Steering adjustment in my 316 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 4 Old 07-12-2009, 01:00 PM Thread Starter
JimC_Vt's Avatar
Hello Folks, While I have the motor on the bench (Telescopic Cylinder gauges have been ordered) I was wondering if there is a procedure to tighten up the steering gearbox on my 316 ???? It has a little slop in the wheel,nothing major ,but it could use some adjusting! Thanks ,Jim
JimC_Vt is offline
post #2 of 4 Old 07-12-2009, 01:26 PM
Super Duper Member
saleen49's Avatar
Re: Steering adjustment in my 316
If the set up is similar to the steering box on a truck, you want to make 1/8 to 1/4 inch adjustments until the play is gone. The only tractor I that I had to adjust was the JD 100 that I restored. It threaded in from the bottom of the shaft. I used this method to tighten it up.
1983 318.
2009 X729 with 54" deck & 54" blade, oh and 45 loader
__________________________________________________ __
"I have not failed. I've just found 10,000 ways that won't work." Thomas A. Edison
saleen49 is offline
post #3 of 4 Old 07-12-2009, 01:35 PM
Super Duper Member
saleen49's Avatar
I meant to say 1/8 to 1/4 turn adjustments on the jam screw.
1983 318.
saleen49 is offline
post #4 of 4 Old 07-12-2009, 03:08 PM
JD Green all the way~!
GR8racingfool's Avatar
I played with mine on my 300. I had to remove a cotter pin from the bottom, and then turn the entire bottom plug/piece a little bit, then line the splines back up, and reinstall the pin. It helped some, not much.
So, read the manual, and it said there were adjustments on the sides of the steering column. Removed the battery, the battery tray, and played with that some, better, but not perfect.
I have slop where you can turn the wheel left or right, before it even moves the front wheels. But all the adjustment I did, made the steering firmer, but easier. The slop is what drives me kinda nuts. But I cant get it any better, unless I am doing everything wrong, or there are some severely worn parts inside the gear box that need to be replaced.
~F~
GR8racingfool is offline
