Homemade back blade. - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 13 Old 05-11-2013, 09:27 PM Thread Starter
JDfreak2012's Avatar
Images: 8
I made a back blade from an old Gilson front blade and a cheap engine stand. The engine stand has a natural swivel point to adjust blade angle. A hole for the hiych pin, weld it to the blade and viola! In the pics you'll see the sleeve hitch I made for my old 112 mounted to my X500. 2 bolt holes drilled into the side of the rear frame plate and it fit right on!
JDfreak2012 is offline
post #2 of 13 Old 05-11-2013, 09:34 PM Thread Starter
Images: 8
Re: Homemade back blade.
Here's a pic of the homemade sleeve hitch.
post #3 of 13 Old 05-11-2013, 09:37 PM Thread Starter
Images: 8
Here's the first revision. The blades a little far away from the tractor so I'm gonna shorten it up.
post #4 of 13 Old 05-11-2013, 09:40 PM Thread Starter
Images: 8
Here it is all shortened up. I reinforced the joint with a plate on the side.
post #5 of 13 Old 05-11-2013, 09:42 PM Thread Starter
Images: 8
Primed it all to prep for green/yellow topcoat.
post #6 of 13 Old 05-11-2013, 10:03 PM
SonnyT's Avatar
Images: 26
Looks like you did a fine job!
RIP Sonny T.
1954-2015
SonnyT is offline
post #7 of 13 Old 05-11-2013, 10:27 PM
rbick1's Avatar
now why didn't I think of that! excellent idea, I see those engine stands cheap all the time.
tractors: 74-446, 78-224, 78-446, 79-446, 81-224, 83-444, 84-226, 86-222, 92-3118
decks: M-46, J-45 or J-46, 46 in, and 3 more 48 in
blowers: L84, L80, J80
blades: L50, homemade 48 inch v-plow
http://www.youtube.com/user/TheRBNetwork
rbick1 is offline
post #8 of 13 Old 05-11-2013, 10:39 PM Thread Starter
Images: 8
I mounted the DPDT switch on the right rear fender. I thought about putting it on the dash but your always turned around to watch the implement when raising and lowering.
post #9 of 13 Old 05-11-2013, 11:27 PM
Nice. There's an old Montgomery Wards (Gilson) blade at my dad's, I may have do something like this...
Sent from the MTF Free App
ericstromberg is offline
post #10 of 13 Old 05-12-2013, 12:11 AM Thread Starter
Images: 8
Yeah the Gilson/Montgomery Ward blades are heavy enough to weld to. Not like the Craftsman blades. Hardest part was cutting off the original mounting system off of the blade. I may remove the large height adjustment shoes before I'm done. I built this to use when I have the snowblower hooked up so I can back drag away from garage doors. I want to get as close to the door as possible. Kinda like a backhoe scraping dirt off of a block wall.
post #11 of 13 Old 05-12-2013, 12:19 AM
Will it swivel 180 deg. so you can also push with it?
Just call me Larry
2012 JD X729, 62C deck, 45 loader, 54" front blade, Quick Hitch, Cat 1 3PH, Heavy Hitch. Heavy Hitch Forks. Heavy Hitch Sub Soil Ripper. Heavy Hitch sleeve hitch. 8 JD suitcase weights. 2-50# cast rear wheel weights. 4 home made 63# wheel weights. Front fork frame for 45 loader.
197? Economy Power King Model 1614 with tandem transmissions, hydraulics and 3PH and 48" mower deck.
Thread for 110 RF build http://www.mytractorforum.com/12-john-deere-forum/287161-66-110-rf-rebuild.html
1966 JD 110 RF, Model 38 mower deck, Model 30 tiller, 580 TracVac, Home built log splitter, Stihl MS260 Pro Chain Saw,
Stihl BG85 Leaf Blower, Echo GT2400 Weed Whacker, 20KW Generac standby generator.
KWDAILYD is offline
post #12 of 13 Old 05-12-2013, 12:34 AM Thread Starter
Images: 8
Yes, you just let it drop, spin it around, and you can push. Angle has 6 positions forward or back.
post #13 of 13 Old 05-12-2013, 08:22 AM
04zrx's Avatar
nice job, I love to see pictures of home made attachments, it gives me ideas.
1984 John Deere 420 (sold)
home made 3 pt.receiver hitch
2002 X585 with 45 FEL and 54C deck
extended weight bracket (8)
04zrx is offline
