Hooking up to the hydraulic control valve (help) what else do I need - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 7 Old 03-28-2008, 07:40 PM Thread Starter
425 AWS owner
JD Power's Avatar
Images: 7
How or what do I need to hook up the BM17347 Front Hitch??? What fittings I have two female on the hitch
-Greg
'96 John Deere 425 AWS
'84 Massey Ferguson 210 w/front loader 216
w/attachments
--backups--
'94? Toro Groundmaster 445-D
'90? Jacobsen Turfcat II DW 224
JD Power is offline
post #2 of 7 Old 03-28-2008, 07:45 PM
9K+ Poster
JDFANATIC's Avatar
Re: Hooking up to the hydraulic control valve (help) what else do I need
JD,
You need the hydraulic coupler kit. I'm not sure of the p/n, but will check.
Cheers
JDFANATIC
JDFANATIC is offline
post #3 of 7 Old 03-28-2008, 10:34 PM Thread Starter
425 AWS owner
JD Power's Avatar
Images: 7
this ? if so how would install it with out draining the fluid
-Greg
w/attachments
--backups--
JD Power is offline
post #4 of 7 Old 03-29-2008, 09:03 AM
9K+ Poster
JDFANATIC's Avatar
Yes,
I've never installed one, but I'll bet you don't spill that much and can just top off what was lost. Then again, it may be a good excuse for a tranny fluid change.
You might want to pm Unit40 as he just went through this on his post which is something that goes along with the couplers: Relief valve installed today !!
Cheers
JDFANATIC
post #5 of 7 Old 03-29-2008, 11:02 AM
Banned!
Fluid loss is next to nothing as long as none of the spool valves are pushed in either direction. Just remove the plugs, screw in the appropriate quick-coupler half and tighten them. Don't forget to use thread sealant.
You can check your fluid level after but you won't be adding anything.
Caseguytoo is offline
post #6 of 7 Old 03-29-2008, 11:14 AM
bruce56bb's Avatar
jd power, i installed a blade with the angling cylinder this week on my 425aws. the part #for the 4 coupler kit is BM17763.
there is not much oil that drains from the ports when you remove the plugs.
bruce
JD 425 AWS, Husky 346XP and 51, EarthStove 2800HT
bruce56bb is offline
post #7 of 7 Old 03-30-2008, 11:48 AM Thread Starter
425 AWS owner
JD Power's Avatar
Images: 7
thanks for all the info and help/part numbers
-Greg
w/attachments
--backups--
JD Power is offline
