Gt235 with vanguard and 54" deck stalls in thick grass - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 16 Old 04-08-2013, 10:05 PM Thread Starter
Got Grass?
MowJoe's Avatar
I mowed a yard today with my gt235 and this is the first yard I have mowed since putting on a 54C deck. Yard was tough, thick, and a bit high. I would expect it to bog down the mower some but not to the point where it almost kills it. At times it felt like it was stalling out the deck. Is a 54 too much for the 18 hp Vanguard to handle or do I have other problems?
Sent from the MTF Free App
'16 X570 48" cut
'08 X520 48" cut
'05 GX255 48" cut
'88 316 3pt lift
(3) 80 Dump Cart
18 Dump Cart
JVR Mowing "Got Grass?"
MowJoe is offline
post #2 of 16 Old 04-09-2013, 12:09 AM
Todd_D's Avatar
Re: Gt235 with vanguard and 54" deck stalls in thick grass
There are other variables - blade sharpness, wet grass, etc. I don't think a 54" deck is too much for an 18 hp Vanguard. A lot of people have 18 hp tractors with 54" decks. But 54" decks are as big as they get unless you go to the 400 series.
Current Machines: 318, 430, 430, 455, X748
Former Machines: 355D, GX345, X300, 318, 322, 420 w/ 44 Loader, 214, 110 RF, F935, GT225, 316
Todd_D is offline
post #3 of 16 Old 04-09-2013, 07:07 AM
Penn State Puller!
MichaelTJD60's Avatar
Is the Vanguard the original motor? Supposedly theyre really good motors, I'd be surprised if thats an issue. Of course, I'm pretty sure HP is measured differently today than it was 10 or 20 years ago. My 26 HP with 54" deck always stalled in pretty thick grass but that was because the valves were out of adjustment. Have you adjusted your valves? And the factors that Todd_D mentioned can also affect the cut too.
-2016 JOHN DEERE X570
-1983 JOHN DEERE 210
-2000 JOHN DEERE LT155
-1954 JOHN DEERE 60
-1974 CUB CADET 129
-2008 CUB CADET GT2550
-1969 FORD 4000 DIESEL
-PAST: 1987 JD 316 (R.I.P. ), 1984 JD 316, 1989 JD 318, 2007 JD LA150, 2001 JD LT133, 1997 JD LX176, 1984 JD 111 (R.I.P.), 1973 CUB CADET 86, 2001 CRAFTSMAN LT1000, 1992 YARD KING 38-12
MichaelTJD60 is offline
post #4 of 16 Old 04-09-2013, 07:36 AM
JohnnyReb's Avatar
My dad has a GT235 with the 18hp and 54 inch deck. He bought it brand new and is on its 13th mowing season. A real tuff and lasting mower for sure.
But the 18hp engine is a little underpowered for the 54' on heavy duty. For adverage yard mowing it does just fine, but its not going to " bush hog " knee high grass well...especially with the deck set really low. We always mow on 3 inches or 3 1/4. On the other hand I've never had it stall on me but really thick and tall grass will certainly work the 18horse hard. But it has been a great little engine and mower. 13 years and going strong.
Make sure the blades are sharp and maybe mow a little higher...3 inches works well for dads. Might run some premium non ethanol gasoline too and see if it helps. Of course I realize that can be tuff to find. Fortunately my small Kentucky town has a non ethanol pump for small engines and equipment. Will it help....I guess that's debatable
JohnnyReb is offline
post #5 of 16 Old 04-09-2013, 07:50 AM
toppop52's Avatar
The Vanguard is an excellent engine but the torque peak is 30 ft lbs @2600 rpm, the torque curve is fairly flat from 2200-2800 rpm then falls off dramatically the 3500-3600 rpm cutting speed, so if it starts to stall it won't recover as well as a bigger engine with the same h.P. rating. The Vanguard only has 35 cu. in. to work with so torque output is limited and moved in the rpm band as compared to say a 48 cu in. 18 H.P. Onan. So the V has more peak power but the O will put torque where you need it better in the real world.
