JD 425 box blade question - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 17 Old 03-14-2007, 01:41 PM Thread Starter
Hey Folks,
Please bare with me ... I have several inputs/questions.
Has anyone ever seen or used a small box blade with a JD 425?. If so how did it work for you?
Another person said you could put one on the 425 HOWEVER the JD attatchment capability chart doesnt show you can.
The JD dealer offered to sell me a cat o blox blade BUT he never had heard of anyone putting one on the 425.
SO ... with out talking to someone who has actually placed a box blade on a 425 with out wrecking the transmission or engine ... I'm mighty leary about doing it.
Thanx!! in advance for any help
Rick
1964 JD 3020 Diesel Power Shift/F-11 Farmhand Loader/8ft Snow Bucket/5ft Kingcutter Field Mower/62in Howse Tiller/Three Point Post Hole Digger ... Sold
1998 JD 425/48in Mower/Ruegg 3 Point/Iron Man 4ft BB/Beromac 4 ft Snow Blower/Beromac Cab/WW Filled 26-12-12 Carlisel HD Field Trax Tires/70lb Wheel Weights
2008 Jinma 284 Shuttle Shift/Factory Loader
Rick ND is offline
post #2 of 17 Old 03-14-2007, 02:25 PM
Citizen of Earth
bontai Joe's Avatar
Re: JD 425 box blade question
Here is a thread from www.weekendfreedommachines.org that shows a 332 with a loader and box blade on it:
http://www.weekendfreedommachines.or...335/84864.html
I have seen box blades on the old Deere 140 GT and would think that the heavier duty 400 series could easily handle one.
If it's FREE, it's for ME!
bontai Joe is offline
post #3 of 17 Old 03-14-2007, 02:34 PM
USMC
slkpk's Avatar
Images: 21
I had a 425 for 7 years and 860 hours and it's a tough machine. If I would have had the 3PH I would've had one on it. I see less heavier duty tractors on this forum and others using a BB. Don't see why the 425 couldn't handle it. slkpk
1964 JD RF110 Restored
2007 JD 2305
slkpk is offline
post #4 of 17 Old 03-14-2007, 06:57 PM
Sign up Today!!!
Mayor's Avatar
Images: 34
I think you would have traction problems long before any damage was done to the tractor. Thats just my thinking.FYI, I think my little 4ft box blade is under 300 lbs. I
JD 2305, 200CX, MMM, iMATCH, Weight Box, 826D Snowblower, Frontier Box Blade, Markham Welding Toothbar, Star Sprayer 3 point, Herd M96 Spreader 3 point, Trac Vac 3 point.
Projects: 12 Volt Sprayer, Weight Box, Toolbox
Mayor is offline
post #5 of 17 Old 03-14-2007, 08:09 PM
Bruceman's Avatar
Gannon made a Box Blade, and adapted it to work on several GT's, John Deere being one of them. There were 32, 36 and 42 wide with rippers!"
There are still a few around. I've seen them for sale on Ebay.
I have one that's 36" wide on a Sears GT16. Did I say it only has 16hp and does a great job. I have Ags and weights on it though. You would have no problems using one on yours.
Deeres guide probably doesn't list one because they don't offer a BB for the GT's.
Bruce~
Bruceman is offline
post #6 of 17 Old 03-14-2007, 08:17 PM
Rick - its a John Deere. You can't hurt it by using it. Did you get a 3 point, or how would you hook it up. If you have a hookup that allows down pressure, be forewarned that traction will be a problem.
old_nodaker is offline
post #7 of 17 Old 03-15-2007, 01:30 AM Thread Starter
Folks,
First; Thanx! for the info.
Second; A few questions for Old Nodaker.
I haven't bought a 3 point yet but that's what I was looking at.
Is there another way to mount the box blade?
What attachment gives you down pressure??
Do you have any weight suggestions?
