JD 345 cab heater - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 6 Old 10-20-2009, 11:32 PM Thread Starter
enzminger's Avatar
JD 345 cab heater
I have a JD 345 wiyh a soft sided cab. I am considering putting a heater in but do not know what coolant hoses to tap into. I looked and I see one large coolant hose (easy access) but it appears the other hose goes directly into the water pump. There is no room to tap into that one. Does anyone have the answer???
enzminger is offline
post #2 of 6 Old 10-21-2009, 08:23 AM
9K+ Poster
JDFANATIC's Avatar
Re: JD 345 cab heater
Here's some pics of how my 2210 is rigged:
Cheers
JDFANATIC
JDFANATIC is offline
post #3 of 6 Old 10-21-2009, 10:03 AM Thread Starter
enzminger's Avatar
Thanks for the pics. I wish the 345 motor was like yours it would be easier to figure out. I will try and post a few pics to see if anyone has an idea with how my motor is configured/layed out.
post #4 of 6 Old 10-21-2009, 08:01 PM Thread Starter
enzminger's Avatar
I took a few pic trying to show the radiator and its hoses. I see two
"larger" and one small hose. I do not see any place to tap into other than the two large hoses. Any suggestions?????
post #5 of 6 Old 10-21-2009, 09:55 PM
9K+ Poster
JDFANATIC's Avatar
enzminger,
You need to somewhere tap into the outlet and return lines. On the 2210, the fittings make more sense than the hoses. Look closely at the thermostat cap, for example, there may be a fitting or plugged hole you can use.
Cheers
JDFANATIC
post #6 of 6 Old 10-21-2009, 10:19 PM Thread Starter
enzminger's Avatar
I agree. But, I do not see any removable plugs to tap into anywhere. I thank you for you input and taking the time to respond. If you think of anything else please let me know. Thanks again.
