Hydrostatic / Automatic info needed (buying new) - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 5 Old 07-16-2010, 08:55 AM Thread Starter
I currently own the following;
- Craftsman 15.5 HP IC
- 42" cut
- Hydrostatic (automatic) Hydro Gear (310-0500)
- 1998 M/Y
- 917.258081
The manual for my current riding mower states, "hydrostatic (automatic)" as written. Are the terms hydrostatic & automatic synonymous? Here is why I ask .....
I am looking at buying a 2009 M/Y Craftsman LT2000, 19.5 HP, 42" cut with the "automatic" drive. The Sears item number is 28908 (see photo attached).
I called and spoke with a Sears lawn and garden salesperson. He rambled on that the automatic has a series of pulleys that automatically adjust to provide the speed change. I know a belt and pulley drive the rear unit, the explanation did not mechanically make sense. What are the differences?
So I am wondering, does anyone have knowledge of the drive unit that is in this mower I am looking at buying? Such as manufacture, type of drive unit.
Also how could I identify the type of drive unit it has. Where to look and what a series of numbers or description would I look for.
Thanks all
Humble314
its all about the pi
humble314 is offline
post #2 of 5 Old 07-16-2010, 11:19 AM
4K Poster!!!
Fcubman's Avatar
Images: 5
Re: Hydrostatic / Automatic info needed (buying new)
A hydrostatic transmission uses a variable displacement hydraulic pump and a hydraulic motor to vary your speeds. Speeds can be adjusted by a hand lever, or foot pedals that vary speeds, much like a car accelerator, hence the term "automatic". The engine speed stays constant, but the ground speed changes as you push either the forward or reverse pedals harder. Most of these use a belt to transfer power from the engine to the transmission and act as a clutch to disconnect the transmission from the engine.
A variable pulley drive used mechanical means to vary the pulley diameters to vary your speeds. I don't know much else about these. I don't think there are any hydraulics involved.
You need to match the abilities of the transmission to your intended use. A "weaker" one is fine for a level, small lot, where you just mow and do light duty work. If you intend to climb hills, pull a dirt plow, etc, you need a sturdier transmission, or risk ruining a smaller unit by overworking it.
Some prefer a straight geared transmission for reliability and strength, others prefer the convenience of a hydro.
"You pays your money, and takes your choice."
I can't help you with the specifics of that machine, but I'm sure others will be able to chime in.
(Red Green)
Fcubman is offline
post #3 of 5 Old 07-17-2010, 12:52 AM Thread Starter
Fcubman,
As you stated, the auto uses a varying set of pulies and a belt between them with then the primary drive belt to he crank. the hydrostatic is a true hydro. I called Hydro Gear and spoke with a tech who provided good detail as to the differences between each.
I do not want the auto. Thanks for the input.
Humble314
ID:	113220   Click image for larger version
Name:	28910 Hydro.jpg
post #4 of 5 Old 07-17-2010, 01:04 AM
4K Poster!!!
Fcubman's Avatar
Images: 5
You're welcome.
I have a hydro, and love it. I don't know how I got along all those years with a geared transmission....
(Red Green)
Fcubman is offline
post #5 of 5 Old 07-17-2010, 01:09 AM
Murray tractor owner
MTD snow plow's Avatar
Images: 8
Hydrostatic has 2 pedals (1 forward 1 reverse) an automatic has a shifter from forward to neutral to reverse and 1 pedal.
Cub Cadet 72, mower deck, soon plow and sleeve hitch
MTD 995 hydrostatic-hydro lift, 54" snowplow, 3 point Hitch, 50" deck, Tire Chains, 10" plow, box-blade
1997 Murray 15.5 Hp 42"
Honda HRA214 self-propeled mower
2010 Stihl FS-45 trimmer
Ariens Snowblower H70
IH (Cub) cadet 282 Hydro
Lawn-Boy 6262 commercial, BBC, Mulch/side discharge
Lawn-Boy Selfpropeled bagging mower(Forget the model)
MTD snow plow is offline
