D140 w/ 1.6 hours - Smoke on Startup??? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 9 Old 06-24-2013, 06:40 PM Thread Starter
troymi's Avatar
Ok, I didn't find anything "just" like this so I'll ask the question. Is it normal for a new (almost) D140 to smoke like this when started?
Anything I should be doing when seeing this? Thanks for advice and experience. Otherwise, everything is working great.
Ok, I'm not as good as I thought. I took a video of the smoke at startup because it did it last time also. But, the file is too huge to upload. So I took a screen shot of it paused.
2013 John Deere D140 (Vince)
troymi is offline
post #2 of 9 Old 06-24-2013, 06:58 PM
jd2007's Avatar
Re: D140 w/ 1.6 hours - Smoke on Startup???
An little smoke at start-up is normal when the choke is used.
John Deere 757, 345, GS45, & JX75
MTF Tech Exchange Articles
jd2007 is offline
post #3 of 9 Old 06-24-2013, 07:07 PM
Frame Swapped '88 322
JohnDeere318Guy's Avatar
Images: 21
The rings probably haven't fully seated yet, it will diminish as it gets more hours on it.
-1999 John Deere F1145 -28HP Yanmar Diesel-72'' Deck-4x4
-1989 John Deere 318 -18HP Onan P218G-On Loan to MichaelTJD60
-1987 John Deere 318 -18HP Onan P218G-46 Deck-54 Blade-Wheel Weights-Chains
-1988 John Deere 322 -18HP Yanmar Liquid Cooled Gas-Frame Swapped
-2009 John Deere LA115
JohnDeere318Guy is offline
post #4 of 9 Old 06-24-2013, 07:27 PM
LA125
While it's doubtful it'd be the same problem I had, it's an easy fix if it is.
My '08 LA125 with 98HRS was smoking while mowing and at startup. It turned out being a blown head gasket. I got it fixed easily in one night. Think it was about $12 at the dealer for both gaskets needed. Just looked online for how to videos posted on youtube and did it all myself.
Basstracker34 is offline
post #5 of 9 Old 06-24-2013, 07:27 PM
Proud JD Owner
Mach-1's Avatar
You have warranty. Let the engine break in some and it should get better. Some smoke upon startup is normal. When my Poulan has been sitting for a few days, it will smoke for the first few minutes of running. No biggie.
___________________________________
2008 X720 Ultimate
54" Blade
47" Snowblower
Powerflo Bagger
Mulch Kit
#18 Dump Cart
Mach-1 is online now
post #6 of 9 Old 06-24-2013, 10:02 PM
On my X320, I found startup continues to get easier and cleaner. After 3 yrs and 138 hours, startup is smokeless I agree you probably just need the engine to break in and the rings to seat.
Sent from the MTF Free App
forum009 is offline
post #7 of 9 Old 06-26-2013, 06:49 PM
L120/G110 Hybridizer
ryanpf's Avatar
Congrats on your new D-140. That's an excellent machine for its intended purpose.
I'll offer you my experiences with my Intek twin, similar to yours, and now almost 10 years old. It has 425+ hours on it. Sometimes it smokes on startup but most times not. A hot start will NEVER blow smoke. When a cold start does smoke, it is just a brief event. Never noticed any drop in oil level, and the engine doesn't use oil between changes (~ yearly and 50 hours). The commonly accepted explanation is that the vertical shaft engines will draw a drop or two of oil into the cylinder on shutdown, depending on where the piston stops in the bore. I can buy that and it seems to fit with my experiences.
The other possibility is overfilling the crankcase oil. Then it will smoke on every startup and MAY smoke while running until it burns it down to a useable level. Since it's new, the dealer may have slightly overfilled during prep. For reference, there's about 8 oz between FULL and ADD, so it can get pretty low before you need to worry. There's 64 oz in a full oil change.
I'd give it a few more hours to break-in then revisit the issue. Check the oil level regularly to make sure there isn't a major problem lurking under the hood.
HTH,
Paul
Massey GC1710 - A little red diesel with a loader in front, a backhoe in the rear and a big smile in the middle -
John Deere L120/K66 with Berco 30" tiller, John Deere 44" Snowblower, Johnny Products Sleeve Hitch and
JB Jr bucket. Plus Brinly-Hardy 10" plow, 7-Tine Cultivator, 40" Plug Aerator, 40" Dethatcher, E-I-E-I-O...
ryanpf is offline
post #8 of 9 Old 06-30-2013, 10:19 AM
JD 112, 37A snowblower
CitizenCS's Avatar
I have a new one with a few hours on it. It did start some smoke at start up but I am not too concerned.
One bonus on buying a new one... My wife has mowed the last two weeks!
past JD rides: 4020,3020,4430,8640
CitizenCS is offline
post #9 of 9 Old 07-01-2013, 02:01 AM
Forgot to mention. When my X320 was new, it was hard to start, and it smokes in cold start. I was a little concerned but didn't do anything about it. Now, it starts cold and hot smokeless, hot start is instantaneous, cold start takes about 1-2 sec. I know we have different engines, but I think breaking-in is the key.
forum009 is offline
