Rectifier / Regulator Question - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 4 Old 07-27-2006, 06:29 AM Thread Starter
Hi have an old wheel horse and it has a Rectifier / Regulator, can someone tell me what it does and how to test it if fails, what the symptoms would be if it does fail?
Thanks!
Salarmi is offline
post #2 of 4 Old 07-27-2006, 10:49 AM
Deceased Oct.-2014
Mickey's Avatar
Images: 9
Re: Rectifier / Regulator Question
Not knowing what engine we're talking about it's hard to be specific. In general, alternators produce A.C. power and the rectifier assy changed that to D.C. A Voltage regulator controls the voltage out of the alt so all the things that use electrical power & the battery are seeing the correct voltage. Over voltage can be a killer. Batteries will live a short life and lamps will fail and other equipment may not function correctly of fail.
Cub Cadet 3204 48" mower
1257 Bolens
Yanmar Fx24D
5' rotary mower
52" Yanmar RSB1300 tiller
Koyker 155 loader
Mickey is offline
post #3 of 4 Old 07-29-2006, 01:57 PM
from South Jersey
Buzz's Avatar
Here's a link to a series of articles that explain your tractors electrical system in an easy to read form. Go to:http://www.simpletractors.com/servic...al_systems.htm
Buzz...from the heart of South Jersey
1954 Bantam 3000 (good original condition)
1958 RJ-58 (a work in progress)
1960 Suburban 400 (a future project)
1964 854 (restored) with SMS-425 Sickle Bar Mower (restored)
1966 856 (my worker...it keeps on going and going and going)
1968 Lawn Ranger 1-2631 (restored) I've owned it since 1972
1973 16 Automatic
1975 C-160 (A freebie!)
1989 John Deere 130
Buzz is offline
post #4 of 4 Old 07-29-2006, 06:42 PM
I looked at BUZZ'z link. It reminded me of my cars in the 40's and 50's.
I had a problem with my '79 bolens with a kohler engine. Its sytem was quite different. It used magnets in the flywheel with coils around the flywheel. This generates AC which goes to the rectifier/regulator. As I remember, it used a 'silicon controlled rectifier' (SCR for short) which is turned on to charge the battery or not turned on if the battery gets up to max volteage (around 14.5 volts). This is all electronic.
I haven't had a regulator fail since I replaced that SCR on the bolens. But I did have the charge diode fail on an unregulated briggs engine used on my gilson.
It seem to me the age and type of engine may affect what your charge system is.
All the modern mowers that I have seen have only a low output alternator and a charge diode if they have a manual pto. If they have an electric pto, the engine gets a high output, regulated charge system.
To check the system, I just put a voltmeter on the battery. It should be around 12.5 (maybe 13) volts before starting the engine. After starting, the voltage should climb to 14.5 volts fairly quickly, if you started with a charged battery.
If the regulator doesn't charge, then the running voltage will be low. If it overcharges, the battery will run dry and fail. This is regardless of the design of the regulator and/or charge system.
JerryO
JerryO is offline
