Craftsman gt 6000 18hp Kohler - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 12 Old 04-21-2017, 08:46 AM Thread Starter
Need info on type of oil, or oils used in transaxle. Also filter type, etc.
Any help is appreciated. Drain plug locations, fill tube location, etc.
carheir is offline
post #2 of 12 Old 04-21-2017, 09:59 AM
nra1ifer's Avatar
Images: 3
Re: Craftsman gt 6000 18hp Kohler
Can you tell us the year and model number of your GT6000?
There should be a tag under the seat that looks something like this:
nra1ifer has:
1994 GT6000 917.255730
2009 PGT9000 917.289740
1980 Speedex 1631
Cub Cadet 123 w/48" deck and Model 1 tiller
1974 Troy-Bilt Horse tiller
nra1ifer is offline
post #3 of 12 Old 04-21-2017, 11:52 AM
tkskagen's Avatar
carheir,
More information required...
I'm assuming that given that it is a GT6000, and that you stated 18hp Kohler that your tractor may have a Kohler Magnum M18. (horizontal shaft or vertical shaft?)
Does your tractor & engine look similar to these pictures?
-Thomas (12)
Just west of Seattle, Washington
tkskagen is offline
post #4 of 12 Old 04-21-2017, 07:53 PM Thread Starter
Looks identical with the exception mine is a hydrostatic. Otherwise the same.
carheir is offline
post #5 of 12 Old 04-21-2017, 07:56 PM Thread Starter
Model # 917257730
carheir is offline
post #6 of 12 Old 04-21-2017, 08:51 PM
Slightly Autistic
Bill Kapaun's Avatar
Originally Posted by carheir View Post
Model # 917257730
Owners manual should answer some-
http://www.managemyhome.com/mmh/lis_...M/L0804022.pdf
Illegally Blind
Bill Kapaun is online now
post #7 of 12 Old 04-22-2017, 12:26 AM
nra1ifer's Avatar
Images: 3
You have one identical to mine. Therefore: you have the HydroGear 218-3010L transmission. I forget if I drained the case via the spin-on filter (WIX 51563) or if there was a drain plug. I do remember that there is an oil level plug (hex-keyed slot for removal). Seems like you have to remove the left rear wheel/tire to get to it. I filled mine via that plug, or by the vent hose that is tucked under the rear end, somewhere near the gas tank.
Oil - 20W-50 ..... manual says approx. 1/2 gallon (2 qts)
If you look at the files I attached, you might notice that one document says 10W-40, another says 20W-50. I have used 20W-50 in mine. Might take awhile to warm up in the winter, but it has worked fine for me. Either is probably OK.
nra1ifer has:
1980 Speedex 1631
nra1ifer is offline
post #8 of 12 Old 04-24-2017, 09:36 AM Thread Starter
Thanks very much for the info. Really appreciate your assistance. BTW, what size, etc are those lug tires on your tractor?
carheir is offline
post #9 of 12 Old 04-25-2017, 12:22 AM
nra1ifer's Avatar
Images: 3
Hmmm..... I would have to go look. I think those were some old Firestones?? I have since put turfs back on the rear, along with a set of chains. Those stay on for the winter in case I get a chance to move some snow with the front blade.
I have Carlisle Tru Power ags on our PGT-9000.
nra1ifer has:
1980 Speedex 1631
nra1ifer is offline
post #10 of 12 Old 04-25-2017, 12:28 AM
nra1ifer's Avatar
Images: 3
And..... I think that WIX 51563 equates with Hydro-Gear's 51563... here is a good place to get the Hydro-Gear 51563.
Hydro-Gear 51563 FILTER, SPIN-ON
I think I originally got a filter at NAPA for a higher price, then ordered online for one or two to put on the shelf.
nra1ifer has:
1980 Speedex 1631
nra1ifer is offline
post #11 of 12 Old 04-25-2017, 05:24 AM
Slightly Autistic
Hydro Gear 51563 is a Wix 57253 per the WIX website.
Catalogs
Illegally Blind
post #12 of 12 Old 04-25-2017, 08:26 AM
nra1ifer's Avatar
Images: 3
Catalogs
Thank you, Bill, for clarifying that. Several years ago when I was ordering those filters I know I had that information.......
I also need to make a clarification to a previous post: On my GT6000, I used 10W-40 oil, not 20W-50. (I used 20W-50 in the trans on our 2009 PGT-9000.
nra1ifer has:
1980 Speedex 1631
nra1ifer is offline
