Kohler 27 hp head gasket - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 4 Old 03-03-2010, 04:43 PM Thread Starter
All Fired Up
Does anyone think retorqueing the head before the gasket blows would be worth it? Has anyone tryed this? I'm thinking about it.
madmantrapper is offline
post #2 of 4 Old 03-03-2010, 10:07 PM
TECH Exchange Contributor!
Alan Lloys's Avatar
Re: Kohler 27 hp head gasket
I am not sure about this as a preventive measure, but I have seen in some service notes that they recommend it after a few hours if the head gasket has been replaced.
Remember that if you simply put the torque wrench on and turn it till it clicks, you will likely not accomplish anything.
The trick I have seen written but not tried myself is as follows:
  • Back all 4 headbolts out a little to loosen them
  • Take one headbolt completely out and dip the threads in a little oil
  • Re-insert bolt and snug it down (don't tighten it yet)
  • Repeat for the remaining 3 bolts
  • Torque down all 4 bolts per the repair manual instructions
As I said I have not tried this but it does seem to make sense. Basically you are taking the bolts out all the way and then re-inserting them again however without disturbing any of the gaskets.
Use at your own risk
Alan Lloys is offline
post #3 of 4 Old 03-04-2010, 02:53 PM Thread Starter
All Fired Up
I don't see where that is any different then using a used head gasket over. Year ago when we retorgued heads after it heated up, we sure didn't loosen them first, this was on automobile engines.
post #4 of 4 Old 03-04-2010, 03:18 PM
Chuck_050382's Avatar
You aren't supposed to reuse the head bolts so to me removing them and re-torquing them wouldn't be right.
The information says you check the them after a few hours after you replace the gasket, but I dint want want to take everything back off the motor.
Ford LGT 145, 2003 Craftsman GT 5000, 1977 MTD 990, 1983 Ford LGT 165, 1988 Cub Cadet 1210
Chuck_050382 is offline
