JD 140 not charging - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 10 Old 10-16-2009, 10:02 PM Thread Starter
JD 140 not charging
I just bought this and it only puts out 9.6-10.0 volts. Not sure of the year the serial #065841-M and engine#k321as Any ideas would be great. Thanks Don
don17x is offline
post #2 of 10 Old 10-16-2009, 10:25 PM
johndeere's Avatar
Images: 7
Re: JD 140 not charging
Dead cell in a battery is the first thing to check for.
johndeere is offline
post #3 of 10 Old 10-16-2009, 10:56 PM Thread Starter
It needed a battery when i bought it. So i installed a new one and check the charging and it is around 10 volts.
don17x is offline
post #4 of 10 Old 10-16-2009, 11:01 PM
johndeere's Avatar
Images: 7
Should have 12 directly from the battery without it running?So if its 10 and the battery has a full charge its a bad battery.
post #5 of 10 Old 10-16-2009, 11:34 PM Thread Starter
When it's running the charging system only puts out between 9.6-10 volts.
don17x is offline
post #6 of 10 Old 10-16-2009, 11:42 PM
johndeere's Avatar
Images: 7
What does it put out not running?
post #7 of 10 Old 10-18-2009, 11:48 AM Thread Starter
Not running the battery has 12.5 volts. But when it's running the volts gauge is on 10 volts. I checked it with my multimeter and its between 9.6 and 10 volts. With the same battery in my other tractor running my multimeter says 13.2 volts.
don17x is offline
post #8 of 10 Old 10-18-2009, 01:58 PM
grnspot110's Avatar
Images: 21
Start engine. Remove3-prong connector from regulator. Use AC voltmeter to check outer two wires (from stator). Check at full speed (no load), you should get 28 to 32 volts (AC). If voltage is sustantually below 28 volts AC, the stator is bad.
If you get more than 25 to 28 volts the stator is OK,the regulator must be bad!
My 69-140 had a 10 AMP system, with a bad stator. I was able to get a used 15 AMP stator & flywheel & new regulator off Ebay to replace the system.
Not sure what serial number they changed to the newer 15 AMP system. ~~ grnspot110
John Deere: 1953-40S, 1970-70 I, 1980-314, 1993-755 w/60" deck, 2000-F725, 2004-790 w/300 Loader, 1980-Power King 2418 & 2007-"TS" Gator. & 1980-4' x 8' Snowco Trailer
grnspot110 is online now
post #9 of 10 Old 10-18-2009, 04:10 PM Thread Starter
O.K. i just checked and the voltage went as high as 38.2. So does this mean my voltage regulator must be bad? I just don't want to buy parts i don't need. Thanks Don
don17x is offline
post #10 of 10 Old 10-18-2009, 08:55 PM
grnspot110's Avatar
Images: 21
There are people here who know more than I do, but it sounds like it's the regulator, or a loose connection some where! The new one I bought was from EMS (Electric Motor Service), 800/697-6070. If I remember right, it was around $40.
