Deere Garden Tractor Loader Owners - Page 3 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #31 of 45 Old 06-06-2013, 01:44 PM
VALurker's Avatar
Re: Deere Garden Tractor Loader Owners
Originally Posted by GotDeeres View Post
Bigger tractors just requires a bigger idiot to destroy them.
Compact Loader
Attachment 325377
That was not me that did that!!
GotDeeres
That was so it would fit in a "compact" parking space.
I guess I shouldn't have tried that at home!
VALurker is offline
post #32 of 45 Old 06-06-2013, 03:19 PM
Garden Tractor Lover!
summers5's Avatar
I to am interested in what he tried to do.The 45 loader I bought indeed is built tough.To do all that wow!
1997 Sears GT 18.5hp"Kohler Magnum"
SplitFire Plugs
46" Deck PTO
Electric hitch Kit(moves deck too)
Sears grader blade
Ag-Fab Spreader
46" 2 stage SnowBlower
Weights and chain
2005 JD X485 25hp(SOLD)
2008 Echo-SRM230 Trimmer 22.8cc
2010 Echo-PB500T Blower 50.8cc
John Deere 2007 X748SE
54" Edge Deck
3 Point(Ruegg)Hitch Cat1
54" 4way Blade
Yanmar 3TNV76 1116cc 24hp(Yep! same as JD2305)
John Deere 45 Loader
summers5 is offline
post #33 of 45 Old 06-06-2013, 04:25 PM
Just John Deere
GotDeeres's Avatar
Images: 8
Well it has been raining here all day so I did this to keep myself entertained. I recently repaired my 455 hydro and have reread the TM again.
The THRV only protects the FORWARD side of the hydro. It does not protect the Reverse direction. The THRV is installed in the forward closed loop from the hydraulic pump to the hydraulic drive motor. I guess that is why it did not protect the rest of the hydro. Since there were damaged loader cylinders, the IRV did not protect that loop.
My SWAG (Scientific Wild *** Guess) is that the guy picked up an excessive load in the bucket. He lifted it too high and suddenly dropped the bucket. The return fluid to the hydro is SUPPOSED to be "pressure free oil" per the tech manual. By dropping the loader bucket, you create a two cylinder one stroke pump. The return oil is now a high volume high pressure oil flow into the hydro. Apparently, it was high enough to damage something in the hydro. I always wondered why the return lines for some loaders had an in line restrictor on the return side. Now I think I know why.
Why did the loader cylinders fail? I could not find the specs for the cylinders, but the rockshaft cylinder is rated a 2000 psi. Let's just assume the loader cylinders have the same pressure rating. Dropping the loader bucket released the pressure in the cylinders, until the operator returned the SCV to neutral. The operator closed off any path for the oil in the cylinders to go. This happened just before the bucket hit the ground causing the remaining fluid in the cylinders to be pressurized by the falling weight in the bucket to a lot more that normal. This pressure is what damaged the cylinders. The IRV is out of the loop when the SCV is in the neutral position. So, it could not protect the cylinders. I believe you could do similar damage at 1000 psi with the right conditions.
Having said all of that, I cannot blame the shimmed IRV as the reason for the loader failure. Many owners have did this and I have not heard of this type of failure before. I expected it, but I am surprised it is not more common. Was it the cylinders or hydraulic hoses/lines? If the loader cylinders and hoses are rated for 2000 psi, the IRV being increased to 1250 psi should not be a problem. However, higher pressure may cause problems with the charge pump and other functions inside the hydro such as the lube oil and PTO. John Deere would definitely have the right to void the warranty on the hydro.
You ALWAYS want to carry the load in the bucket as low as possible or this could happen to you. Hills and loaders usually do not mix well. BTDT and have brown briefs to prove it.
Since this owner had a similar problem with a Kubota, I would say the failure was due to the operator not the equipment.
But that is just my opinion,
GotDeeres
Just John Deere
318 Garden Tractor
345 Garden Tractor with Piranah Deck
425 Garden Tractor with 54C Deck
455 Diesel with 60" Deck, 3 Point and 540 PTO
455 Diesel with Buford Bucket Compact Loader
2210 CUT with Buford Bucket Compact Loader
John Deere TS Gator
GotDeeres is offline
post #34 of 45 Old 06-06-2013, 06:28 PM
Nah, the "hydraulic" pressure can't get to the "hydro" section, other than the priming oil provided by the charge pump. Return oil from the loader goes straight to the sump(case).
