SAE 30 or 10w30 Mobil1 for Kawasaki Air Cooled? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 9 Old 06-12-2007, 08:17 PM Thread Starter
Which Mobil 1 oil is best for the Kawasaki air cooled engine in our John Deeres?
GrassMaster is offline
post #2 of 9 Old 06-12-2007, 10:38 PM
A semi-retired senior cit
Mower_Man42's Avatar
Images: 3
Re: SAE 30 or 10w30 Mobil1 for Kawasaki Air Cooled?
10w30 after 50 hours of break in, IMHO it`s over kill. Just run a good grade of motor oil. Got over 340 hours on my 15 hp Kawa. and it starts on the first pull ever time. Never have to add a drop of oil between the 50 hour changers.
_________________________________
1985 Lawn Boy commercial Model 8453
1991 Toro Re-cycler 3 speed model 20218
2005 John Deere G110/54" deck
2008 Cyclone Rake Command Pro
1981 Wheel Horse C-85 with snow plow
1969 Case 444 PK with 44" mower deck
2009 Honda HRX hydro Drive 21" Versamow system.
2006 Scag Wildcat 52" cut 25hp Kawasaki
Mower_Man42 is offline
post #3 of 9 Old 06-12-2007, 11:53 PM
dlstelma's Avatar
I believe the owner's manual has the recommended viscosities depending on temperatures.
dlstelma is offline
post #4 of 9 Old 06-13-2007, 07:42 AM
USMC
slkpk's Avatar
Images: 21
I ran Mobil 1, 10w30 in my X585SE year round and really liked it. Easier starting in the winter and ran cooler in the summer. slkpk
1964 JD RF110 Restored
2007 JD 2305
slkpk is offline
post #5 of 9 Old 06-13-2007, 12:14 PM
JMC
JMC's Avatar
Images: 5
Best to do what the manual says, as far as oil weight goes. If you upgrade to synthetic, that's entirely up to you.
JMC
JMC is offline
post #6 of 9 Old 06-13-2007, 12:38 PM
mwood's Avatar
Images: 3
As long as it's under warranty, I'm leaving it with what they ask for. I'm also using JD Oil. Better safe than sorry...
As always, just my opinion!
13.5 Acres in Upstate NY -- [John Deere LA130 w/ 48" deck] [John Deere 216 w/ 46" deck, front blade & snowblower (In need of engine work)] [Husqavarna 323L string trimmer w/ brush blade] [Echo PB-251 Leaf Blower] [Husky (MTD) 21" push mower] [Bolens 6.5 HP Front Tine Tiller] [Agri-Fab poly dump cart, de-thatcher & lawn sweeper]
mwood is offline
post #7 of 9 Old 06-13-2007, 01:35 PM
Bikes/Tractors what else
danbike's Avatar
I recently changed from the JD oil to Mobil 1. Don't know if it makes a big difference, but a less than 2 quarts it makes me feel better. PS>>I'm convinced that my X585 runs quieter.
JMC
2005 JD X585
2011 Triumph T100
1967 Triumph TR6R-all original and gone to a new home
19XX VESPA PX200EFL
1964 Vespa GL(oldest original owner Vespa in the US)
danbike is offline
post #8 of 9 Old 06-13-2007, 04:19 PM
unit40's Avatar
Oils and engines have evolved over the years. In the past you needed straight 30W oil. The use of muli-visc oils wasn't recommended because of excessive oil consumption. In some engines even today that still hols true. But you will find that now many engines give a temperature and viscosity range for you to help determine what type of oil to use. I think a multi-visc oil is a better choice, and that is what I would use. I would change the oil for the winter, and then change it for the spring/summer/fall. Quick thought, why do many auto/truck engines use 5-30 year round, when the temp.range for 5w-30 only goes so high?
unit40 is offline
post #9 of 9 Old 06-14-2007, 07:58 AM
Amsoil has a 4 stroke 10W-30/SAE 30 that is specifically for small engines. I have it in my Lt160 and my Dad's X540.
http://www.amsoil.com/StoreFront/ase.aspx
cheez is offline