I'm not putting down the newer engines, I have a B&S 26 h.p. V-twin, but at work that requires a heavy load on the engine the old Onan works better.
Randy
MF 1855 FEL
toppop52 is offline
post #6 of 16 Old 04-09-2013, 09:42 AM
Also make sure the deck is adjusted properly with the back of the deck a little higher than the front.
rayjay is offline
post #7 of 16 Old 04-09-2013, 10:23 AM
Make sure it's running on both cylinders.
rscurtis is offline
post #8 of 16 Old 04-09-2013, 02:51 PM
Nouveau Redneck's Avatar
Are the deck and engine the original ones designed for that tractor? If this was a "cobble together" job, then perhaps the pulleys aren't the correct ratio to deliver the correct blade speed at the normal operating rpm of the engine.
Nouveau Redneck
Sean in PA
2008 John Deere X500
2015 John Deere X530
Nouveau Redneck is offline
post #9 of 16 Old 04-09-2013, 03:18 PM
Penn State Puller!
Agreed. Thats what I meant when I said they don't measure HP the sane way they used to. My uncle's 318 with 46" deck and LX770 Linamar mows foot tall weeds in the nursery every week without a problem. My 210 with 1-cyl Kohler and 39" deck mows foot tall weeds without a problem. My 5-year-old LA150 v-twin may run faster, but it doesn't put out as much torque at max RPMS. And i ALWAYS mow with the deck all the way up (perhaps it wasn't set up right at the factory?)
-1954 JOHN DEERE 60
-1974 CUB CADET 129
post #10 of 16 Old 04-09-2013, 04:49 PM
So the way they measure horsepower these days is insane?
Sorry... I couldn't help myself.
Nouveau Redneck
Sean in PA
post #11 of 16 Old 04-09-2013, 07:01 PM
Penn State Puller!
I secretly meant to say that I'm pretty sure a 26 HP Briggs v-twin is weaker than an 18 HP Onan opposed twin...
-1954 JOHN DEERE 60
-1974 CUB CADET 129
post #12 of 16 Old 04-09-2013, 09:26 PM Thread Starter
Got Grass?
MowJoe's Avatar
Original motor. Blades are new. Deck is the 54c that would have came on it new. Mower has 221 hours on it. I'm thinking I may have a carb issue that's causing it. I noticed today that when I started it and ran the throttle all the way up it stuttered a bit before it caught up. Under a load it would do the same and cause a stall correct?
'16 X570 48" cut
'08 X520 48" cut
'05 GX255 48" cut
'88 316 3pt lift
(3) 80 Dump Cart
18 Dump Cart
MowJoe is offline
post #13 of 16 Old 04-10-2013, 12:56 AM
You don't have a mulching kit on the deck by chance do you? Any dense wet grass, thick/ high grass or tall weeds don't do well with a mulch kit on the deck. All of our small mowers on the golf course I work part time at have the 18hp Vanguards and they are pretty darn strong motors. Just curious, good luck to you!
GetOffMyLawn is offline
post #14 of 16 Old 04-10-2013, 08:17 AM Thread Starter
Got Grass?
MowJoe's Avatar
No mulch kit. Dry grass and mowed on 2.5.
'16 X570 48" cut
'08 X520 48" cut
'05 GX255 48" cut
'88 316 3pt lift
(3) 80 Dump Cart
18 Dump Cart
MowJoe is offline
post #15 of 16 Old 04-10-2013, 08:19 AM
JohnnyReb's Avatar
Depends. Does it only do that from a cold start?? I never start mine and let it go straight to full throttle. I let it warm up a few minuets first. If it stutters a lot when you go wide open on a warm engine it very well could be running rich and would cause stalling under a load. Notice any black smoke before it stalls? Is a sighn of too much fuel being fed to the engine. Of course it's natural to puff a little black smoke after choking it to start when cold, but not when it's warmed up. If it blows some black smoke when you open the throttle when it's warm and it stutters then it could be rich....essentially like running with the choke on. It will kill the power. Give the carb a good inspection and look for any wetness or find a freind to help you out. Good luck and feel free to ask all the questions you want.