As always ... thanx in advance for any/all replies
Rick
Rick ND is offline
post #8 of 17 Old 03-15-2007, 05:28 PM
Of course the 3 point hookup would be your best bet, just kind of expensive. 3 points generally don't have down pressure options, but just wanted to forewarn you, you can make something, using elect actuators or such, but build float into the linkage.
For weights you don't have a lot of choices with the 3 point. Wheel weights and/or fluid in the tires. Ag tires no doubt would help also but it all depends on what you're doing if you need all that. I pull two 60 inch tag along mowers just using wheel weights and turf tires, but the 445 has bigger rear tires which helps.
post #9 of 17 Old 03-15-2007, 05:36 PM
Sign up Today!!!
Mayor's Avatar
Images: 34
The only way to get down pressure is weight on the box blade. The more weight you add the less traction the tractor will have. Then you add weight to the tractor. This can go on and on till you find your perfect balance. Ag tires will help and do not fill up with mud like the turf tires.
Mayor is offline
post #10 of 17 Old 03-15-2007, 05:45 PM
Sign up Today!!!
Mayor's Avatar
Images: 34
This is a shot of my BB behind the tractor not hooked up but you can see the JD weights in the BB rails. Looks like I can fit 3 to 4 per side @42 pounds thats some weight. The weights are nice because you can take them on and off as needed.
This is the BB with out weights on it but hooked up to the 2305.
Some weights on the JD LX280 for traction with the bagger.
Mayor is offline
post #11 of 17 Old 03-16-2007, 09:34 AM Thread Starter
Folks,
First ... thanks again for the help.
Second ... My wonderful wife has given her full support in in this equipment purchase AS LONG as the box blade will ...
Dig out paths for us/me .. to install brick patios/walk ways; cut drainage swales; level the property and recycled asphalt driveway.
Please chime in if you think the box blade won't do the above CONSIDERING that a loader is out of my price range.
Lastly ... The JD dealer mentioned that the AG tires would tend to beat the lawn up and create a rougher ride.
SO I was wondering if anyone had experience/know the up/down side of with filling turf tires with fluid to create more traction.
Thanks in advance for any/all help
Rick
Rick ND is offline
post #12 of 17 Old 03-16-2007, 10:17 AM
USMC
slkpk's Avatar
Images: 21
Rick ND, I had the AG tires on my 425 and loved them. I found no need for chains in the winter using my FEL to push snow, they did NOT tear up the yard and the ride was not bad at all. The only thing you need to be careful of when triming and tight turns slow down or the AG's will cut into the yard, if you slow down no problem. slkpk
2007 JD 2305
slkpk is offline
post #13 of 17 Old 03-16-2007, 10:20 AM
USMC
slkpk's Avatar
Images: 21
Mayor, is that dirt I see on the floor board of that brand new tractor? Glad to see your using it. slkpk
2007 JD 2305
slkpk is offline
post #14 of 17 Old 03-16-2007, 10:26 AM
Sign up Today!!!
Mayor's Avatar
Images: 34
The box blade will do what your asking it to do. It would be nice to get rid of that wheelbarrow and have a FEL ready to go. Your going to need ag tires and weight. Try the weight first and see how it works. You can always have rear ags mounted on rims and switch the turfs out in the winter if your going to do some box blade work. It's easy for us to spend your money but just wanted to put it out there. Sounds like your on the right path.
Mayor is offline
post #15 of 17 Old 03-16-2007, 10:37 AM
Sign up Today!!!
Mayor's Avatar
Images: 34
Why yes, I belive it is. Will have to get right on that. If I had a few pictures of her when she was stuck in the mud last week you would die. Had to get the power washer out to get the mud off. I don't mind getting her dirty but always put time aside for clean up. We are going to have a long relationship so I better treat her right. Here is a shot I just took. Got her in the garage from the shed to take care of the snow storm that's coming. Put the box blade on for weight. I am kind of off today due to my sales meeting being canceled. Paper work day got to love it.
Mayor is offline
