Pressure relief valve for Deere X-series - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Johnny Products Johnny Buckets and more!!! The Voice Of The Common Man With The Common Yard
post #1 of 23 Old 12-20-2006, 08:51 PM Thread Starter
I just purchased a John Deere X740 with 16 hours that had been returned to the dealer within 30 days of the first sale. I planned to order a JB Sr. in January. However there is some discussion on the net about the need for a pressure relief valve for the hydro (not to be confused with the cut-off valve) and a new free wheeling lever to prevent damage to the hydro from hydraulic back pressure.
Is this rubbish? Are any present users using this?
I do not intend to break any granite stones with the JB, just move loose material.
Any thoughts?
whbob is offline
post #2 of 23 Old 12-20-2006, 09:44 PM
Hardscrabble's Avatar
Re: Pressure relief valve for Deere X-series
I've got a JD X485 with a JB Sr. I had the dealer add the pressure relief valve and the divertor cutoff valve. Don't remember the cost. I believe these items come standard as part of the OEM loader assembly but you will need to add them yourself since the JB Sr. does not come with them. No trouble with my JB Sr. and I have moved some pretty good size loads. I don't remember having to do anything with the freewheeling control.
Hardscrabble is offline
post #3 of 23 Old 12-21-2006, 04:29 PM
DeereBob's Avatar
I've had my JBSr. for a couple of years and this is the first time I have heard anything about a pressure relief valve required. I've used it pretty heavily two summers ago and noticed no odd performance or any damage to the control arm. Sometimes the bucket response is slow but that may because I forgot to turn the bypass valve to the opposite position I use for just mowing. My X485 is 4.5 years old now so if there were any problems, I'd probably experienced them by now.
John Deere X485 AWS 48" Deck, Power Flow with 3 Bag Bagger, 46" Single Stage Snowthrower, Quick Hitch, 54" Blade, 2" Ball Hitch and JBSr.
DeereBob is offline
post #4 of 23 Old 12-21-2006, 07:01 PM Thread Starter
Anybody outthere in Deere world know what the pressure relief valve does and what is it application on the X-Series. Is it required for loaders? Is it required for 3ph use? This may be more of a deere question than a JB question.
Also, I believe that Simplicity is using the same K92 transmission which deere has used since the 455 series. This would probably apply to them.
whbob is offline
post #5 of 23 Old 12-22-2006, 07:34 AM
JDPROFESSOR's Avatar
The Rel-valve is needed when the John Deere loader is installed. Not needed with the J-Bucket.
The reason you need it; if you had a heavy load in the bucket, had it up in the air, and dropped it quickly, you would get a pressure spike. The Rel-V is used to protect the system.
The good old days pulling the GREEN!!
JDPROFESSOR is offline
post #6 of 23 Old 12-22-2006, 08:36 AM
9K+ Poster
JDFANATIC's Avatar
Professor,
Isn't this the same as the bypass valve DeereBob mentioned?
Cheers
JDFANATIC
JDFANATIC is online now
post #7 of 23 Old 12-22-2006, 09:03 AM
No! The Rel-valve mounts on top of the hydro unit. The by-pass valve mounts on the back side of the hydraulic valve that operates the front equipment. The outlets that are used to angle the blade, operate the bucket on the loader or angle the chute on the snowthrower and raise and lower the mower deck are all operated with the same hydraulic valve. The bypass valve or better known as the shut off valve is used to turn off the flow of oil to the mower lift cylinder, when one of the front att. are being used.
If you don't shut off the flow to the cylinder the front att. will operate much slower than normal, the blade will angle on it's own when pushing a heavy load.
post #8 of 23 Old 12-22-2006, 10:27 AM
9K+ Poster
JDFANATIC's Avatar
Thanks for the clarification!
Cheers
JDFANATIC
post #9 of 23 Old 12-22-2006, 02:24 PM Thread Starter
I want to thank everyone for their help in educating us about this.
I will use the funds that I would have spent on the PR valve on the JB-Sr.
whbob is offline
post #10 of 23 Old 12-22-2006, 03:32 PM
WHBOB
You may want to look at the following pics. and viedos.
This bucket makes the JB look like a toy.
post #11 of 23 Old 12-22-2006, 03:49 PM
DeereBob's Avatar
Don't be too quick to cite the virtues or your bucket versus ours. Yours requires a $500 quick hitch and mowing deck removal while ours doesn't but still can handle close to the same volume of material (3 cu. ft.) and lift 300 pounds. Plus yellow looks better than green!!!
DeereBob is offline
post #12 of 23 Old 12-22-2006, 04:22 PM
Old as Sin
silver hair deere's Avatar
hello all
how about the or-bilt loader it lifts about 400 lbs. up about 50 inches and only costs about 500.00 more
silver hair deere
p.s. there web is www.or-bilt.com
silver hair deere is offline
post #13 of 23 Old 12-22-2006, 04:31 PM
DeereBob's Avatar
Silver Hair,
Now you're talkin'!! If I had known about it, I might have considered it over the JBSr. just for the extra lift height. However, I'm not sure it would work on my AWS tractor since JD doesn't recommend a FEL with AWS for safety reasons. But for 2WS tractors, that loader looks pretting appealing both on a price and size basis versus the JD one.
DeereBob is offline
post #14 of 23 Old 12-22-2006, 05:17 PM Thread Starter
JDProfessor - who makes this scoop. Do they have a web site?
whbob is offline
post #15 of 23 Old 12-22-2006, 06:26 PM
The mower deck does NOT have to be removed.
There are grease fittings at all pivot points.
Hardware is grade 8
The frame is stronger built than the JB
In most cases the customer already has the quick-tatch hitch because they have
a blade or blower.
The lift cap. is over twice what the JB is.
These buckets are locale made, no web site
