said they would, or you have a wire mixed up.
The M terminal is the kill wire. That wire goes to the lower front corner of the engine shroud. There is a little screw it hooks to. Make sure you have that M wire right on the switch.
You have to becareful you don't get them mixed up or you could burn up the solid state unit. $$$
ss12 wiring
post #11 of 14 Old 02-23-2011, 11:45 AM Thread Starter
TominCT's Avatar
The ignition works perfect now. I rechecked the wires I originally connected and noticed that I indeed had installed them on the wrong prongs.
I bought the new ignition on Ebay for $14.95 + shipping if anyone is looking to replace their broken ignition switch. Ebay search 2942-365401R and you should find it.
Thanks again for the help.
Regards,
Tom
Disk Harrow
Rear Plow
Snow Plow
Mower Deck
Snow Blower
Cart
TominCT is offline
post #12 of 14 Old 02-23-2011, 01:09 PM
Cranky Motorsports
GT_80's Avatar
Images: 32
Bravo! I love fixing wiring issues!
MTF Addict #35886
Hugh-SS/16 fan #0001
1966 Suburban 12 parts build - for sale soon
1967 Suburban 12 "The 679"-Yanmar L70 Diesel
1967 Suburban 10 Super 12 Special clone
1967 Super 12 "Christine"
1968 Super12 "Miss Emma Lee" Launtop 178F Diesel
1968 Super 12 "C&B Special"
1970 Suburban 12 Trike Build
1970 Suburban 12 2
1973 SS16 / Roper Diesel "D10S"
1974 SS16 rescued
1976 SS18 "Trusty"
1978 GT18 with Hard cab
My YouTube
My Ebay
Sears Manuals
GT_80 is offline
post #13 of 14 Old 02-23-2011, 03:48 PM
Small Fry's Avatar
Good to hear you having it working.
post #14 of 14 Old 03-03-2011, 06:23 PM
Captn. Crunch's Avatar
I also am having an ignition issue with a suburban. I got a 64 7.25 DB and the switch fell apart. It has six terminals and a push button switch to the right of that. I can't find anything close to the switch and I am not sure what the button did - never pushed it. and it's broke too!
2 1965 Gravely Super convertables 7.6
1 1952 Wisconsin powered L
1 1964 David Bradley Sears Suburban 7.25 hp
1 Dump Cart
2 30 in. Brush Hogs
2 40 in. finish Decks
2 Rotory Plow
1 Rotory Cultivator
1 Reel Mower
1 Square Chute Snowblower
1 Sickle Bar Mower
1 Power Brush
1 Snow Blade
1 Sulky
Captn. Crunch is offline
