removing mold from siding - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 14 Old 04-12-2005, 01:42 PM Thread Starter
ex spelling bee champ
Ingersoll444's Avatar
Images: 14
I have a few aeras on my house that have a lot of mold on the vinel siding. Any tips for cleaning it, but without hurting the siding?
Paul B
SUPER Of The Month 10/2011
Ingersoll444 is offline
post #2 of 14 Old 04-12-2005, 01:49 PM
I use a slightly weakened mixture of bleach and water (can't quite remember the ratio) and a scrub brush. My siding is clay colored and it doesn't affect the color at all and the mold comes right off. Hope that helps!
911radioman is offline
post #3 of 14 Old 04-12-2005, 02:04 PM
Member Extraordinaire.
Durwood's Avatar
I have always heard to use bleach too. Check on the product label and it should tell you what it's ok for. If you go to a place that sells siding (lowes,home depot, etc ) they should sell a product to clean it with.
Durwood
I'm ashamed of what i did for a Klondike bar....
Durwood is offline
post #4 of 14 Old 04-12-2005, 02:06 PM
Ratchet Jaw old Member
drbailey's Avatar
Ingersoll444 , Idid like 911radioman, 1 gal water 4 caps bleach , scrubed it with a long handled car was brush , then rinse ( before drying ) , I used my pressure washer. If u do any part , I would suggest doing the complete wall.
drbailey is offline
post #5 of 14 Old 04-12-2005, 02:11 PM
m-ODD-r8r
CatDaddy's Avatar
I've had pretty good success using TSP (tri-sodium phosphate - I think) in removing mold & mildew from walls & ceilings without damaging the finish.
If at first you don't succeed, destroy all evidence that you tried.
iumop-эp!sdn эJa nολ s!ч+ paэJ ua} nολ !
CatDaddy is offline
post #6 of 14 Old 04-12-2005, 02:13 PM
Durwood's Avatar
on the whole wall. It will probably show the spot washing if you don't.
Durwood
Durwood is offline
post #7 of 14 Old 04-12-2005, 02:22 PM Thread Starter
Images: 14
Well the whole wall would be tough. Realy pretty tall. Maybe I will test out a low part, and see how it looks
Paul B
post #8 of 14 Old 04-12-2005, 04:21 PM
guest
Guest
Posts: n/a
If you have a pressure washer, I would try spraying the wall down with a strong clorox solution and then pressure wash it off after it has had maybe a half hour or so so soak in. Otherwise the old scrub brush and clorox solution is the other choice. Wash it off with the hose.
post #9 of 14 Old 04-12-2005, 04:27 PM
Camaniac
I use a product called "60 second (something) cleaner". I buy it at Lowes home and garden. I use it on my beige vinyl siding, my deck, even hit the lo-boy once with it to get the mold off the north side as parked. I do dilute it some, spray on with pressure washer (low presure), scrub, blast it off!
1956 Cub Lo-Boy
JD LA175
JD LT133
JD RX73
Sears 16/6
If you can't fix it with a hammer, it must be an electrical problem!
freebird is offline
post #10 of 14 Old 04-12-2005, 11:09 PM
Anything With Wheels
Argee's Avatar
They used to make a product
called X-14 that was designed for that very problem. I used some on a moldy canvas camper top once without any residual damage. It was bleach based.
Randy G
Argee is offline
post #11 of 14 Old 04-13-2005, 06:48 AM Thread Starter
Images: 14
I have seen that before Argee. Cant remember where though.
I will have to check whats out there. I was afread the bleach would hurt the siding, but it sounds like as long as I cut it, it should be fine. This aera looks real bad, and its right in front. Got my gutters up last year, and that should stop it from coming back though[I hope]
Paul B
post #12 of 14 Old 04-13-2005, 08:07 AM
9K+ Poster
JDFANATIC's Avatar
Clorox makes a outdoor cleaner that has something for mold/mildew etc. I used it on my lawn furniture and then decks and it worked great. You just apply it with a sprayer and let it sit for a while and then wash off (some scrubbing required). I'll look later to see if I have some left in the shed -- I did purchase it at HD though.
Cheers
JDFANATIC
JD2210
JDFANATIC is offline
post #13 of 14 Old 04-14-2005, 08:03 PM
9K+ Poster
JDFANATIC's Avatar
It's called:
Clorox Outdoor Bleach Cleaner
Worked well enough for me that I would purchase it again.
Cheers
JDFANATIC
JD2210
post #14 of 14 Old 06-11-2005, 08:46 AM Thread Starter
Images: 14
Re: removing mold from siding
Well all this worrying about nothing. My wife went out, hosed it down, scrubbed it with a little soap and water and it came right off. Easy. Hey some times things work out the easy way. Not many time thoguh it seems.
Paul B
