wheelhorse 520 h wont turn over - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 15 Old 01-04-2010, 05:21 PM Thread Starter
hi everyone i have a i believe to be a 1993 toro wheelhorse 520h. It ran yesterday and today when i went to start it nothing happened i was just wondering if anyone can tell me where to begin. I tried jumping it and that dint work. Then i tried to charge the battery,i was going to jump the solenoid but it looks a little diffrent then the ones im use too and i dont want to mess anything up.Is their something that usually goes wrong with these tractors that i should look for?
ryanchamp10105 is offline
post #2 of 15 Old 01-04-2010, 05:29 PM
archie
wheel horse 1045's Avatar
Re: wheelhorse 520 h wont turn over
check the safety switches,you should have 3 on the 520
wheel horse 1045 is offline
post #3 of 15 Old 01-04-2010, 05:31 PM Thread Starter
how do i do that? thanks
post #4 of 15 Old 01-04-2010, 05:31 PM
Deere 330 Killer
Hugh-SS/16's Avatar
Images: 15
also check the starter and wiring. the batter may have juice, but maybe the starter isnt getting any
GT_80 Fan Club Member: #0001
1967 Suburban 10
1969 Hydro-Trac 12
1970 Hydro-Trac 12
1973 SS/16
Hugh-SS/16 is offline
post #5 of 15 Old 01-04-2010, 05:33 PM Thread Starter
ok i will its wierd it ran fine yesterday
post #6 of 15 Old 01-04-2010, 05:34 PM
Dr.Clank's Avatar
Check the fuses while you're at it. My 414 came with bad fuses, which caused it to start right up one moment and then be totally dead the next.
Dr.Clank
414-8 (31-14k804)
42" deck (15-42SC01)
48" blade (06-48BC03)
36" tiller (07-36TL03)
42" snowthrower (79360)
Dr.Clank is offline
post #7 of 15 Old 01-04-2010, 06:06 PM Thread Starter
i will Im going to be busy in the morning checking all these things lol
post #8 of 15 Old 01-04-2010, 10:17 PM
from South Jersey
Buzz's Avatar
Check the oil level, it has a low oil sensor that won't let it start. Also, while sitting on the seat move the handle on the PTO while trying to start. Sometimes it's not totally disengaged and won't let the tractor start. Sounds like something minor, annoying as heck, but minor.
Buzz...from the heart of South Jersey
1954 Bantam 3000 (good original condition)
1958 RJ-58 (a work in progress)
1960 Suburban 400 (a future project)
1964 854 (restored) with SMS-425 Sickle Bar Mower (restored)
1966 856 (my worker...it keeps on going and going and going)
1968 Lawn Ranger 1-2631 (restored) I've owned it since 1972
1973 16 Automatic
1975 C-160 (A freebie!)
1989 John Deere 130
Buzz is offline
post #9 of 15 Old 01-04-2010, 11:11 PM
Mrwiggles2's Avatar
Images: 9
What were you doing with it when it was running? Snow removal? If so, its possible any combination of the above occurred. Snow gets into everything and 520's have exposed connections galore so its easy for something to get wet, corrode, etc. Just may be that the battery doesn't have enough to turn- hey, its probably 14 degrees by you too. Get yourself a multimeter if you don't have one. Test the battery, should have 12.5 volts at least, when running should see 13.2 to 14. Check your fuses. Two by the pto lever, one down by the starter. Let us know if you find anything.
Craig
Buffalo, NY
You Tube Channel Link Below. Videos on my tractors, how-to and just good stuff!
http://www.youtube.com/user/mrwiggles2?feature=mhee
1989 Wheel Horse 416-8 16hp Onan
1989 Wheel Horse 520-H 20hp Onan
Mrwiggles2 is offline
post #10 of 15 Old 01-05-2010, 12:34 AM
800-SPECIAL's Avatar
Check the relays under the battery next to motor, there are 3 of them and the one closest to the belt had some greened up terminals on mine causing it not to start. Stick your hand in there a wiggle the wires around at relays then try.
312-8 w/ 48" 2- stage Bur-Vac blower
<a href=http://www.1969stang.com/albums/album36/IMG_4930.highlight.jpg target=_blank>http://www.1969stang.com/albums/albu....highlight.jpg</a>
800-SPECIAL is offline
post #11 of 15 Old 01-05-2010, 12:35 AM
Thats what mine was doing.
post #12 of 15 Old 01-05-2010, 08:06 AM
When my neighbor's 520 did that, I pulled and cleaned the fuses under & to the right of the battery. They were slightly corroded and that fixed the problem. My 520 seems to destroy starter solenoids, probably because I hose off the dirt all the time. I put a new one on it about 2 years ago and it's starting to act up again. It clicks, but doesn't allow the voltage to pass thru the solenoid.
billyban is offline
post #13 of 15 Old 01-05-2010, 03:35 PM Thread Starter
i just wanted to tell everyone thanks i looked at the tractor this morning i noticed the 30 amp fuse is melted and broke off i believe it is the charging cicuit fuse maybe that is it i dont have time today to get fuses but i will in the morning after work hopefully this is the problem i will post tommorrow to let you know thanks again
post #14 of 15 Old 01-08-2010, 02:40 PM Thread Starter
hi everyone thanks for your help i replaced the fuses and it fired right up thanks again
post #15 of 15 Old 01-08-2010, 08:11 PM
Living the Dream Again!
steddy's Avatar
That's one of the downfalls about the WheelHorse you will come to find: that open hood design makes electronic parts & bare metal components problematic.
Overkill.
I love overkill.
I'm Ted.
(Click Here)
steddy is offline
