140 Brakes - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 29 Old 09-30-2012, 01:46 PM Thread Starter
Diesel Power
Harryc's Avatar
140 Brakes
I took a look at the brakes on the 140 today because it barely is able to hold on a hill, and unfortunately I live on a good sized one. In the pics below, the left pad/shoe is quite a bit more worn than the right, and in the 3rd pic, I am holding the brake lever in the position where the pads/shoes are just touching the rotor, and per the Service Manual that is where you adjust it to. As you can see there is no way I can adjust that clevis on the threaded rod to take up all that slack. So am I looking at new shoes? I wonder if there is a spec for the thickness of the rotor? It could be worn too I suppose.
Edit: Just checked Deere parts, both shoes and the rotor are NLA. Great ... such is life with a 43 year old machine.
ID:	231324   Click image for larger version
ID:	231325   Click image for larger version
Harryc is offline
post #2 of 29 Old 09-30-2012, 02:03 PM
new nut but loving it
deerenut's Avatar
Images: 11
Re: 140 Brakes
Harry
For some reason I am thinking that I read some where about relining the shoes... Sorry can not remember where or when. Hopefully I did not dream it. But maybe it is the best option.
What do the other members think? Fellows?
The Deerenut's Herd
95' STX 46
94' LX176 with powerflo and bagger-Mrs. Nuts
70' 110 with model 39 deck
69' 110 with model 39 deck, Horn
69' 140 H-3 The green painted patio Pat.
Model 33 tiller two extentions
200 series Pincor generator
#10 cart
#7 cart
71' Model 68 (Holly's first machine)
She sold it... money in her college fund
91' 322 with 50" deck The Duck
92' 430 with 60" deck and 44 loader
deerenut is offline
post #3 of 29 Old 09-30-2012, 02:22 PM
DeereGuy
blackfoot1's Avatar
Images: 7
Re: 140 Brakes
I doubt the rotors are worn.
Check the condition of the lever at the point of contact to the back of the pad. Also, check this point on the back of the pad for wear.
Pads can be relined at a reputable brake shop, by someone who knows what the heck they're doing. Check with a truck repair/srvice shop for info on who relines brakes in your area.
Michael
2008 JOHN DEERE Z445, 54" Deck.
1986 JOHN DEERE 330, 50" Deck. Home built CAT 0 three point hitch.
1971 JOHN DEERE Model 15 Chain Saw
blackfoot1 is offline
post #4 of 29 Old 09-30-2012, 02:37 PM
Old equip is awsome.
Re: 140 Brakes
Looking at your picture it appears the plate that your brake lever goes through is bent and it should be straight, it is common for those to bend on a hard brake application and these disc brakes never worked that well, that's why every tractor after the 140 and 120 had drum brakes instead of disc
Tractors:
1967 sears suburban 10
1968 John Deere 140
1969 John Deere 112
1970 John Deere 120
1970 massey ferguson 12
1974 John deere 112
1982 John deere 317
Three point hitch for 317 or 140 or 120
2 Brinly 12" three point plows
Brinly 10" sleeve hitch plow
Briny three point cultivator
Brinly 4' sod roller
John Deere 54" blade
John Deere rear tiller for 317 or 140
Custom built sleeve hitch 3 bottom plow
Custom built sleeve hitch box scraper
TRACTORMANDAN is offline
post #5 of 29 Old 09-30-2012, 02:44 PM
Re: 140 Brakes
And see how the bolts are that hold the brake assembly together, it appears that those bolts need to be tightened down to hold the assembly tighter together to take out the excessive clearance.
