1998 Craftsman LT electric clutch - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 15 Old 04-19-2017, 08:55 PM Thread Starter
walter g's Avatar
My early 1998, Green box style tractor, is having mowing issues. It has the 46" 3 blade deck.
I just put on brand new kevlar belts, and new blades. Pulleys are good, spindles are good.
It was fine after the new parts for the first 15 minutes, now the mower deck doesn't come up to rpm's.
So is this the sign of an electric clutch failing, or does it just need to be adjusted, or ???
Sent from my LGLS775 using Tapatalk
walter g is offline
post #2 of 15 Old 04-19-2017, 10:52 PM
Slightly Autistic
Bill Kapaun's Avatar
Re: 1998 Craftsman LT electric clutch
New Posters Please Read Before Posting
It would be mighty coincidental.
Could the deck braking system been "disturbed"?
You could try adjusting the air gap on the electric PTO (if adjustable) if you REALLY think that is the problem.
https://www.google.com/#q=Warner+Clutch+Adjustment.pdf
Illegally Blind
Bill Kapaun is online now
post #3 of 15 Old 04-19-2017, 11:42 PM Thread Starter
walter g's Avatar
Bill the tractor number is 917.258685. Clutch is ayp 137140, which is a Warner clutch.
I'm going to check everything on the deck this weekend, but this is a strange problem. I thought if these clutches were out of adjustment they simply didn't work.
The clutch is working but not reaching the correct rpm's. I don't see any signs of belt slippage. Belts are new and the correct ones.
walter g is offline
post #4 of 15 Old 04-20-2017, 04:43 AM
Cannon51's Avatar
Did you remove the clutch to change belts? Didn't lose the keyway? Any tensioning springs on the deck? I had a 46 inch/electric PTO on a 917.256600 once, had a lot of belt routing. I'm just guessing.
Cannon
Cannon51 is offline
post #5 of 15 Old 04-20-2017, 05:48 AM Thread Starter
walter g's Avatar
No. I just had to unplug it and remove a couple guides. I took pics of the belt routing to make sure I put it back right.
Guys, one thing I should of mentioned is it had this problem with the old belts, also. I had assumed it was a belt stretch problem.
The belts were worn out and stretched. After I replaced the belts. Everything worked fine for a short time. Then the problem started again.
walter g is offline
post #6 of 15 Old 04-20-2017, 08:13 AM
Ericjr16's Avatar
Check your idler pulley set up on deck. Our latest one did same and idler pulley was froze in place, belt was too loose on PTO.
Challenge Met
John Deere 180 with two bin bagger
1997 John Deere 345
1971 Bolens 1256 snow caster
1996 Craftsman GT6000 snow blower
1980 Wheel Horse C-85
1967 Sears Suburban SS10
Many more!! changing by the day!!
John 3:16 Psalm 28:7
"Complain and remain, praise and be raised!
Ericjr16 is offline
post #7 of 15 Old 04-20-2017, 09:55 AM
larrybl's Avatar
Images: 43
I agree, the spring and lever on the deck idler pulley could be restrictive in movement not allowing the idler pulley to place the correct tension on the belt.
1990 18.5 Craftsman (RED)
1978 Roper 20T (Old Girl)
[/url]
larrybl is offline
post #8 of 15 Old 04-20-2017, 07:03 PM Thread Starter
walter g's Avatar
Idler pulley is fine, but the arm isn't.
Looks like the arm is bent, putting the pulley at an angle. So the belt is to loose because of this.Click image for larger version
walter g is offline
post #9 of 15 Old 04-20-2017, 07:05 PM Thread Starter
walter g's Avatar
I only uploaded the pic once, so I don't know why their are 2 copies showing.
Now it's back to one pic. Must be a glitch.
walter g is offline
post #10 of 15 Old 04-20-2017, 09:08 PM
Ericjr16's Avatar
Figured that might be your issue! In my latest machine at first deck came on soft, turned out the idler was seized. Today after rebuild you can hear it fire right on when pto engaged!
Challenge Met
1997 John Deere 345
Ericjr16 is offline
post #11 of 15 Old 04-21-2017, 09:28 PM
It might be just the bright back gound in the the pic, but it looks like that belt is riding very deep in the pulley. You get the right width on that new belt? If it is bottoming out, it will slip. Just a thought.
X 500 48" Deck 48" blade
Sears Suburban Super 12 1968
Alien5044 is offline
post #12 of 15 Old 04-21-2017, 10:50 PM
larrybl's Avatar
Images: 43
I agree, belt doesn't look wide enough, and Idler is canted. Check the Idler bracket bushings, and find the proper belt size.
http://www.mytractorforum.com/showthread.php?t=699657
[/url]
larrybl is offline
post #13 of 15 Old 04-22-2017, 08:54 AM
any chance someone put the wrong idler on it?
38racing is online now
post #14 of 15 Old 04-25-2017, 05:20 AM Thread Starter
walter g's Avatar
Sorry guys. I haven't been getting updates on this thread.
The belt is correct, at least by the part number it is. I kept the old belt, so I will check to make sure the width and length is right.
I've had the tractor for over 11 years. It had that idler pulley on it when I bought it. I will double check the condition of the pulley when I pull the deck.
We've just had four plus inches of rain here, so I need the ground to dry out before I can work on it.
walter g is offline
post #15 of 15 Old 04-25-2017, 11:01 AM
I have the understanding, from reading, that v-belts do NOT stretch. They will wear the sides of the Vee, and slip further into the pulley until they are so deep they no longer are in tension, and develop slip and melt and destruction.
The idler in the picture appears to be at an angle. One can remove the idler shaft support arm, and tweak the angle, hopefully straightening the arm so the idler pulley runs square to the backside of the belt. Some width is there in the idler pulley to handle the different positions the belt will attain depending on the height of cut setting. The PTO pulley is fixed relative to the chassis, but the deck is movable. The change is 'handled' by the idler pulleys(two on my two-blade deck) with their expanded pulley width allowing the belt angle to vary a bit without causing the belt to ride out of the pulley.
I'd check that the idler arm should be straightened a bit for proper operation. If the belt seems to be riding against either edge of the idler, an angled shaft caused by a bent arm might be the cause.
tom
simplificate & add lightness
tomw0 is offline
