Attaching 42" Snow Blade to C160 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 17 Old 01-02-2009, 06:13 PM Thread Starter
wkmcgee's Avatar
Images: 5
OK, it seems so simple, but I could not get the blade attached today. Would you recommend attaching the rear mount first? Is the blade just attached to the rear & then to the lift assembly in the middle of the tractor? I could not get the shaft in the holes in the back. Tried to lift it & hook it by myself & just couldn't do it. Then I tried setting it on blocks so I didn't have to lift it so far, but still couldn't get it attached.
When I went to hook the lift assembly in the middle, I don't think I was doing that right either. Here are some pictures of what I have. This blade was attached when I bought it, so I know it fits, etc.
The part in the last picture (short link?) was attached to the part in the first picture with the bolt that is in picture 1. From the drawing on Toro, it looks like it is attached to blade & lift assy with clevis pins. Is Pic #3 the lift assembly? The drawing shows a lift bar. Do I attach the short link to the part that sticks out on the lift lever in Pic 2 or to the hole to the left with a clevis pin???
I am sorry guys that I am so new at this. I'm in training, remember!! Any help you can give me is always appreciated.
Wanda
Wanda
Goochland, VA
1975 Wheel Horse C160 w/Hydraulic Lift (Kohler K 16)
42" Side Discharge Rotary Mower (1975)
36" Tiller (1974)
42" Snow/Dozer Blade (1975)
10" Brinly Plow w/Coulter (1975)
WH Cultivator (NOS)
2005 Kubota BX1500 4WD
Kubota Front Loader LA181FL
1985 BCS 725 2-Wheel Walk-Behind (Kohler M 8)
Berta Rotary Plow (2006)
30" Tiller (1985)
36" Sickle Bar Mower (1985)
36" Dozer Blade (2006)
Hiller/Furrower (2006)
Chipper/Shredder Bio 100
wkmcgee is offline
post #2 of 17 Old 01-02-2009, 06:25 PM
paul52446m's Avatar
Re: Attaching 42" Snow Blade to C160
In pic. one, the little plate in pic. three goes from the bolt in the blade frame straight up to the hole in your lift bar
paul52446m is offline
post #3 of 17 Old 01-02-2009, 06:36 PM Thread Starter
wkmcgee's Avatar
Images: 5
OK, that resolves that. Thanks so much.
Wanda
Wanda
Goochland, VA
36" Tiller (1974)
WH Cultivator (NOS)
30" Tiller (1985)
wkmcgee is offline
post #4 of 17 Old 01-02-2009, 07:41 PM Thread Starter
wkmcgee's Avatar
Images: 5
Do I need to take the blade off, install the frame then remount the blade? Is that the trick?
Wanda
Goochland, VA
36" Tiller (1974)
WH Cultivator (NOS)
30" Tiller (1985)
wkmcgee is offline
post #5 of 17 Old 01-02-2009, 08:36 PM
4StarCstms's Avatar
Wanda, I get it all lined up, Mount the Lift Link - Raise the blade, and it should fall right into the rear hitch, and hold it there...allowing you to close and pin hitch...
1976 B-80 36" RD Deck
1987 418A 42" SD Deck
54" Snow Blade -
Sleeve Hitch -
WH 36" Tiller -
WH Cultivator -
Lowes 4 Wheel Wagon
My Youtube Videos
Stihl K55 Kombi-Motor
String Trimmer - Cultivator
4StarCstms is offline
post #6 of 17 Old 01-02-2009, 09:52 PM
Oldbie
Wanda.....
I put the bar of the plow frame in the rear quick hitch first.
I use a short car jack (out of my corvette) and jack the bar
into the slots in the quick hitch. You may have to go to the
front of the tractor and nudge the whole plow to the left or
right to square up the plow frame to allow the bar to fit into
both sides of the quick hitch. Once in place....clamp it in
with the clamp arms. Then go to the front of the blade and
raise it up and set it on blocks as high as it will go (you could
use the jack here also). Then pull your impliment lift arm up
until it locks in the "up" position. Then you can attach the
mid-lift (in your picture) with your pins and bar (you also have
shown). You can then take it down from the blocks (or jack)
in the front.
You can also take the time to adjust the working height if you
do not have a cement or asphalt drive. Lift the plow and set
it on blocks again until it is approzimately 1/4" to 1/2" above
a flat level surface. Lower your lift arm and adjust your lift
limit adjustment knob.until your arm rises slightly. You can
now lower your plow and it should ride at the above measurments
so you won't scrape up a pile of rocks when you plow snow.
If you have cement or asphalt.....you can let the blade scrape
the surface of the drive. But it is entirely up to you.
Keep us posted....
M.
Teddy da Bear is offline
post #7 of 17 Old 01-03-2009, 12:26 PM
Oldbie
Don't keep us in suspense.. Did you get it on?
M.
post #8 of 17 Old 01-03-2009, 02:01 PM Thread Starter
wkmcgee's Avatar
Images: 5
I haven't tried yet. Sorry. I had to work on that pesky left wheel hub again. I can't figure out why it still works itself loose.
Having a family bonfire tonight in the garden, so won't have time until tomorrow. I'll let you know though. I printed out your instructions. Thanks.
Wanda
Wanda
Goochland, VA
36" Tiller (1974)
WH Cultivator (NOS)
30" Tiller (1985)
wkmcgee is offline
post #9 of 17 Old 01-03-2009, 05:14 PM
10,000 +posts!
glenn27's Avatar
Let us know....
Jimmy Buffett
glenn27 is offline
post #10 of 17 Old 01-03-2009, 06:29 PM
Oldbie
Roll that tractor out to the Bonfire..... You can have a round table on it....lol
M.
post #11 of 17 Old 01-03-2009, 10:16 PM Thread Starter
wkmcgee's Avatar
Images: 5
I did use my tractor with wagon attached to take my great nephew for rides around the farm. He was afraid of the noise at first, but after his first trip he was hooked. We had a blast! Hopefully, will attach blade tomorrow.
Wanda
Wanda
Goochland, VA
36" Tiller (1974)
WH Cultivator (NOS)
30" Tiller (1985)
wkmcgee is offline
post #12 of 17 Old 01-03-2009, 10:38 PM
Tmo
Wanda,
Go to the Red Square Wheel Horse site and particularly to this post:
http://whtractor.15.forumer.com/inde...showtopic=5988
It gives you info on the snow plows. And for info for installation, go to this one: http://whtractor.15.forumer.com/index.php?showtopic=291
Tmo is offline
post #13 of 17 Old 01-04-2009, 12:41 AM
4StarCstms's Avatar
Need to repost the pics in that second thread. All the links are no good..
Btw that was a helpful post over there!
54" Snow Blade -
Sleeve Hitch -
WH 36" Tiller -
WH Cultivator -
Lowes 4 Wheel Wagon
My Youtube Videos
post #14 of 17 Old 01-04-2009, 10:50 AM
Are you guys members of redsquare too?
It was broke, then I welded it, But its still broke!!!!
1975 WH C-120 special
46" deck
48" craftsman blade, homemade bracket to fit.
clevis style hitch
no attachments yet
1972 WH 800 Comando
1974 WH B-80 4 speed
WH 520-H
48" deck
rwilson is offline
post #15 of 17 Old 01-04-2009, 11:54 AM
4StarCstms's Avatar
Yeah, Thou I try not to just post links to RedSquare. Does'nt help MTF IMO
54" Snow Blade -
Sleeve Hitch -
WH 36" Tiller -
WH Cultivator -
Lowes 4 Wheel Wagon
My Youtube Videos
