using the landscape rake - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 15 Old 01-14-2008, 09:28 PM Thread Starter
2Lazyt2's Avatar
OK, I broke down and rented a landscape rake. Got it hooked up to the 3 point and off I went to play in the dirt.
So, I start trying to rake the stone debris out of the dirt around the house left by the builders. I set the rake down into the dirt about an inch and very shortly I'm digging a lot of dirt. It's real sandy and dry and should just fall through the tines but it doesn't. It piles up in the rake and pretty soon I have a trench across my property and lots of stones left behind!
I have the thing set pretty level. Should I adjust top link to give it less angle on the tines? Also, I have a 2320. I can't find anything in the manual that explains how to use the dang 3pt other than simple up and down. Is there a float position and would it work on a rake?
2Lazyt2 is offline
post #2 of 15 Old 01-14-2008, 09:49 PM
Anything With Wheels
Argee's Avatar
Re: using the landscape rake
Set the rake so it barely touches the surface when down...that way you'll grab the stones and leave the soil.
Randy G
Argee is offline
post #3 of 15 Old 01-14-2008, 10:20 PM Thread Starter
2Lazyt2's Avatar
Well, I tried that too and it wouldn't pick up the rock. To make matters worse, after screwing around out there for a while, I had the whole place so lumpy with piles of rock and sand and leaves, I couldn't keep the rake level enough to do much of anything except make it worse.
2Lazyt2 is offline
post #4 of 15 Old 01-14-2008, 10:40 PM
ccsial's Avatar
Location: Northern IL 30 mi NW of Rockford, IL in farm country
Gauge wheels are pretty handy for this work. I added them to my rake. Otherwise I had to go real slow and keep adjusting.
Your 3PH should float up but not down. I'm not aware of anyway to make it float both ways.
JD X748SE - Kubota L3400HST - Ford 1910 4WD FEL
ccsial is offline
post #5 of 15 Old 01-14-2008, 11:09 PM Thread Starter
2Lazyt2's Avatar
If I drop it all the way down with the control lever, is that the float position?
2Lazyt2 is offline
post #6 of 15 Old 01-14-2008, 11:35 PM
Argee's Avatar
Yes....as long as you don't have draft control. But that's not going to help...as you're going to fill it up again...it's just the nature of the beast. Try angling it while just keeping it touching until you can get the lumps flattened out.
Randy G
Argee is offline
post #7 of 15 Old 01-15-2008, 02:03 AM
9K+ Poster
JDFANATIC's Avatar
2lazyt2,
3PH float is the weight of the implement. I don't know how big of a landscape rake you are using, but it probably has enough weight to start digging into the soil. As pointed out, gauge wheels make all the difference (expensive option but worth it), other than that, you need to keep playing with the position control.
Cheers
JDFANATIC
JDFANATIC is offline
post #8 of 15 Old 01-15-2008, 07:53 AM Thread Starter
2Lazyt2's Avatar
Yep. All good advice. Thanks. I hear the rain just started. Oh well. It's gonna be an interesting day today. Got about 6 hours left on the one day rental. My main objective for renting was to see if I should buy one. Considering how long it took yesterday to make a genuine mess of my front acre...... renting is no option.
2Lazyt2 is offline
post #9 of 15 Old 01-15-2008, 08:25 AM
Argee's Avatar
If you decide to buy one, consider one that is a foot wider than your tractor....that way when you angle it, it will cover your tire tracks.
Randy G
Argee is offline
post #10 of 15 Old 01-15-2008, 01:28 PM
Citizen of Earth
bontai Joe's Avatar
The one I rented was not a 3 point, but a simple pin hitch connection and had gage wheels. Used just it's own weight and worked very well. I went from the outside edges of the yard and raked toward the center until I had a single "windrow" of rocks and stones. Then I shoveled them into a cart.
If it's FREE, it's for ME!
bontai Joe is offline
post #11 of 15 Old 01-15-2008, 02:23 PM
Argee's Avatar
I have a 7' unit I use on my tractor which is 5' wide.
I have this unit that I pull behind my GT5000. It's 48" wide but is available in 60" and 72".....I wish that I would have gotten the 60". My GT is 36" wide.
Randy G
Argee is offline
post #12 of 15 Old 01-15-2008, 05:29 PM
10,000 +posts!
Would those rakes work well for leveling also?
Agree thats a nice looking ford you have there..Is that your garden space in the picture?
Team_Green is offline
post #13 of 15 Old 01-15-2008, 05:36 PM
Argee's Avatar
The 3PH one works fair for leveling. The pull behind works great.
Thanks for the compliment and yes that's one of my garden spaces.
Randy G
Argee is offline
post #14 of 15 Old 01-15-2008, 05:42 PM
Dude11's Avatar
These are called "rock rakes"around here and if you angle it as some said it works great for leveling crush run type driveways.I used one on another home once owned with Longgg rock driveway.Angled that boy to the center on both sides then just barely hit the top down the middle.Works great!!I'm pretty sure the angle thing is the best bet any where you use it yards,fields,etc.Good Luck,Dude11
Dude11 is offline
post #15 of 15 Old 01-15-2008, 06:26 PM
escavader's Avatar
Ive rigged up a quick hitch that easilt attaches to my loader bucket.Here is a pic of my rake up front instead of on back
ALAN
Name:	100_1627 (671 x 447).jpg
BX-23 TLB,LOADED AG TIRES,MECHANICAL THUMB,BUCKET FORKS ,FRONT BUCKET QUICK HITCH,REAR 3 POINT QUICK HITCH,WOODS 5 FOOT RAKE,6FT TSC BLADE,SALSCO 600 CHIPPER, MARKHAM TOOTHBAR,BACKHOE TRAILER HITCH,HOME MADE HEATED CAB,PRONOVOST PUMA 54 SNOWBLOWER WITH HYDRAILIC CHUTE CONTROL
escavader is offline
