John Deere 212 Tranaxle humming. - Page 2 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #16 of 49 Old 09-13-2009, 12:07 PM
TheEdge's Avatar
Re: John Deere 212 Tranaxle humming.
Originally Posted by JakeBlues652 View Post
is it hard to get to the upper plug? i'm guessing the hitch plate needs to come off to refill. how much does it hold so i know how much to buy?
easy to get at, it is toward the front of tranny(not at way top) so you dont have to take hitch plate off. I use a funnel that has a hose on the bottom(bought it at wal-mart) and put the hose down thru the hole where you shift gears and right into tranny. Dont remember exact amount.. Ill look it up though.
2008 JD X540 w/54x deck, Triple bag powerflo
1979 JD 214 w/47 deck, 37A Snowblower
1969 JD 112 w/39 deck, JD 15gal. mounted sprayer
JD 10 cart
JD 7 cart
TheEdge is offline
post #17 of 49 Old 09-13-2009, 06:27 PM Thread Starter
JakeBlues652's Avatar
Help Re: John Deere 212 Tranaxle humming.
is it mis-communication or do i need to unbolt the shifter? i will go look at it in a bit to see what i can see without taking it all apart. This is one thing i wished i did when it was all apart. Thanks everyone for the suggestions so far too!
Proud Owner and operator of:
1985 John Deere 212
2010 Polaris Sportsman 500 H.O.
1999 Chevy Silverado 2500 6.0
1967 Chevy C/10 4x4 5.0 with a 3" lift and 35's
2000 Chevy S-10 with the MASSIVE 2.2
I'll keep my guns, freedom, and money.
You can keep the 'change.'
-Hank Williams Jr.
JakeBlues652 is offline
post #18 of 49 Old 09-13-2009, 07:48 PM
Collector of many tractors
Kbeitz's Avatar
Lower fender vibration...
Kbeitz is offline
post #19 of 49 Old 09-13-2009, 07:52 PM Thread Starter
it dosen't sound like a rattle or vibration or anything. it is a loud annoying hum. i will take a video with my cell phone tomorrow or tuesday and try to put it on here and if not i'll make a youtube. i just don't want it to get worse and have a real mess on my hands while plowing this winter. Snows coming and theres no way to stop it!
1985 John Deere 212
-Hank Williams Jr.
post #20 of 49 Old 09-13-2009, 08:55 PM
TheEdge's Avatar
No, do not unbolt shifter. just run tube along side shifter gate and down into upper drain plug hole
JD 10 cart
JD 7 cart
TheEdge is offline
post #21 of 49 Old 09-13-2009, 09:07 PM
10K and Climbin!
WNYTractorTinkerer's Avatar
Images: 14
A changing noise like you describe may be a bearing changing it's tune under load.. if it gets loud and obnoxious then call on "Elwood" (couldn't resist!!) to use a mechanic's stethescope to listen to it after you jack/block it up to determine where the racket is coming from..
Can You see the Real me?
WNYTractorTinkerer is offline
post #22 of 49 Old 09-13-2009, 09:40 PM Thread Starter
oh boy. sounds like that can get pricey. any other way to check the bearings or whatever to find out where its coming from and i looked today and i didn't see a pulg but i didn't go fishing down there either.
1985 John Deere 212
-Hank Williams Jr.
post #23 of 49 Old 09-14-2009, 05:25 PM Thread Starter
View My Video
Heres a video where you can hear the humming good. Bad quality but deal with it, it was my cellphone.
1985 John Deere 212
-Hank Williams Jr.
post #24 of 49 Old 09-14-2009, 06:04 PM
Titanium's Avatar
That cotton picker is loud!
Check the level, and change that transmission oil!
Retired from the rat race... the race was fixed by the rats!
Titanium / Dave
Titanium is offline
post #25 of 49 Old 09-14-2009, 08:29 PM Thread Starter
thats not loud!!!! its a single cyl kohler and i have a craftsman with a twin B+S and its 2 or 3 times louder!!
1985 John Deere 212
-Hank Williams Jr.
post #26 of 49 Old 09-15-2009, 07:48 AM
chvymn99's Avatar
There is a little noise that sounds a little louder, but that humming sounds is just the variator system noise. Mine makes that noise, bearly audible when going slow and the faster I go the more it hums/whines. It gets really audible when I am in second and the last notch on the variator shifter. If its a problem, then I'll have something to learn too.
chvymn99 is offline
post #27 of 49 Old 09-15-2009, 03:34 PM Thread Starter
Do you really think its the variator?!? I didn't think it would be because like if you go over a bump it will stop for a second and then start again so i pretty much ruled out all of the components.
1985 John Deere 212
-Hank Williams Jr.
post #28 of 49 Old 09-16-2009, 06:23 AM
ex spelling bee champ
Ingersoll444's Avatar
Images: 14
Not that uncommon for those trannys to make a little noise. Do the fluid change first. Its easy. I used synthic gear lube in my 112. Mine was a little noisy before, and did quite down some.[granted the fluid had not been changed in.... ahhh... ever. ] After that you can work to narrow it down. Might also be a idel pulley bearing making a noise.
Paul B
SUPER Of The Month 10/2011
Ingersoll444 is offline
post #29 of 49 Old 09-16-2009, 06:13 PM Thread Starter
do you really think its bearing noise? usually bearing just sound dry, i've never heard one like that! I'll check out the pulleys tomorrow. And did anyone ever say how much the transaxle holds?! I want to know that so i don't drain it out and end up going to NAPA a dozen times!!
1985 John Deere 212
-Hank Williams Jr.
post #30 of 49 Old 09-17-2009, 06:59 AM
Images: 14
Well I belive the 200 series, and my old 112 take the same tranny... I got two bottles of gear lube, and did not use them all. So.. about 1 1/2 bottles
Paul B