Sent from the MTF Free App
Displaced Hokie is offline
post #35 of 45 Old 06-06-2013, 07:36 PM
15,000+ Posts & Climbing
Also, dropping the load like that puts the cylinder under negative pressure as it's going down since the pump flow can't fill the void fast enough. That might suck in some air through the gland, but it will still be restricted in rate of drop.
TUDOR is offline
post #36 of 45 Old 06-07-2013, 12:18 PM
Just John Deere
GotDeeres's Avatar
Images: 8
Tudor,
Like I said this was just a SWAG. You are correct about the negative pressure on one side, but since this is a dual action cylinder both chambers are closed with the SCV in neutral. Could the combination of the high positive pressure on one side and negative pressure on the other side damage the seals?? I really want to find out what was damaged in the cylinders or hoses.
Would you happen to know the PSI in the 455 hydraulic pump to the motor closed loop?? Seems like I read somewhere it was 1550 PSI. I repaired a hydro and checked the charge pump, but could not test the pump to motor loop. The TM does not address this issue. I know how I can test this pressure and just need to know what to expect.
Thanks,
GotDeeres
Just John Deere
318 Garden Tractor
John Deere TS Gator
post #37 of 45 Old 06-07-2013, 02:25 PM
Charge pressure is regulated @300 psi. Anymore and it could try to drive the hydro.
PTO circuit pressures are regulated to @ 175 psi.
Hydro loop pressures can be upwards of 10,000 psi, but I think usually @ 5,000 psi on this trand. I know many CUTS go into relief at 10K. No relief valves on any L&G TUff Troq trans - except for the spike limiter for the X7's with loaders.
Outboard hydraulic pressures are capped at @ 1200 psi.
post #38 of 45 Old 06-07-2013, 02:34 PM
I don't think there are any high pressure hydro loop test ports on these. There are on CUTS.
There is a test you can do to test the general condition of a hydro though. It is a pump/motor internal leakage (I.e. rotator group wear):
- plumb into charge port. More pressure.
- load hydro by pushing against a pole, tryin to pull something, etc.
- if charge pressure holds or dips only a little, the hydro has little internal leakage and wear.
- if the charge pressure drops considerably, there is wear.
The theory at work here is the more hydro pump or motor wear you have, the more internal leakage, and the more oil the charge pump must provide to keep the system primed.
A poor mans test is do you lose steering or lift when under a hydro load? If so, same thing is happening. All the charge pump oil is going to the hydro loop with little left for the steering or lift.
post #39 of 45 Old 06-07-2013, 03:06 PM
Maverick74's Avatar
Originally Posted by Displaced Hokie View Post
Charge pressure is regulated @300 psi. No relief valves on any L&G TUff Troq trans - except for the spike limiter for the X7's with loaders.
My X748 has the relief valve for the loader but it does seem to stall out when you overload it. It will stop forward motion.
My X728 did not have the loader or the valve and it seemed to pull no matter what it was loaded with as I had a box blade on that tractor many times.
