Any reason I couldn't put bigger tires on X340? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 11 Old 04-26-2013, 08:15 PM Thread Starter
JohnnyReb's Avatar
After looking at some X500 series I really like the beefier tires and the knobby tread. Considering my X340 and the 500 are basically on the same frame and tractor body is there any reason why I couldn't go to a 24 inch back tire and up to the 16.5 on the front like the 500???
Now some will say why not just buy a 500 series. Well I don't really need the extra features and liquid cooled ect ect. Don't really need a heavier tranny either. But I do like the larger tires. Might be a little better for crossing a few rough spots on my property. And that knobby ATV like rear tire on them would be great for better traction up a slope I have on my land. I'm just wondering how it will effect my deck height. The tractor will set taller I would think so my deck setting will be off. I normally mow at 3 inches so I guess I could drop it to 2.75 to compensate??
2015 JOHN DEERE 1025R H120 60D
2004 JOHN DEERE X485
1983 JOHN DEERE 318
2000 JOHN DEERE GT235
1953 FARMALL SUPER A
2002 HARLEY DAVIDSON WIDE GLIDE
MY TOYS!!
JohnnyReb is offline
post #2 of 11 Old 04-26-2013, 08:19 PM
Re: Any reason I couldn't put bigger tires on X340?
If you're lookin for better traction i'd go for an AG tire in the same size of the stock tire.
I said I work on em', I didn't say I fix em'.
brokenbeak387 is offline
post #3 of 11 Old 04-26-2013, 08:25 PM
robcfo's Avatar
The only thing I can think of is that a lager tire will change the gearing and added weight can rob you of a little horse power - but if you have plenty to spear, go for it. I also like the bigger tire look.
robcfo is offline
post #4 of 11 Old 04-26-2013, 08:51 PM Thread Starter
JohnnyReb's Avatar
It's got the 25hp Kawasaki so power isn't a issue.
The rear is fine for now. There 22x11 I think. But I'd rather habe the 16.5 on the front. Would I notice the front being taller going from 15.5 to 16.5?? Don't wanna get everything out of whack
1983 JOHN DEERE 318
MY TOYS!!
post #5 of 11 Old 04-26-2013, 09:42 PM
jdaws's Avatar
I don't know what transaxle you have, but I know they have a max tire size rating. This would be your limiting factor.
jdaws is offline
post #6 of 11 Old 04-26-2013, 09:48 PM
MTF Tractor Nut
wizzo's Avatar
The transmission manufacturer lists the max tire size as 23" http://www.tufftorq.com/?page_id=141 for whatever that would mean to you. Not sure that you could tell the difference between a 22 and a 23" tire if you kept the same rims. There should be lots of ATV tires in both sizes. Will a 24" tire hurt the transmission, I doubt it... Send an email to Miller Tire, mention MTF and see what they can do for you.
2010 John Deere X500
  • 48X w/ Mulch Kit, Gators & HDAPs
  • Brinly Plug Aerator, JD Spreader & 10p Cart
  • 48" Front Blade, Wheel Weights & Suitcase Weights
  • 30" Mechanical Tiller
1994 John Deere 14SB
2000 John Deere JX75
Stihl KM 90R Kombi System
2005 Lawn Boy 10684 Insight Mower
wizzo is offline
post #7 of 11 Old 04-26-2013, 10:04 PM Thread Starter
JohnnyReb's Avatar
It's a K58 tranny. Mowing and pulling a 2 wheel cart sometimes with a light load. I may just stay at 22 rear with a more aggressive tread. But I want to go to a 16 inch front tire like the 500s. Just not sure if it will affect the stance of the tractor. I don't want the front sitting up higher than the rear or having a " raked" stance
1983 JOHN DEERE 318
MY TOYS!!
post #8 of 11 Old 04-26-2013, 10:11 PM
MTF Tractor Nut
wizzo's Avatar
If you change one tire size or the other (front or rear) I'd still relevel the deck after you put the new tires on because the front and rear height of the deck are supposed to be different. I'm not sure most people would notice the difference in stance, maybe put the front of your X340 up on some 1/2" thick boards and see if it feels weird.
wizzo is offline
post #9 of 11 Old 04-28-2013, 12:45 AM
I agree that you may be better served with changing to a more aggressive tires rather than upsizing it. Larger tires lowers the overall gear ratio, it increases speed but reduces torque. It increases stress on the hydro, and makes your brake less effective. You mention about going up a slope, not knowing how steep it is, your tractor will actually has less torque to tackle the hill even if you get better traction. I would not want to chance it with a K58. You weakest link is not your engine, but your hydro.
For the mower deck, you will need to re-level it as front vs. rear now has a half inch difference. You will also need to drop mowing height by 1 inch as your tractor is now a inch higher off the ground in the back, and 0.5 inch higher in the front.
Personally, lawn tractor is form follows function, I would not sacrifice durability and performance for look.
forum009 is offline
post #10 of 11 Old 04-28-2013, 12:58 PM
Onan18's Avatar
Is there a hub kit that will fit on the K58 axle and allow you to use a bolt on rim like a 500 series? I would rather have bolt on rims for the convince of being able to service/change the tires.
Joe
Onan18 is online now
post #11 of 11 Old 04-28-2013, 07:34 PM
Proud JD Owner
Mach-1's Avatar
Joe
Hubs from a K66 would probably work. Both have axles that are 1" diameter.
___________________________________
2008 X720 Ultimate
54" Blade
47" Snowblower
Powerflo Bagger
Mulch Kit
#18 Dump Cart
Mach-1 is offline
