Re Fuel shut off solenoid and Circuit Board, Diesel Module John Deere 455 Yanmar 22 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 6 Old 03-14-2013, 12:35 PM Thread Starter
02603sec's Avatar
I searched and searched. Couldn't find anything that speaks to this subject directly: 3 Wires go to the harness to power the Fuel Shutoff Solenoid Part Number AM124379, RED BLACK and WHITE. The Red HOLDS, Black is Ground and White is the POWER that PULLS IN the unit. Testing procedure; provide power key on with Seat control bypassed. Turn the key on and off and test for voltage accordingly on each, red and white. If you have battery voltage; then buy a new Shut off Solenoid*. IF NO POWER on either RED or WHITE; Put your fingers on each of the TWO relays and verify that both click, the LEFT relay is the PULL IN RELAY the RIGHT is the GLOW PLUG RELAY. IF THERE IS NOT 2 clicks, then check the grounds, but you'll have to buy a new CIRCUIT BOARD because this is a solid state unit. The old part number for the CIRCUIT BOARD is AM115249. It has been revised to AM120740. The revision requires a new harness plug, AM136628. My circuit board had a loose pin.
* Shut off Solenoids, seem like they should never wear out, but heat will kill them.
1998 1750 hr 61 Bobcat ZTR 22 Vtwin Kohler
2003 GT 5000 25 Vtwin Kohler (motor out)
1993 JD 455 In Service
[SIGPIC]
02603sec is offline
post #2 of 6 Old 03-14-2013, 12:39 PM
Re: Re Fuel shut off solenoid and Circuit Board, Diesel Module John Deere 455 Yanmar
By loose pin is this something you cloud fix with a simple solder job?
1996 JD 455 2ws 450 tiller, 47" blower 54" blade, 54" mower
2006 JD 3720 with lots of goodies my favorite being my Harley rake followed closely by my Farmi skidding winch
2013 JD x750-AC w/60" HC deck
KennedyDiesel is offline
post #3 of 6 Old 03-14-2013, 12:44 PM
MTF mile high club member
Diesel Powered's Avatar
What, exactly, is your question?
2011 JD X748
2004 JD 4410 TLB
Diesel Powered is offline
post #4 of 6 Old 03-14-2013, 01:09 PM Thread Starter
02603sec's Avatar
How about this for search terms; Fuel shut off solenoid "pull in controller" non functional, not working, needs fixed, fix, replaced, diagnosed, diagnosis, circuit test, voltage test, on John Deere 455? (search for) Diesel Module John Deere 455 or Fuel Shut Off Solenoid John Deere 455 3TNA72UJ3 CH3029D
[SIGPIC]
02603sec is offline
post #5 of 6 Old 03-14-2013, 01:11 PM Thread Starter
02603sec's Avatar
kennedy, thanks for the thought, but the board looks dusted anyway.
[SIGPIC]
02603sec is offline
post #6 of 6 Old 03-14-2013, 01:11 PM
So your tractor is fixed now and you're just providing info to people that may have an issue in the future?
2011 JD X748
2004 JD 4410 TLB
