John Deere 445 FD620D engine rebuild after seize - Page 4 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #46 of 322 Old 11-25-2013, 11:06 AM Thread Starter
DanielRaible's Avatar
Re: John Deere 445 FD620D engine rebuild after seize
Oil screen - pretty clean.
DanielRaible is offline
post #47 of 322 Old 11-25-2013, 11:23 AM Thread Starter
In the foreground is the one sizable metal shaving found hiding under the oil screen. We'll keep our eyes open for where that might have come from as we go.
post #48 of 322 Old 11-25-2013, 11:52 AM Thread Starter
Extracted 16 plastic oil pump gear teeth and 8 discernible metal shavings from the bottom of the crankcase.
Shot both cylinders and the output shaft bushing with PB Blaster again. Might need to manually rotate shaft a bit to remove connecting rods, but I don't want to do any further damage if there are metal particles bound up in the cylinders or bushing...
post #49 of 322 Old 11-25-2013, 03:46 PM
VT JD's Avatar
DanielRaible,
Great thread!
I am watching with interest as I also have a 445.
Good luck with the rebuild and keep the pics coming.
VT JD is offline
post #50 of 322 Old 11-25-2013, 04:36 PM
dyt4000's Avatar
Images: 12
Originally Posted by home-boy View Post
That looks pretty clean. Last 425 engine I had was a black blob
How many hours did the 425 have on it and what caused it to fail?
1957 IH Cub Lo-Boy
1959 Ford 631 Workmaster
1967 Wheel Horse 857
2001 John Deere 425 3 point lift, rear PTO and Heavy Hitch with trash can option
dyt4000 is offline
post #51 of 322 Old 11-25-2013, 05:27 PM
4K poster & climbing
burned300's Avatar
Images: 14
This is one of the best theads ever! A lot of us Kawasaki owners here.
2002 X485 Cat 0 three point, Click n Go, Snow Blade, 62C mower deck, anti blow out kit
2004 X595 Cat 1 three point, Click n Go.
Gannon graderbox
#40 EZ Rake Vac
#40 EZ Rake Vac for parts
1977 MTD 990 Parts Tractor
Ohio Steel yard cart
Brinly cat 0 plow
Deere I've owned, 110 140 160 210 212 214 216 300 316Onan 420
burned300 is online now
post #52 of 322 Old 11-25-2013, 06:07 PM
Loving my Deeres
techie1961's Avatar
Images: 3
What's the going rate from the Tooth Fairy for those? Gotta get some help in the finances don't ya.
Lorne
My century barn that I'm making into a Deere stable and work shop.
1999 John Deere 455 AWS with Ruegg cat 1 3PH (don't tell the others but this one's my favourite )
1997 John Deere 455 AWS
2001 John Deere 445 AWS
1994 John Deere 425 2WS (Sold)
60" mower, 60" mower, 60" mower with JD Mulch Kit, 54" Mower, MC519 and Powerflow, 47" Snow Blower, 54" blade with bucket add-on (Plucket), 54" blade, 54" blade, 51" Broom, and garden cart
John Deere 314 (Sold)
Grew up with a John Deere 140 and all the goodies
techie1961 is offline
post #53 of 322 Old 11-25-2013, 07:28 PM Thread Starter
The full oil pump assembly kit is no longer offered, but there are still a few floating around.
The gear alone is $4.75, and I would gladly pay multiple times that amount for a metal replacement.
Lost some time today running for tools.
post #54 of 322 Old 11-25-2013, 08:53 PM
Don't worry about the cylinders, they'll be fine. The cylinder and piston require almost no lubrication, especially on a liquid-cooled engine. Look for a cooked rod or main bearing. It might also be useful to find out what caused the gear failure if you plan to reuse the oil pump. Your pictures also point out the fallacy of periodic carbon removal- look how clean that engine was running.
rscurtis is offline
post #55 of 322 Old 11-25-2013, 09:23 PM
I'm wondering if perhaps the stripped teeth of the gear got lodged or bound up causing the lock up rather than something seizing up.
F350ctd
1999 JD 455
1981 JD 317 w/Onan P218G
1986 Ingersoll 446 w/B43, 3pt.
'13-'14 Winter project: Adapt AC sickle mower to 446
93 F350 4x4 w/97 5.9 Cummins
1981 IH 684 w/D239, FEL, misc 3pt attachments
Cub Cadet 123 - sold
Cub Cadet 1250 - sold
f350ctd is offline
post #56 of 322 Old 11-26-2013, 03:22 AM
Daniel, have you considered talking to a machine shop about fabricating a steel gear? Perhaps it is cost prohibitive, but then the engine is very valuable as well. CNC machines make quick work of complicated parts especially if they can copy a new plastic part. One problem with a steel gear is that the thermal expansion may be substantially different than the plastic. Larry
retsparky is offline
post #57 of 322 Old 11-26-2013, 03:28 AM
jar19800's Avatar
Images: 32
it IS costs prohibitive. most CNC shops charge $100 per hour for PRODUCTION.
my shop is over 500 per hour. that piece will take about 10 hours to reverse engineer and about 10 hours to make a 1 off model.
it is cheaper to go BUY it from the OEM.
that is just my .02 cents...
results may vary....
a few of my prized possessions
Craftsman GT6000: 26HP HG730 hydro. 54" mower, bagger, blade, sleeve hitch, plow, cultivator, disks, back blade, cart.
1986 John Deere 318: currently in pieces. Mower, 3pt, front and rear weight racks, Sleeve Hitch adapter, 54" 4way blade.
1981 John Deere 216: Tiller, blower, hitch and helper
1977 John Deere 400: 60" mower,home made dozer blade, 3pt carryall, and spare set of loaded Ag's yea i went there
1964 John Deere 110: Mower, Hitch, helper spring, narrow wheels original tires
2015 1025R with D180 loader I match and whatnot plus powerFlow D.O.D.
Cheers
jar19800 is offline
post #58 of 322 Old 11-26-2013, 05:11 AM
10K and Climbin!
WNYTractorTinkerer's Avatar
Images: 14
Exclamation Re: John Deere 445 FD620D engine rebuild after seize
Personally I'd pull the crankshaft and make sure all of the oil passages are clear!!
Can You see the Real me?
WNYTractorTinkerer is offline
post #59 of 322 Old 11-26-2013, 05:13 AM
10K and Climbin!
Images: 14
Lightbulb Re: John Deere 445 FD620D engine rebuild after seize
Mic the Piston skirts as they wear down perpendicular to the wrist pin.. (They did on mine!) Tolerances are tight in the Kaws so better safe than sorry..
post #60 of 322 Old 11-26-2013, 07:57 PM Thread Starter
This is an excellent point. Unfortunately I do not have the resources to cut a metal gear here, or I would seriously consider it. If I was still in school this would immediately become one of my 'spare' projects when I had access to machinery.
I asked a few of my machinist friends, and they basically said I can't afford to have someone else do it for me.
My plan is replacement of both plastic gears. The dealer mentioned that the only oil pump gear he has seen fail in these is when the cam gear was upgraded and the plastic pump gear was not replaced at the same time.
