X728 Fender Deck Question - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 7 Old 04-06-2013, 08:38 PM Thread Starter
aquist06's Avatar
Hi everyone, I was wondering if your cupholders on your X700 series tractors have holes in the bottom or are they solid? Mine is solid and always fill with water when I wash it or get caught in the rain. I think I am going just drill a few small holes in the corners but was curious.
Thanks
Adam
2014 1025R, 54" AutoConnect Deck, H120 Loader, 14 Bushel Bagger, 60" QH Blade, 49" Kuhn Tiller, 47 snowblower, 54 rotary cutter
2005 X575, 54" mower, QH, three point hitch
aquist06 is online now
post #2 of 7 Old 04-06-2013, 08:40 PM
Mike X485's Avatar
Images: 8
Re: X728 Fender Deck Question
My X485 has three holes in the bottom.
JOHN DEERE X748
Mike X485 is online now
post #3 of 7 Old 04-06-2013, 08:41 PM
Thanks
Adam
Adam,
I have 2012 X748SE and it has 3 small (1/8" maybe) evenly spaced holes in the bottom of it to drain any fluids.
Roger
X748SE is online now
post #4 of 7 Old 04-06-2013, 09:22 PM
Hostaman's Avatar
Thanks
Adam
The holes get stopped up due to being the exposed to the wheel well. Look again.
JOHN DEERE X729(2012)
54" Deck w/BM20827 Mulch Kit, 45 Loader, JD BM23882 Cat 1 3PH, JD LPHDC18JD 18 CuFt Cart, JD LP22862 25 Gallon Sprayer, JD LPPA48JD 48" Core Aerator, JD LP25001 3-Point Receiver Hitch, JD BM17972 50 lb. Cast Wheel Weights, JD BM22725 Wheel Spacers, Custom Heavy Hitch, *TOMBSTONE Ballast Slab, Eight Suitcase Weights, Fluid Filled HDAPs on Stock Wheels, Turfs on SE Wheels, SE Seat, Brush Guard, Click-N-Go Weight Bracket (Modified to hold eight suitcase weights)
named by PA318Guy
Hostaman is offline
post #5 of 7 Old 04-06-2013, 11:27 PM
Have Dog - Will Travel
Jere39's Avatar
My 2010 x728 cup holder does have holes, but they are too small in my mind, and clog up so that I always need a tooth pick or other similar sized probe to open the holes to drain the water after a wash. I'd guess your holder has the holes, and they are clogged.
Anyone drill the holes out a little bigger?
Jere39 is online now
post #6 of 7 Old 04-08-2013, 01:07 PM
Jerry
MNvet's Avatar
After washing the winter crud (salt) off the X748 and blower before removing the blower, I noticed the cup holder still had water in it. I looked it over and determined the holes needed to be cleaned out...that is to say drilled out to remove burrs left after manufacture/assembly. I simply used a drill bit by hand from under the fender pan. I would say the holes were about 90% closed. They drain good now!
John Deere X748 and assorted attachments
MNvet is offline
post #7 of 7 Old 04-08-2013, 09:06 PM Thread Starter
aquist06's Avatar
Thanks for the help, I do have them, but they will need to get opened up some.
