Copper exhaust - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 20 Old 01-17-2011, 03:23 PM Thread Starter
Cranky Motorsports
GT_80's Avatar
Images: 32
Copper exhaust
Anyone ever used copper tubing for exhaust? soldered it together? only downfall I could see is that maybe the solder would get too hot, but how hot is a small engine's exhaust? I was just brainstorming for the Super12 custom exhaust I wanna do...
MTF Addict #35886
Hugh-SS/16 fan #0001
1966 Custom 6 for sale $100
1967 Suburban 12 "The 679"-Yanmar L70 Diesel
1967 Suburban 10 parts for VVVV
1967 Suburban 10 Super 12 Special clone
1967 Super 12 "Christine"
1968 Super12/66 SUburban "Miss Emma Lee" Launtop 186F Diesel
1968 Super 12 "C&B Special"
1970 Suburban 12- Parts
1970 Suburban 12 All Power diesel
1973 SS16 / Roper Diesel "D10S"
1974 SS16 rescued
1976 SS18 "Trusty"
1978 GT18 with Hard cab
My YouTube
My Ebay
Sears Manuals
GT_80 is offline
post #2 of 20 Old 01-17-2011, 03:27 PM
evo803's Avatar
Re: Copper exhaust
IMHO plain solder would not hold up to the heat or vibration , silver solder might have a chance. Could you braze it ?
Chris
" Friends don't let friends drive stock ! "
evo803 is offline
post #3 of 20 Old 01-17-2011, 04:11 PM
jaron's Avatar
Re: Copper exhaust
Copper discolors when exposed to heat or water, so it would look really nice but only for a short time.
jaron is offline
post #4 of 20 Old 01-17-2011, 04:34 PM
Re: Copper exhaust
Copper will work fine if you silver braze pipe into connector. The elbows will not hold up very well. I did this years ago on a Wheel Horse. It does sound good. If you choose to use copper, get Silfos from someone in the HVAC business. It does not require flux on copper to copper. I use 15% because it flows better. Mapp gas torch will work but is slow. Oxy-Acetylene works well but you have to be careful not to burn through metal.
oldgoat53 is offline
post #5 of 20 Old 01-17-2011, 05:35 PM
That there's worth fixin'
69l46vert's Avatar
Re: Copper exhaust
Cool idea. Wonderin if you could incorporate a copper muffler into it? I've built steel mufflers for some of my tractors but the copper idea seems worth a try. I don't think it would get so hot that it would melt decent solder
69l46vert is offline
post #6 of 20 Old 01-17-2011, 05:55 PM
HAMMAN
hamman's Avatar
Re: Copper exhaust
I had a 1951 Ford Pk Up that my dad and I put 1 1/2" to 3" copper exhaust on back in the 60s. Stepped it up from 1 1/2 to 3 in a couple of steps. Made a Wye for it just behind fire wall and went to the back dual from there. With that Flat Head and 3" copper exhaust I could rattle the windows in my home town taking off or downshifting.(Needless to say copper was way cheaper then) I posted here earlier about a Sears Compact 8E that I was going to redo and make it a hot rod. I plan on using copper for the exhaust and dueling it to come out under the back wheels. I will do the same thing and make a Wye ( if I can remember how my dad did it) to go into the dual. I will use Silver Solder on the copper and I will use black iron pipe from the motor to under the tractor. It can be done. As was said try not to use a lot of copper els as they will tend to degrade especially close to the motor. Good luck & show us if you do. When I get to working on mine I will post its progress.
hamman is offline
post #7 of 20 Old 01-17-2011, 06:26 PM
Johnnyby68's Avatar
Re: Copper exhaust
i've never saw it done before... you could braze it but i dont kno if it would hold honestly.... what about metal conduit? itd be cheaper and you could bend it yourself
Johnnyby68 is offline
post #8 of 20 Old 01-17-2011, 06:51 PM
Re: Copper exhaust
Put on a small fitting on the end of the exhaust of my WH210-5, to get direct the exhaust flow away from the hood support. Close enough to the end of the pipe, so I could use a small self threading screw. Then painted it black.