Previous:
2008 JD X728
1998 Cub Cadet 2185 48" MMM 42" Snow Plow...RIP
Current:
2012 John Deere X748SE
3pt hitch, Rear PTO, 7 Iron, 54 Snow Plow, 647 Tiller,
45 Loader, Kwik Forks, iMatch, Heavy Hitch, Cyclone Rake Z-10,
Box Blade BB2048L, and Rear Blade RB2060L
Maverick74 is online now
post #40 of 45 Old 06-07-2013, 04:09 PM Thread Starter
Tech Exchange Moderator
Sergeant's Avatar
Well The reason I said Be careful with shimming your transaxle. Is shimming it You May try to Pick Up something You shouldn't. While the Loader May pick it Up You Might damage something else. Had the Guy Not shimmed it The Loader probably would Not Have even raised the Object Up more than a few Inches if at all and shimming beyond spec is Just a great way to Loose Deere covering the cost of any damage You might do to the transaxle( shim after Your warranty is Up) So Deere gets to use the fact that he shimmed it as a excuse not to cover the cost of the repair under warranty There still working out what Happened. But anyways they should be getting a New transaxle In today On there expedited order My Brother says they should Have it all Back to running condition by the Middle of next week ( The Owner is what we call up here a Gentleman Farmer He Buys the Machines But doesnít actually do any filed work) But went he does Do field work He usually does end up breaking something That is very costly to repair. As Far as My Brother Boss the Dealer. He Like the customer Because they Make a lot of Money on repairs :side laugh and the guy Pays Cash for everything He Just Bought a JD 9506R from them which Cost almost $400,000 at MSRP Before configuration and Yes He Has Damaged Big Machine of that size as well or so Iím Told
John Deere Models:X748,GX335,140H3,112,Sabre 1542
Ingersoll Model:3016PS
Simplicity Models:Wonder Boy
White Model: GT2055
Sergeant is online now
post #41 of 45 Old 06-07-2013, 04:20 PM
Deere addict
Sergeant, you've got my curiosity piqued now. How on earth do you break a 9560R? I've run some big equipment before and you have to really try to break something because they're so over engineered and built.
Dave
78 John Deere 312 Project: Work Horse
79 John Deere 317 Project: TBD
65 John Deere 110 Project: Show Queen
07 John Deere 2305 w/200CX Loader
Yooper75 is offline
post #42 of 45 Old 06-08-2013, 04:23 AM Thread Starter
Sergeant's Avatar
Well He Hasn't damaged the New JD 9506R Yet and I say Yet! It was a Tractor of that size I think It was a CASE/IH or a Ford Versatile
White Model: GT2055
post #43 of 45 Old 06-08-2013, 07:59 AM
Tudor,
Thanks,
GotDeeres
A perfect vacuum is 0 psi. Atmospheric pressure is 14.7 psi. Negative pressure is betwen those 2 numbers. The seals are designed to withstand 2500 psi. I don't see them failing due to negative pressure.
Hydraulic hoses usually have their pressure rating printed on, or formed into, the abrasion protection (the rubber cover on the outside of the hose). Cylinders will sometimes have their pressure rating stamped into one end of the barrel. For FEL hydraulics, the minimum for both is 2500 psi, even for the old Johnson and KwikWay loaders. Somehow, I don't think that JD would derate their equipment below standards used by companies making loaders for light GTs 40 years ago and that are still in service today.
My guess is the damage to the cylinders came from other than hydraulic pressure. More like something broke from the heavy load and the cylinder rods, barrels, or the cross tubes suffered mechanical damage.
I searched, but couldn't find the necessary specs for the K92 pertaining to the pump/motor pressures, but I suspect that your thoughts are correct at 1550 psi, or at least in close proximity. For a Sundstrand Series 15, the rating for GT service is 1500 psi, and the peak rating is 4500 psi. A hydro capable of surviving even peak pressures of 10,000 psi woud be a very heavy piece of equipment. The traction conditions needed to produce 1500 psi at 3/4 thottle are difficult in the extreme to find for my 2400 lb GT. It usually spins its chained tires at lower pressures.
The only way that I can think of to test the pressures in a hydro in a heavy GT or SCUT involves tire chains, a large tree or other immovable object, and a low throttle setting.
TUDOR is offline
post #44 of 45 Old 06-08-2013, 11:56 AM
In my research I found that the JD 455 (k91/2) Transaxle forward relief valve is set at around 3900 lbs.
I was looking because mine I think is set too low because it will stop moving without spinning the tires. This is with only 50lbs of weight on the ATV tires and climbing a really steep hill with only the deck and loader on it.
But, there are no test ports to confirm the settings. So, one of these days I'll just pull the fender pan and stick a shim in it and try it out. I sure don't want to overdo it, but would like more forward torque.
antiqueetc is offline
post #45 of 45 Old 06-08-2013, 10:59 PM
You can't shim the hydro relief valve (again, you only have one if you have a loader). Only the IRV for the external hydraulics can be shimmed.
