Won't Run, Idles Rough - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 5 Old 10-19-2009, 02:43 PM Thread Starter
x485 aws's Avatar
Hello. My X485 AWS has the 25hp Kawi. Just recently (last couple of mowings) it started to cut out a little but would then run fine. Well, about two ago I was about half way through mowing and it coughed a couple of times and then died. Now it will sometimes start and idles very rough. when I try to idle up, it dies. I replaced the fuel filter and also put new gas in. With the fuel linie unhooked, the pump will shoot gas several feet, so I'm guessing fuel pressure is good? Any help would be appreciated.
x485 aws is offline
post #2 of 5 Old 10-19-2009, 03:38 PM
Super Duper Member
saleen49's Avatar
Re: Won't Run, Idles Rough
When you say cough, do you mean the engine is bogging (fuel), or does it shut off and on sharply (ignition)??
1983 318.
2009 X729 with 54" deck & 54" blade, oh and 45 loader
__________________________________________________ __
"I have not failed. I've just found 10,000 ways that won't work." Thomas A. Edison
saleen49 is offline
post #3 of 5 Old 10-20-2009, 08:11 AM Thread Starter
x485 aws's Avatar
Almost like you turned it off and back on again, but no back back fire.
x485 aws is offline
post #4 of 5 Old 10-20-2009, 08:21 AM
Super Duper Member
saleen49's Avatar
Based on that, I might start looking for an easy ignition issue first. Take the panels off and look over all wiring, and grounds. Grab the connectors and see if they can be pulled apart.
1983 318.
saleen49 is offline
post #5 of 5 Old 10-20-2009, 01:33 PM Thread Starter
x485 aws's Avatar
Give it a try. Do you think it may be a vaccum line?
x485 aws is offline
