Wheel Horse not charging battery - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 11 Old 07-26-2009, 08:47 AM Thread Starter
I have a 1988 520HC, about 2 years a new 20HP Onan engine was installed, on the voltage gauge it stays right on the bottom left of the green at 12 volts, it wont charge any higher, have checked with other meters, when engine not running it checks at about 12.6 volts, when I start the engine it drops to about 12.4 volts. Wondering if anyone had any ideas, could it be the rectifier or the stator, I have a wiring diagram, I thought when engine running the voltage should actually rise to around 15 to 16 volts, anyone got any ideas on things I can check to see if it is charging properly, havent had it long, it must be charging a little because the new battery is still starting it.
kk4et is offline
post #2 of 11 Old 07-26-2009, 10:26 AM
Re: Wheel Horse not charging battery
The proceedure to check it is in the Onan service manual you can download from Toro. Go to
https://lookup3.toro.com/request/request.cfm
Enter your C1-20OE01 model number (0=zero, O=Onan) and type none in the serial # box.
Garry
gwest_ca is offline
post #3 of 11 Old 07-26-2009, 11:37 AM
Vet-Wrencher
Big10's Avatar
If the meter is pushing positive AT ALL, your charging. If your certain it's not charging i would get a multimeter and probe the battery to see if there is a voltage jump between it running and shut off. If no change i would suspect eaither loose connections which is possible or ultimatly the rectifyer/regulator which REGULATES your charge. See if you can get a jump in voltage by wiggling the fuses or wires and watch the amp meter. If it jumps, there's your problem.
Obstical's are those terrible things you see when you take you're eye's off you're goal-Henry Ford
Big10 is offline
post #4 of 11 Old 07-26-2009, 01:31 PM Thread Starter
Found the service manual on the tractor but not on the Onan engine, in the tractor manual it tells about the charging system but no details on how or where to check tnx
kk4et is offline
post #5 of 11 Old 07-26-2009, 01:54 PM
It is there titled "Onan Toro Power Plus P216, 18, 20, 24 Engines - Horizontal" - 53 page file.
Garry
gwest_ca is offline
post #6 of 11 Old 07-26-2009, 08:45 PM
onanparts.com's Avatar
Battery voltage while running should be between 13.5-13.9 depending on battery state of charge. If all connections are clean and tight then check the stator output. The two outside leads at the regulator are the AC leads from the stator.
With engine off disconnect them and connect your DVM set to Ohms to each lead, you should read continuity. If open the stator is bad. Then check between each stator lead and ground. Reading should be infinity or zilch. If good reconnect DVM leads to stator leads and change DVM to AC volts and start up the engine.
At idle you should have about 25-30 volts AC. Full throttle reading should be about 50 Volts AC. If the stator checks out then the regulator is bad.
onanparts.com is offline
post #7 of 11 Old 08-05-2009, 04:48 PM Thread Starter
tnx on the tip for checking the stator
kk4et is offline
post #8 of 11 Old 08-05-2009, 07:14 PM Thread Starter
did the check on the stator but my meter only showed a little over 20 volts
kk4et is offline
post #9 of 11 Old 08-05-2009, 07:45 PM
At idle or full throttle?
post #10 of 11 Old 08-06-2009, 10:39 AM
CHDinCT's Avatar
Images: 7
Sorry to jump in here but I'm having the opposite issue - voltmeter periodically pegs all the way right on my 520, then will settle back to about 14 volts while running, then peg right, then back, etc. Tried jiggling the wires while running to no effect so I don't think it's a loose connection. I can also faintly here a change in pitch to a higher frequency from some electrical component (regulator??) when it pegs right. I would like to test the regulator but I have no idea where to find it on my P220 engine. Also, what's the procedure for checking the regulator output? Thanks for any help.
Chris
BX25, Landpride Grapple, 54" MMM,
1967 Wheel Horse 1077 with 36" RD deck
CHDinCT is offline
post #11 of 11 Old 08-07-2009, 07:32 AM
Mine did the same thing. Found one of the "pins" in the engine to harness "Molex" connector was funky and had heated. Found it when I wiggled the harness and the charged jumped up. Pulled apart and cleaned and applied dielectric grease and it's been good since.
04fxdwgi is offline