Serves it's intended purpose.
engine2quarters is offline
post #9 of 20 Old 01-17-2011, 07:00 PM
Ken in NJ's Avatar
Re: Copper exhaust
Have you priced out copper pipe lately ?? Its HIGH !!
Scrap yard is paying $3.70 a pound (Todays Price)
Ken in NJ is offline
post #10 of 20 Old 01-17-2011, 07:04 PM
A1CNC's Avatar
Re: Copper exhaust
Aluminum melts ~1100F-1300F depending on the alloy.
60/40 solder melts ~ 500-600F
15% silver solder melts in the 1300F range if I remember correctly.
45% silver solder melts at a higher temp. and Brazing rod is higher still I think.
One option woulb be o use brass fittings coming off the engine going to copper or continuing with brass.
1977 16/6 with Kwikway loader
GT 3000 Hydro
Simplicity 15hp Regent Hydro with 36" snowblower and mower-deck
Dump cart, Lawn roller, 46" 2-stage sears snowblower attachment
A1CNC is offline
post #11 of 20 Old 01-17-2011, 07:08 PM
Sears/Craftsman Owner
DIRT Dog's Avatar
Images: 20
Re: Copper exhaust
Harris makes an excellent fifteen percent braze for copper.I really don't think soft solder would hold up due to the low melting point.Use ACR or type L copper to prevent the copper from having stress fractures from vibration.Commercial refrigeration unit vibrate alot and set up harmonics.No problem if you use the types mentioned.A copper exhaust isn't a bad ideal at all!The number in the braze indicates how much silver is in it.
77 18/6 twin,electric 3 point hitch,disc harrow ,cultivator,10" mold board plow,draw bar,Sears box blade,& sickle bar (Haban).
97 Craftsman GT 50",Craftsman front scoop,48"dozer blade.
79 GT18(parts doner),42"deck,2 manual 3 point
hitches.
74 ST-16,42"deck
DIRT Dog is offline
post #12 of 20 Old 01-17-2011, 07:19 PM
HAMMAN
hamman's Avatar
Re: Copper exhaust
My dad used brazing rod and silfloss to put the pipes together. We did have one joint come apart. It was because the silfloss didn't penetrate as it should. Dad said it was because he didn't heat it enough. I had the exhaust on for over a year and a half and 5 tickets. That's when I had to take it off. Once silfloss has been heated it's melting point is heightened. (so I am told) I would think that as the exhaust exits away from the small engine the heat would be disapated enough to make the use possible. IMHO. I used to have a picture of the rear of my pickup showing the exhaust. It does turn it dark but it did sound good.
hamman is offline
post #13 of 20 Old 01-17-2011, 07:57 PM
Re: Copper exhaust
You could fabricate a steel exhaust,
Then make an exact copy of it in copper only bigger to cover the entire exhaust.
Steel exhaust would fit inside the copper one.
No worries about heat or structural problems and no discoloration.
Honda goldwings did this with chrome exhaust outer shell, and basic steel inside, so they would not turn blue from the heat or incorrect jetting mixtures.
GQROD is offline
post #14 of 20 Old 01-17-2011, 08:35 PM Thread Starter
Cranky Motorsports
GT_80's Avatar
Images: 32
Re: Copper exhaust
i think i was only considering it cause i saw nice smooth corners on a website and thought it would look cool. I have 1 1/2" conduit i am planning on using, but I don't have a bender for it, and I think making the whole stack out of black pipe looks wierd. I want to use a 2" nipple off the motor and make the rest of the pipe in one piece- out the head, 90, about 20" straight, then turn out at top. Like I said I just don't have a pipe bender for conduit
MTF Addict #35886
1974 SS16 rescued
1976 SS18 "Trusty"
My YouTube
My Ebay
Sears Manuals
GT_80 is offline
post #15 of 20 Old 01-17-2011, 08:51 PM
89YT12's Avatar
Images: 9
Re: Copper exhaust
i think the copper would look cool once it got hot and weathered
Jason "J"
89YT12 is offline