Tractors:
1968 John Deere 140
1969 John Deere 112
1970 John Deere 120
1974 John deere 112
1982 John deere 317
post #6 of 29 Old 09-30-2012, 02:57 PM
Re: 140 Brakes
Check where the lever rubs on the back of the brake pad, its probably worn a divit in the back of the pad and the end of the lever will have some wear as well as the pin that goes through the brake lever that is the pivot point for the lever, these points will wear out before the brake pads ever would because there is not a lubrication method for these parts and they are normally left dry which accelerates the wear
Tractors:
1968 John Deere 140
1969 John Deere 112
1970 John Deere 120
1974 John deere 112
1982 John deere 317
post #7 of 29 Old 09-30-2012, 02:59 PM Thread Starter
Diesel Power
Harryc's Avatar
Re: 140 Brakes
I thought of that, but there are (2) things at play. First you need movement on those pins/bolts so that the shoes can move in and out. The second thing is that they are not threaded all the way through, and the nuts on the ends of the bolts are up against a stop and tight...I might be wrong though. I'll take another look. Thanks
Harryc is offline
post #8 of 29 Old 09-30-2012, 03:02 PM Thread Starter
Diesel Power
Harryc's Avatar
Re: 140 Brakes
Looking at your picture it appears the plate that your brake lever goes through is bent and it should be straight, it is common for those to bend ...
Wow, really? That is VERY thick steel plate. I'll see if I can find a pic of how it should look.
Harryc is offline
post #9 of 29 Old 09-30-2012, 03:05 PM Thread Starter
Diesel Power
Harryc's Avatar
Re: 140 Brakes
Check where the lever rubs on the back of the brake pad, its probably worn a divit in the back of the pad and the end of the lever will have some wear as well as the pin that goes through the brake lever that is the pivot point for the lever...
I'll take another look. The plate and the lever are also NLA though. Worst case is I weld a 1/4 or 3/8 small square piece of plate to the back of the shoe where the lever hits on each side. That would probably take care of the problem.
Harryc is offline
post #10 of 29 Old 09-30-2012, 03:11 PM Thread Starter
Diesel Power
Harryc's Avatar
Re: 140 Brakes
OK, take a look at this EBay picture. The plate the lever goes through is also bent over pretty well. I'd have to say that is normal.
http://www.ebay.com/itm/1968-70-JOHN...item51a12de467
Harryc is offline
post #11 of 29 Old 09-30-2012, 05:37 PM Thread Starter
Diesel Power
Harryc's Avatar
Re: 140 Brakes
Anyone have an idea of what the pad thickness was on the original '69 140 brakes? I am guessing somewhere around 3/8"
Harryc is offline
post #12 of 29 Old 09-30-2012, 06:36 PM
JRJ
The owners manual
JRJ's Avatar
Re: 140 Brakes
Gosh Harry, is that 140 falling apart on you-tell you what, just ship it down this way and I will take it off of your hands then no more brake problems.
Dick
GT275
GT235
JRJ is offline
post #13 of 29 Old 09-30-2012, 07:12 PM Thread Starter
Diesel Power
Harryc's Avatar
Re: 140 Brakes
Originally Posted by JRJ View Post
Gosh Harry, is that 140 falling apart on you-tell you what, just ship it down this way and I will take it off of your hands then no more brake problems.Dick
Falling apart? . It never was together... LOL. It is a needy little guy, but no problem because progress is being made so it's all good. I'll post pics someday soon.
Harryc is offline
post #14 of 29 Old 09-30-2012, 07:42 PM
Cementhead's Avatar
Re: 140 Brakes
I would start with taking the whole assembly apart and wire wheel the bolts,springs,spacers and clean the holes in the brake pads where it rides on the same.Also take the adj rod clevis apart and clean - lube the threaded area so it can be adjusted. I think when cleaned up so the brake shoes can slide more easily will probably help and if too much effort is needed to work the brake mechanism you might not be getting all of the range of motion on the whole system.On most disc brake systems on lawn & garden tractors the disc or rotor needs to slide back and forth on the shaft it rides on to function properly and that could be the cause of one pad being worn more than the other.I cant remember if the system you have works this way (its been awhile) but check that out also.I just did this job on Phils electrak different style same principal.
Cementhead is offline
post #15 of 29 Old 09-30-2012, 07:44 PM
Likes Vintage JDs
UrbanTractor's Avatar
Re: 140 Brakes
The 140 switched to drum brakes about mid-way through the production run. Can't remember the exact date, but my '72 has drums.
Harry, no suggestions, but I hope you can find a relatively painless solution!
UrbanTractor is offline
