My opening is only 80" from the plush carpet to the top of the door frame. 48" wide.
http://www.homedepot.com/p/JELD-WEN...HDJW160600147/202037481?N=12l0#specifications
This doors we are looking at says Assembled Height (in.) is 80.5 in
So how much do I have to trim off the bottom? to make it look right. Below it says I can only cut off a 1/2"......I think it still may be rubbing against the rug?
Then it says this:
•Installation hardware included
•Matching slab and prehung passage doors also available
•Textured woodgrain surface is primed and ready to paint
•Doors must be finished on all 6 sides
•Trimmable allowance of 1/2 in. from door height and width (1/4 in. from each side)
•5-Year limited warranty
•Note: Product may vary by store
•MFG Model # : THDJW160600147
•MFG Part # : 05316
So how much do I have to trim off the bottom? to make it look right. Above it says I can only cut off a 1/2"......I think it still may be rubbing against the rug?
Can I use this door or not, if not where do I find a door lower then 80"
Then it says this:
•MFG Part # : 05316
